n/a Posts
Re: Searching for a 4 bladed prop for the Top-Flite 1/7th P-51 Mustang.
Your recommended prop sizes are for TWO-bladed props... An 11/6 four bladed
prop will be plenty of load for your .61.. Maybe too much.. Four-bladed props are not well known for efficiency... Use one for display.... But FLY with a two-blade. I think you'll be better off... See APC 4-bld props here: http://www.apcprop.com/store/agora.c...o7jc1&product= 4-Blade Tru-Turn has spinners... Bring $$$$... Cheers, Bill "CKJohnson" <CKJohnson72@aol.com> wrote in message news:c564598b.0212181319.438b0dfe@posting.google.c om... > I've got the Top-Flite 1/7th P-51 Mustang, with an OS Max .61 Engine. > I really would like a 4 bladed prop on her, but am not sure how it > will affect the plane and engine. The recommended prop size is 11x7 - > 12x8, but the closest 4 bladed prop I can find is 11x6. Will that > work? Does anyone know where I can find 4 bladed props and spinners? > > Thank you for any help. |
n/a Posts
CKJohnson wrote: > I've got the Top-Flite 1/7th P-51 Mustang, with an OS Max .61 Engine. > I really would like a 4 bladed prop on her, but am not sure how it > will affect the plane and engine. The recommended prop size is 11x7 - > 12x8, but the closest 4 bladed prop I can find is 11x6. Will that > work? Does anyone know where I can find 4 bladed props and spinners? > Try http://www.ramoser.de/home_e/variopr...rioprop_e.html and see if that will suit. > Thank you for any help. > |
n/a Posts
Try http://www.bolly.com.au/models/glassfour.asp to see the Bolly range of 4
bladed props. This splendid Aussie company does have distributors in Canada, USA, UK etc and seems to be the prop of choice for most TOC pilots. Cheers from Oz. "CKJohnson" <CKJohnson72@aol.com> wrote in message news:c564598b.0212181319.438b0dfe@posting.google.c om... > I've got the Top-Flite 1/7th P-51 Mustang, with an OS Max .61 Engine. > I really would like a 4 bladed prop on her, but am not sure how it > will affect the plane and engine. The recommended prop size is 11x7 - > 12x8, but the closest 4 bladed prop I can find is 11x6. Will that > work? Does anyone know where I can find 4 bladed props and spinners? > > Thank you for any help. |
n/a Posts
Use a four blade prop for static display only. You can get a spinner cut to
your specs from Tru Turn. http://www.tru-turn.com/ Cheers -- \__________Lyman Slack_________/ \______AMA6430 IMAA1564___/ \____Flying Gators R/C______/ \__Gainesville FL _________/ Visit my Web Site at: http://www.LymanSlack.com "CKJohnson" <CKJohnson72@aol.com> wrote in message news:c564598b.0212181319.438b0dfe@posting.google.c om... > I've got the Top-Flite 1/7th P-51 Mustang, with an OS Max .61 Engine. > I really would like a 4 bladed prop on her, but am not sure how it > will affect the plane and engine. The recommended prop size is 11x7 - > 12x8, but the closest 4 bladed prop I can find is 11x6. Will that > work? Does anyone know where I can find 4 bladed props and spinners? > > Thank you for any help. |
n/a Posts
CKJohnson72@aol.com (CKJohnson) wrote in message news:<c564598b.0212181319.438b0dfe@posting.google. com>...
> I've got the Top-Flite 1/7th P-51 Mustang, with an OS Max .61 Engine. > I really would like a 4 bladed prop on her, but am not sure how it > will affect the plane and engine. The recommended prop size is 11x7 - > 12x8, but the closest 4 bladed prop I can find is 11x6. Will that > work? Does anyone know where I can find 4 bladed props and spinners? That engine will never be able to turn an 11x6 4-blade prop. A proper 4-blade prop for that engine is at most 10" in diameter. Instead of a scale-looking gigantic 4-blade prop that barely clears the ground, you'll end up with a wimpy little prop that barely clears the cowl... You won't like the way it looks or flies, guaranteed. If you want scale appearance for static display, you should get the 4-blade display propeller. For flying, use a regular 2-bladed propeller. |
