| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||||||
Millennium RC Micro SSX and Micro SSX Biplane Kits Review
I first met James Karpy of Millennium RC at FITS in January of last year. At that time he had recently started Millennium RC and was showing off his new SSX. By the time SEFF rolled around, he had added a smaller version of the SSX called the Micro SSX and began to offer ARFs as well as kits. Then to my surprise, at the Zephr late last year he unveiled the prototype Micro SSX Biplane. The Zephyr was also the first time I got to see both the Micro SSX and Micro SSX Biplane fly in high winds, and I was amazed at how well these small, lightweight planes faired in far from ideal conditions. One big advantage about living near to Millennium RC is that when the Biplane was ready, I had the opportunity to pay a visit to James and Moe of Millennium and see where these great little planes were created and developed.
Biplane Kit includes:
Needed to Complete:
Micro SSX Kit includes:
Needed to Complete:
Both the Micro SSX and the Biplane are simple builds. They are laser cut, and the builder does not need to build a fuselage. Even a first time builder would have no trouble with one or both of these kits. Millennium RC has their own forum in the Vendor area here on RCGroups, which includes threads with photos for both planes, taking the builder step by step through the build.
The wing or wing(s) for the Biplane are put together almost completely before gluing. The only exception is the ribs that support the struts as seen here.
Once all ribs and stringers are in, the amazingly strong wing(s) are glued.
Tail Section
The tail sections on the two planes are different. On the Bipe you build the tail with interlocking pieces, and with the Micro SSX the vertical and horizontal stab have a lot fewer pieces.
One trick I used on some of the exposed pieces of wood is coloring them with a Sharpie. It did a great job in making them match the airplane.
Covering
The Bipe is covered with Solite, and the Micro SSX is covered in Solarfilm. Both coverings are fairly easy to work with, but the Solite can be a little challenging as it really likes to stick to itself. The technique I used on both was the same, and I learned it from James from Millennium RC.
Basic steps:
I used this technique to add the white stripes to the top wing on the Micro SSX as well as the white patches on the top wing on the Bipe.
Final Assembly
The final assembly for both kits includes hinging the control surfaces with tape, mounting the servos, putting together the landing gear and attaching everything to the fuse stick. On the Bipe, you have to attach the top wing using the carbon struts. The manual gives good instructions on how to tape the hinges while ensuring you get maximum throw. This is done by putting tape along the rear trailing edge of the surface you are hinging. Turn the surface over so the sticky side of the tape is facing up, take the elevator, rudder or aileron with the beveled edge facing up and at a 45 degree angle place it up against the trailing edge of the surface you are hinging, and secure the tape. Turn it over, and fold the (elevator, rudder or aileron) back onto the surface and tape along the hinge line. You then can work the hinge and confirm that you are getting full throw. The landing gear is sandwiched between the balsa blocks.
It is important when sliding parts onto the fuse stick that you do them in the proper order and pay attention to when to glue parts together. The final assembly to the fuse stick on the Micro SSX Biplane: The servo tray and P12A are slid on the fuse stick first and then the tail mount, which is glued.
The lower wing and tail is added next, then the landing gear. The landing gear should be 2-1/32" from the front of the fuse stick. The top wing is then added, and it is very important that the carbon wing struts are fully inserted in the wing before gluing. Then we add the battery tray and motor mount.
The Micro SSX Biplane has an adjustable incidence. When making adjustments to the rear wing mount you just have to remove two screws. What a great idea!
For final assembly of the SSX, slide the servo mounts on the fuselage stick. Next, attach the wing through the front wing saddle and then slide the rear saddle on the wing and glue. Attach the tail, landing skid, landing gear, battery tray and motor mount. Attach the motor and radio gear to allow for balancing 1/8" to the rear of the main spar. You can adjust the position of the hardware to get CG, and if an adjustment is still needed you can move the wing. Once balanced, adjust the horizontal stab so that it is parallel with the wing, and then glue the wing saddles.
Biplane:
Micro SSX:
The first time I flew the Micro SSX was in James backyard over a lake. Apart from being a little nervous about putting it in the lake I was impressed with how well this little lightweight plane handled the 10-12 mph wind. The first flight of the Biplane was at a school track, and the takeoff roll was about fifteen feet. It could have been shorter, but the plane looked so nice once the tail came up that I let it roll a little further before lift off. Either plane can be airborne in less than ten feet. As I made my first pass with the Bipe, I was already thinking how cool a little mock dogfighting would be with two of these in the air at once. My first flight was cut short due to rain, but it was a blast to fly and easy to land. Flying weight and duration can vary a little depending on which size pack you decide to use. In the Biplane, a 3 cell 480 is a nice combination, and in the Micro SSX I like flying on a 2 cell 720. Both these packs weigh about the same. For props, I am using a GWS EP-7035 on the Biplane and a EP-6050 on the Micro SSX.
Take-Off and Landing
Both the Biplane and Micro SSX can be airborne in less than 10 feet and will take off from very short grass. Either can be hand launched as well. Either plane can land at a walking pace with the motor running or cut the throttle and glide to a nice landing. The Biplane really excels at this with its extra wing area. I experimented with a tail wheel on the Micro SSX, and since it is not a steerable tail wheel, I found that as the plane slows, there is not enough air flow around the rudder to allow it to steer. I have decided to stick with the tail skid.
Aerobatics/Special Flight Characteristics
Basic aerobatics are no problem at all for either of these planes. They also do spins and hammerheads quite well. Due to the lack of fuselage, knife edge is the one maneuver neither can really do. To me, the special flight characteristic of the Biplane is its slow speed and handling (great for fly-bys and touch and go's) while the Micro SSX is quite aerobatic and has the ability to handle a lot of wind. I have flown mine in 15 mph of wind without a problem. Both planes are quite happy to fly close and low to the ground, and as your comfort level grows, you will find yourself doing aerobatics lower and lower to the deck. Either plane should succeed in putting a smile on your face.
Is This Plane For A Beginner?
No. I would not recommend the Biplane or Micro SSX to a beginner as both can be quite nimble on the sticks. However, with the throws cut down, either one would be a good 2nd aileron plane.
Photo Gallery/Flight Video
The video and some of the pictures were shot at the Prop Busters RC club in Lakeland. James & Moe from Millennium RC were flying while I shot pictures and video. The video of the Micro SSX was shot in James backyard over the lake.
The Millennium RC Micro SSX Biplane and Micro SSX are nice looking and easy to build as far as kits go. Either would make a nice project for the first time builder or experienced builder alike. Don't plan to spend a lot of time building, as the lack of a full fuselage makes for a quick build. If the thought of building has you running for cover, Millennium has an ARF version for the Micro SSX and the possibility of an ARF version of the biplane in the future.
Pluses:
Minuses:
Thread Tools |
#2 |
War Eagle!
Great job with the review, sir! These definitely look like very fun planes and nicely designed, too. The little jig for adjusting the incidence sure is a neat trick.
I'm glad you're having fun with these planes the videos sure did show it. That was really funny about the dogfight "soundtrack," too!I thought they'd be gentler-flying machines, but they sure can zip along!
#3 |
rebel without a glue
Nice review! I enjoy my Micro SSX, which I bought as an ARF at NEAT last fall. The main thing I wish it could do better is fly slowly, and it looks like the biplane version is just the ticket for that. :-)
#4 |
Been There! Done That!
Great review! Well done! Really liked the videos.
boomer |
#5 |
I'm goo-goo over Ga-Ga
Great review....
I'm glad you really hammered the sticks,that's the way I would have flown 'em..the coolest was taking off as a biplane....You flew the snot out of it....then landing with both wings still attached.hey hey...
#6 |
Balsa just crashes better
Great review - two really cool planes
Looks like a bipe in my future
#7 |
On the fence
Very nice review Doc. I was thoroughly impressed with the micros I saw fly at Perry last weekend. Thanks
Bill |
#8 |
Freedom isn't Free,Thank a Vet
Thanks for the compliments, they both really fly well and it shows in the video.
#9 |
Thanks Doc, the review looks greate!
#10 |
Roll Tide!
Man, I finally got my hands on the micro-bipe..
I *had* to come home with one (and another SSX).. The bipe absolutely rocks.. Now to decide how to cover it.. ![]() Jeff www.CommonSenseRC.com |
#11 |
Embracing the Dark Side
Tram I picked up a Bipe at SEFF as well, can't wait to get started on it.
MLT |
#12 |
Just got home from SEFF
You guys will like the bipe |
#13 | |
Roll Tide!
Climb to some altitude.. Power out.. Full left rudder.. Full right aileron... Full down.. or bottom left corner mixed with a lil' top right corner.. ![]() The bipe rocks at this.. Top left corner.. Top right corner rocks too..
#14 |
I am "pilot Error"
can someone help me?
OK - I just finished my micro ssx bipe and m having some flight issues. When I open the throttle all the way up the plane pushes down, at half throttle it flies straight and level and then less throttle it tries to nose up a bit. everything appears to be true but it is not as stable as I had hoped - any suggestions would be greatly appreciated.
#15 | |
James |
| Thread Tools | |
| Discussion New Products from Millennium R/C! SSX ARF's! | Tram | Product Announcements | 0 | May 11, 2007 01:19 PM |
| Sold 2 KITS - Radical r/c Mini stick and Micro stick + motor and esc | MailOrderGuy | Aircraft - Electric - Airplanes (FS/W) | 3 | Nov 12, 2006 11:14 AM |
| Installing Micro R/C gear in a Flyzone Classic Biplane | Old Bag Lady Al | Indoor and Micro Models | 3 | Apr 25, 2005 03:20 PM |
| R/C equipment for micro sized boat | micro sailor | Dock Talk | 9 | Dec 28, 2004 07:55 AM |
| Does Anybody else here run r/c cars? Cool micro car | slowflyer | Electric Power Cars | 1 | Mar 05, 2002 09:59 AM |
