Old Dec 19, 2002, 06:12 AM
Drago
Drago
Guest
n/a Posts
P-39 nose gear door
Hi guys,
I'm about to start building Top Flite P-39 Airacobra with retracts and
everything, and am having trouble figuring out how to do nose gear door
mechanism. Any suggestion (preferably from someone who had already built it)
would be greatly appreciated.
Seems to me that there is no much room for any elaborate mechanism inside
the nose of P-39, so it would have to be pretty simple to work well.
I saw something (nose gear door) at these nice pages
(http://www.wingsontheweb.com/vhangar.../oct24-97.html), made by guy who
scratch built Dornier 335, but must admit I am not sure I could build
something like that without detailed plans of the mechanism.
Thanks in advance!
Drago
Old Dec 19, 2002, 07:12 AM
CurtD
CurtD
Guest
n/a Posts
Re: P-39 nose gear door
SonicTronics makes a nice kit that works great for gear doors. Here's the
link:
http://sonictronics.evisionsite.com/Hinges.html
It's at the bottom of the page. The kit comes with full instructions on how
to use it.
"Drago" <smaug@bug.hr> wrote in message news:atscld$6l55$1@as201.hinet.hr...
> Hi guys,
it)
who
> Thanks in advance!
> Drago
Old Dec 19, 2002, 07:32 AM
Drago
Drago
Guest
n/a Posts
Thanks a lot - plenty of other nifty thingies on their pages too..
Drago
"CurtD" <not_here@notnow.com> wrote in message
news:atsgj3$gr7$1@slb5.atl.mindspring.net...
> link:
how
> to use it.
> > Hi guys,
> it)
inside
> who
> > Thanks in advance!
> > Drago
Old Dec 19, 2002, 10:12 AM
Chris Spierings
Chris Spierings
Guest
n/a Posts
If its the gear door itself that you are trying to fabricate I"d suggest you
build the fuse with the gear retracted. When you have everthing all shaped and
smooth iron on some monokote or similar covering. Then get yourself some 6
ounce glass cloth and some .75 ounce cloth. Lay up about 4 layers of the 6
ounce making sure the weave is 45 degrees off the previous layer then finally
add a layer of .75 cloth. Let all that cure and then pop it off. This is done
only over the area you expect to need a door for.
Pull the covering off the fuse and continue with your building and finishing.
When you ahve the retract in and the opening set up the way you want lay the
glass piece you made over the open and trace the size to fit the hole you've
made. Cut the door to fit mount with hinges like Sonictronics offers, follow
the directions about keeping the pivot points lined up and you'll have a pretty
nice set up.
Wish I could claim credit for this idea but I learned it from the Dave Platt
video.
Chris
Drago wrote:
> Hi guys,
> Thanks in advance!
> Drago
Old Dec 19, 2002, 01:52 PM
Drago
Drago
Guest
n/a Posts
Chris,
great advice - I was thinking of just cutting the balsa door out of the fuse
once I get the nose gear into place, but it probably wouldn't hold the shape
once cut out from the fuse - your method seems much better.
I am a little apprehensive about glassing since I'm alergic to epoxy, but I
guess an overall, latex gloves and mask should do the job.
Drago
"Chris Spierings" <spierings@removemailbag.com> wrote in message
news:3E01EDBB.CB0DDC89@removemailbag.com...
you
shaped and
6
6
finally
done
finishing.
the
you've
follow
pretty
> nice set up.
Platt
> video.
> Chris
Old Dec 19, 2002, 04:32 PM
Sherman F. Dickson II
Guest
n/a Posts
Lay wax paper over the area. Its easier. I am in the process of building
a plane that will have retracts hopefully, so I have been doing some
research on gear doors and actuators also. I came across this site last
article last evening. Maybe it will be of some help to you also.
http://www.fly-imaa.org/imaa/hfarticles/howto.html
BTW if you happen to receive any good sketches on the subject, I would
appreciate it if you could pass them along to me.
Sherman
Drago wrote:
> Chris,
> Thanks,
> Drago
> you
> shaped and
> 6
> 6
> finally
> done
> finishing.
> the
> you've
> follow
> pretty
> > nice set up.
> Platt
> > video.
> > Chris
Guest
n/a Posts
I was looking at their door hinge kit and it looks interesting. I know
that you can get door sequencers to have servo's drive the retract doors
but on a smaller model the added weight isn't good. Does the kit include
instructions on how to make simple door actuators?
Sherman
> link:
> to use it.
> > Hi guys,
> it)
> who
> > Thanks in advance!
> > Drago
Old Dec 19, 2002, 05:12 PM
Drago@Madness
Drago@Madness
Guest
n/a Posts
Sherman, thanks a bunch!
I'll make sure that I pass along to you any info on this matter I come
across.
On your previous question (instructions on making gear door actuators) there
are none. Otherwise - great kit, and great instructions.
Drago
"Sherman F. Dickson II" <dicksonsf@comcast.net> wrote in message
news:3E0246F4.597214F3@comcast.net...
> Sherman
> Drago wrote:
> > Chris,
fuse
shape
but I
> > Thanks,
> > Drago
suggest
> > you
> > shaped and
some
> > 6
the
> > 6
> > finally
This is
> > done
> > finishing.
lay
> > the
> > you've
> > follow
a
> > pretty
> > > nice set up.
> > Platt
> > > video.
> > > Chris
Old Dec 19, 2002, 10:42 PM
David AMA40795 / KC5UH
Guest
n/a Posts
Here is a site with some ideas fer ya....
http://flyinglindy.homestead.com/b25...ectronics.html
Have fun!
David
On Thu, 19 Dec 2002 13:05:00 +0100, "Drago" <smaug@bug.hr> wrote:
>Hi guys,
>Thanks in advance!
>Drago
Speed 400 Class P-39 pfsiegel Scale Kit/Scratch Built 8 Mar 04, 2002 07:28 PM
Wtb Hob P-39 Nib Megowcoupe Aircraft - Electric - Airplanes (FS/W) 0 Jan 31, 2002 02:55 PM
Retract nose gear steering linkup GMILL47 Scale Kit/Scratch Built 6 Jan 27, 2002 09:58 AM
P-38 landing gear cheapflyr Parkflyers 0 Jul 18, 2001 06:04 PM
Has anybody made an X250 with steerable nose gear? Joe Elston Electric Plane Talk 13 Jun 24, 2001 05:34 AM
