Dec 26, 2007, 07:02 PM
UK
Joined Dec 2007
Running a glowplug engine on petrol/oil/solvent mix?
Any experience on this subject much appreciated!!
I'm looking at initially mixing approx 20% oil + 80% petrol, and maybe some kind of solvent (white spirit etc. to aid mixing - prob. less than 5%)
The flashpoint of petrol is -40C, auto-ignition is about 250C (high to prevent knock)
The flashpoint of methanol (usual model plane fuel I believe?) is 11C, auto-ignition at 455C.
It seems plausible that the engine could theoretically run on either. Compression is very low, so knock is not an issue. Ignition looks likely for petrol fuel.
I will have to run engine much leaner with petrol, i assume? Will this cause problems with engine temperature/explosion risk? With same fuel flow as model plane fuel, i'd be producing about 2x more power (based on specific energy content of fuel).
I don't know how lean i can tune typical cheap .75 glowplug test engine, or could I just increase the lubrication oil content of the fuel? I was thinking of using a fairly non-combustable synthetic. i guess extra oil will just come out of exhaust, but too much will cause higher compression, loss of swept volume, and probably in severe excess, a bent connecting rod.
In ideal world, petrol needs 14.7:1 mixture for complete combustion, ~12.5:1 for max power.
With methanol, engine needs 5:1-6:1 mixture, but much higher fuel flow to produce same power output.
Can anyone confirm if this approach is likely to work, or should I be putting on kevlar helmet / riot gear so that I don't get crankcase or piston in the brain?....
Thanks in advance for any knowledge.
