Old Aug 23, 2012, 12:04 AM
TTRotary is offline
Find More Posts by TTRotary
Rangers Lead the Way
Joined Mar 2010
Just as a reminder to me - assuming I use a Scorpion 4026/16 or Power 90, would a 7S 5000 in the battery tray location result in a tail-heavy build or nose-heavy? What I'm really trying to determine is whether I can run a Eflite 10-15 e-tract as a tail-wheel without needing nose weight if I use the stock battery tray location. I'll be using carbon pushrods with forward-located servos rather than the steel pushrods provided with the ARF.
I've heard this one tends to come out nose-heavy, which I find hard to believe as every warbird build so far has required the batts inside the cowl, ahead of the firewall, to make CG.
TTRotary is offline Find More Posts by TTRotary
Old Aug 23, 2012, 01:41 AM
172AMD is offline
Find More Posts by 172AMD
Richmond B.C. Canada
Joined Aug 2006
I am using a scorpion S4025-12 with a CC Ice100 mounted under the motor mount. As you can see my 6s 5000mah pack (835 grams) is well aft of the hatch to achieve balance. Both mine and a fellow club members TF P-51's are nose heavy without the batts installed!
172AMD is offline Find More Posts by 172AMD
Old Aug 23, 2012, 03:17 PM
philipm785 is offline
Find More Posts by philipm785
Joined May 2009
I concur. I'm flying with a 6S 4400 and Rimfire .80 up front and I actually needed some lead in the tail to get it to balance.
philipm785 is offline Find More Posts by philipm785
Old Aug 24, 2012, 12:58 PM
TTRotary is offline
Joined Mar 2010
holy smokes! That's got to be a first for a glo model. You guys have retracting tail wheels?
Old Aug 28, 2012, 07:28 AM
Joined May 2009
Just the standard tailwheel on mine. Honestly the couple of ounces in the back is really not an issue. This plane flies beautifully and lands at a walk.
Old Aug 28, 2012, 11:27 AM
zeus3313 is offline
Find More Posts by zeus3313
United States, FL, Port St Lucie
Joined Jan 2010
zeus3313 is offline Find More Posts by zeus3313
Old Feb 01, 2013, 12:38 AM
SmokeDogg is offline
Find More Posts by SmokeDogg
"Fly Low, Fly Fast, Turn Left"
SmokeDogg's Avatar
United States, CA, Red Bluff
Joined Jul 2009
What's the best way to get in there and open up that battery hatch? Any suggestions or tips?
SmokeDogg is offline Find More Posts by SmokeDogg
Latest blog entry: Miss Foxy Lady eBuild
Old Feb 02, 2013, 09:49 AM
172AMD is offline
Joined Aug 2006
I used pins pushed through from the inside to identify the perimeter of the hatch on the outside. Then used my OLFA knife( AB blade) to cut the hatch out. Take your time!
Old Feb 03, 2013, 11:38 AM
Doug Bateman is offline
Find More Posts by Doug Bateman
Doug Bateman's Avatar
Swarthmore, PA 19081
Joined Dec 2004
I did similar except i used exacto blade from the inside slid between formers and longerons to cut it out. You have to determine the mating pieces and go between them.
I think i am going to start work again on mine. It's been sitting a while now. I did a "B" conversion so i have to recover and paint.
Doug Bateman is offline Find More Posts by Doug Bateman
Old Feb 06, 2013, 03:04 PM
SmokeDogg's Avatar
Joined Jul 2009
I got mine all cut out ok. Wish it would have been done from the factory but I totally get why they didn't... Just glad it is an option..
I ordered up a roll of matching monokote so I can re-cover the hatch and wrap it over the edges to clean it up more. Maybe glue on a little balsa on the ends and lap it all in for a clean smooth edge.
Old Feb 09, 2013, 01:58 PM
TTRotary is offline
Joined Mar 2010
Thats how I'll do my next hatch. They just don't look clean without the Kote being wrapped. The trick is to leave a wee bit on the fuse side to wrap as well.
I have 2 of the ARFs and will start the build pretty soon, after my Gee Bee R3. I did test fit a set of Eflite .60-120s with the Hobbyking .120 size Mustang oleos (very nice) and they are about as close to a drop in as you can get. I use the smaller size oleos on my .40 H9 sport mustang and they have been great. Only caveat is 3.0 max wheel size.
Old Feb 13, 2013, 04:18 AM
SmokeDogg's Avatar
Joined Jul 2009
Got a link to them oleos?
Old Jan 11, 2014, 12:40 PM
Joined Dec 2004
What spray can paint is there to match the iron on covering of the T/F 60 arf?
Old Nov 10, 2015, 09:16 AM
Razer8811 is offline
Find More Posts by Razer8811
Razer8811's Avatar
United States, WI, Lone Rock
Joined May 2013
Old thread but hopefully someone can help me. What adapter do I need or what do I need to get in order to be able to screw the stock spinner into the motor shaft when using a Rimfire .80?
Razer8811 is offline Find More Posts by Razer8811
Old Nov 18, 2015, 07:55 PM
ccc1970 is offline
Find More Posts by ccc1970
United States, FL, Jacksonville
Joined Nov 2010
I used a rimfire 60 in mine and the prop adapters that came with the ARF worked perfectly.. I dont know for sure but i would have to assume the 80 is the same as the 60
ccc1970 is offline Find More Posts by ccc1970
Discussion Top Flite GIANT P-51D ARF Sture Smidt Electric Warbirds 16 Jul 18, 2008 10:18 PM
