Old Dec 22, 2007, 09:11 PM
cloud-9 is offline
Find More Posts by cloud-9
Prop me up
cloud-9's Avatar
New Mexico, USA
Joined Oct 2007
Equation for stall speed, wing loading, speed?
Thanks. I'm reading an article
http://www.masportaviator.com/ah.asp...&ID=72&index=1
discussing prop selection, and he mentions an equation for calculating stall speed as a function of speed and wing loading, then he does not include the equation. Does anybody know of such/
Jim
cloud-9 is offline Find More Posts by cloud-9
Old Dec 23, 2007, 01:39 AM
hul is offline
hul
Find More Posts by hul
hul
hul's Avatar
Switzerland
Joined Mar 2003
this is an approximation by Keith Shaw:
stall speed = 3.7 * square root of wing loading
speed in mph
wing loading in oz/sqft
Hans
hul is offline Find More Posts by hul
Old Dec 23, 2007, 02:07 AM
cloud-9 is offline
Prop me up
cloud-9's Avatar
New Mexico, USA
Joined Oct 2007
speed in mph
Hans
Thanks very much, Hans.
Jim
Old Dec 23, 2007, 03:45 AM
JetPlaneFlyer is online now
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
The 'full' formula (in S.I. units) is:
V = sq root (W x 9.81/(1/2p x S x Cl_max))
where:
V = Stall speed M/s
p (rho) = air density KG/M^3
S = wing area M^2
Cl_max = Coefficient of lift at stall
W = weight KG
The simplified 'rule of thumb' version posted above assumes that you are flying at sea level and uses an assumed Cl max.
Steve
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Old Dec 23, 2007, 05:10 AM
Andrew McGregor is offline
Find More Posts by Andrew McGregor
Christchurch, New Zealand
Joined Jun 2006
Or more readably if your computer does all these characters:
V = √( 2 W g / ρ S Clmax )
g = 9.81 m s^-2
ρ is rho
The rest as above.
Andrew McGregor is offline Find More Posts by Andrew McGregor
Old Dec 23, 2007, 08:12 AM
cloud-9 is offline
Prop me up
cloud-9's Avatar
New Mexico, USA
Joined Oct 2007
where:
V = Stall speed M/s
S = wing area M^2
W = weight KG
Steve
Thanks Steve and Andrew. Not sure how I'd get air density or coefficient of lift at stall?
Thanks a lot.
Jim
Old Dec 23, 2007, 09:42 AM
Flyingwingbat1 is offline
Find More Posts by Flyingwingbat1
Joined Jun 2005
air density is about 1.2 kg/m^3 at sea level, max airfoil Cl must be determined from airfoil polar graphs ( Cl/AOA or Cl/Cd, typically).
Flyingwingbat1 is offline Find More Posts by Flyingwingbat1
Old Dec 23, 2007, 09:51 AM
Aberdeen
Joined Mar 2006
Thanks a lot.
Jim
Air density is about 1.25 KG/M^3 at sea level, less as you get higher.
Cl max varies according to airfoil used, wing aspect ratio and the size and speed of the model... Somewhere in the range 1 to 1.5 would be reasonable, small slow flying models being closer to 1 and larger and faster models closer to 1.5
Steve
Old Mar 18, 2008, 11:36 AM
Horten_XVIII is offline
Find More Posts by Horten_XVIII
jeppe
Horten_XVIII's Avatar
Sweden
Joined Jan 2005
Is it Possible that The stall Speed Is Lower than the speed i used for Carculate the Lift?? The wight in the stall speed formula i used the total Lift from the lift Carculation.. but even the stall speed is about 1/5 Lower than i think it shuld be
Horten_XVIII is offline Find More Posts by Horten_XVIII
Old Mar 18, 2008, 11:57 AM
Joined Jun 2006
I don't understand the question… the equation above is for stall speed in terms of the actual weight of the aircraft, you don't need to calculate any lift forces because they are already rolled into the formula above.
Old Mar 18, 2008, 12:28 PM
jeppe
Sweden
Joined Jan 2005
It a bitt hard to explane the question. but im well aware that is no need of carulate lift force in for stall speed.
I Thougt, If I take the Lift Created From the wing(Carculated by formula) Insteed of the actual weight of the aircraft, In that way i can check if the formula is right. For example if i Carculate Lift For 100 Km/h and use the same Data in the stall speed carculation, i would come up with the same Speed (100km/h) but insteed I came up with a stall speed of 72 Km/h. i just wondred if the stall speed use to be lie lower than the speed I carculated lift with?
Im about to do a Design Templet, For making the design better and also adjust
it after the requerments i want.
Thanx
// Luft 46' Design
Old Mar 18, 2008, 01:04 PM
Aberdeen
Joined Mar 2006
But you would be checking the formula against itself ... The 'lift formula' is the same formula as the 'stall speed formula', just transposed to find the different 'unknown' quantities.
Old Mar 18, 2008, 01:32 PM
HugePanic is offline
Find More Posts by HugePanic
German Engineering.......
HugePanic's Avatar
Auxsburg
Joined Dec 2007
some additions:
you have to separate cl and cl_max.
for stall speed you have to use cl_max, for all other flight conditions you have to use cl.
cl depends from alpha (AOA) and has a maximum with cl_max
--> cl < cl_max
for stallspeed the lift is the weight of the model. for climbing lift > wheigt!.
if you are flying faster than stallspeed and NOT climbing (--> cruise), then cl < cl_max and alpha < alpha_max.
HugePanic is offline Find More Posts by HugePanic
Old Mar 18, 2008, 02:42 PM
Aberdeen
Joined Mar 2006
No for a steady state climb; lift = weight.
If the lift was greater than the weight the aircraft would be accelerating upward, i.e. the rate of ascent would be constantly increasing. It's 'excess' thrust that makes an aircraft climb, not 'excess' lift.
Stall speed itself is a somewhat missleading term because it's only applicable if the aircraft is flying straight and level. If the aircraft is turning then stall speed will increase, in fact try to turn too hard and it's quite possible to stall when flying at flat out speed (or pull the wings off, whichever comes first .
Steve
Old Mar 18, 2008, 02:53 PM
HugePanic's Avatar
Auxsburg
Joined Dec 2007
Steve
you are right!
for unaccelerated climb lift = weight *fullstop*
Question motor options for larger high wing loading pusher config. pval3 Power Systems 5 Dec 03, 2007 07:42 AM
Building Floater: wing loading / level flight stall speed relationship opualuan Parkflyers 7 Sep 30, 2007 04:41 PM
Which Slopes for How Much Wing Loading in SoCal? tnavressdog Slope 17 Jul 29, 2005 05:15 PM
Same speed for same wing loading? S55 Modeling Science 8 Dec 15, 2004 04:37 PM
Throttle Target for Stall Speed? martin johnson Electric Plane Talk 1 Feb 06, 2002 06:39 AM
