Old Dec 24, 2007, 07:19 PM
KatManDEW is offline
Find More Posts by KatManDEW
FASST flyer
KatManDEW's Avatar
USA, OH, Newark
Joined Sep 2001
Axi 2203 or Hacker A10-9L?
I'm ready to install a motor on my Aito, and it doesn't look like it will be easy to swap it after installing. Anyone have any comparison data between the Axi 2203 and the Hacker A10-9L?
KatManDEW is offline Find More Posts by KatManDEW
Old Dec 24, 2007, 07:56 PM
hpapilot is offline
Find More Posts by hpapilot
Oly crap.. Deese ease not gud!
hpapilot's Avatar
USA, NC, Kernersville
Joined Nov 2006
A10-9L will give a bit more power than the 2203/46. It's also 2 grams heavier, but that weight includes the fiberglass mount. With the Axi, you will need to add a mount, so the total weight comes out about the same.
RJ
hpapilot is offline Find More Posts by hpapilot
Old Dec 24, 2007, 08:06 PM
FASST flyer
KatManDEW's Avatar
USA, OH, Newark
Joined Sep 2001
Thanks RJ.
Old Dec 24, 2007, 08:38 PM
3D-Seth is offline
Find More Posts by 3D-Seth
3D-Seth's Avatar
United States, FL, North Port
Joined Jan 2007
I have a Hacker A10 7L - Love it, I dont have any specs on it tho . . . Just got a 2203/46 for my Vrolet hasnt been run yet . . .
Seth
3D-Seth is offline Find More Posts by 3D-Seth
Old Dec 24, 2007, 08:48 PM
hpapilot is offline
hpapilot's Avatar
Joined Nov 2006
Seth, what prop are you running on that 7L? I have one as well, and its much happier on a GWS 7x3.5 HD. Using the 8x4 it pulls too many amps.
The A10-9L is much better suited to a GWS 8x4 DD prop.
Old Dec 24, 2007, 09:55 PM
Bubba Gump is offline
Find More Posts by Bubba Gump
F3P, Slap, IMAC, Helis
Joined Jun 2007
I build a divo with a 9L and flew it with 9x3.8 just fine on two cells.
Bubba Gump is offline Find More Posts by Bubba Gump
Old Dec 25, 2007, 06:20 AM
cmeijer is offline
Find More Posts by cmeijer
ETOC/Claes
sweden
Joined May 2006
AXI on 2 cells
Hi
I use the AXI with 8x4,2 GWS or 8x3,8APC it works great on 2S350 Flightpower. I even got same grams of my AXI by same work with my "dremel"
c meijer in Sweden
www.meijer-models.eu
cmeijer is offline Find More Posts by cmeijer
Old Dec 25, 2007, 08:06 AM
elektryki2222 is offline
Find More Posts by elektryki2222
Poland, Olkusz nearly Krakow
Joined Dec 2004
Hello ! I'm fly only Axi 2203/46 + GWS 8x4 / 8x4.3 in indoor model 130-160gram, in 2s 300mah flight time is : 7-8min and 2s 460mah 10-11min hard 3D. Really more power to fast vertical fly und hover in half trotle. And weight is true ( 19grams ). Best regards Krzysiek.
elektryki2222 is offline Find More Posts by elektryki2222
Old Dec 25, 2007, 11:36 AM
Elad Yeffet is offline
Find More Posts by Elad Yeffet
Elad Yeffet's Avatar
Joined Nov 2007
I think that the best configeration for the aito is the AXI 2204\54.
The AXI 2203 will be too small and powerless
Elad Yeffet is offline Find More Posts by Elad Yeffet
Old Dec 25, 2007, 01:37 PM
3D-Seth is offline
3D-Seth's Avatar
Joined Jan 2007
I use an 8x6 per Andrew Jesky . . . maybe I will try the 7x3.5 HD. What about a 7x3.5 DD?
Seth
Old Dec 25, 2007, 06:32 PM
hpapilot is offline
hpapilot's Avatar
Joined Nov 2006
Seth
Same prop. Sometime they're called "Hyperdrive (HD)" props, and sometimes they're called "Direct Drive (DD)".
RJ
Old Dec 30, 2007, 01:06 PM
rebell is offline
Find More Posts by rebell
JustFlying
rebell's Avatar
Joined Dec 2005
I have a Hacker A10-9L and with an 8x3.8 you can't go wrong. What about the new Hyperion Z1705 or Z1709? I have a Z1709 on order. Specs are looking good.
rebell is offline Find More Posts by rebell
Old Dec 31, 2007, 06:22 AM
cmeijer is offline
ETOC/Claes
sweden
Joined May 2006
I new thing I tried on my AXI is to make it lighter!
I sawed servo on this ruff dremel work:-)
Old Dec 31, 2007, 08:29 AM
rebell is offline
JustFlying
rebell's Avatar
Joined Dec 2005
Ruff? I agree! Is it worth the effort to save those few milligrams? It must have better cooling I presume.
Old Jan 07, 2008, 03:30 PM
DVA is offline
DVA
Find More Posts by DVA
DVA
DVA
Chandler, AZ
Joined Jul 2004
I just flew my 5 oz Yak 55 with a Hacker A10-9L. I am running a GWS 8x4.3 SF prop with a 2 cell TP 350 mAh battery and this thing rocks. I hover at about 1/3 throttle and the punch outs are ballistic. The performance of the A10-9L would be hard to beat.
DVA
DVA is offline Find More Posts by DVA
Wanted Axi,Himax or Hacker motor Dragon 2 Aircraft - Electric - Power Systems (FS/W) 3 Jul 10, 2006 07:55 PM
AXI 4120/14 or Magic-Drive 50-28 (Hacker B50-9L) for Big Excel? agbjarn Power Systems 6 Jun 26, 2006 10:29 AM
AXI or hacker outrunners.... can you replace the shaft? FlybyPDX Power Systems 6 Mar 13, 2005 11:13 PM
AXI Extreme or Hacker B20-12L Stuntman Electric Sailplanes 3 May 22, 2003 04:08 AM
Kyosho EDF/Hacker B40-9L and Master 70-3P OR Jeti 70-3P? TGoodwin Electric Ducted Fan Jet Talk 26 Jun 11, 2002 01:44 AM
