Old Dec 18, 2002, 09:14 AM
rakm is offline
Find More Posts by rakm
rakm's Avatar
Pensacola Regional, Florida, United States
Joined Jan 2002
Getting CG forward on a swept wing design
Home designed powered swept wing that flys very well. The only problem is I have to place the battery packs all the way to the rear to get the cg correct. What needs to be done in the design to get the battery packs forward? Do I need to increase the root cord? Reduce the sweep? Thanks for any help.
rakm is offline Find More Posts by rakm
Old Dec 18, 2002, 11:46 AM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
Reducing the sweep moves the c.g. and therefore the battery pack forward.
If changing the root chord reduces the sweep...
Adding a tail will move the c.g. forward also.
Sparky Paul is offline Find More Posts by Sparky Paul
Old Dec 18, 2002, 12:50 PM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
ER what?
First of all are the wings swept forward or back?
If you reduce sweepback, all other things being equal it will move the CG *back* with respect to the wing center of lift, at least. So although Sparky is right that the CG moves forward as sweepback is reduced, because some wing mass will move forward, its not going to do what you automatically think 'moving CG forward' would do. Thats because the wing is moving forward faster than the CG is, so to speak!!!
If the aircraft is nose heavy, reduce sweepback. Or add a tail!
Old Dec 18, 2002, 04:18 PM
rakm is offline
rakm's Avatar
Joined Jan 2002
The wings are swept back. Looks like a small Zagi (28 inch span). Thanks for the advice. It looks as though the answer is to reduce the sweepback. I'm assuming this will also reduce the stability as it's taking away some effective dihedral? Will try a few different angles and get the best trade-off. Right now it's very stable/forgiving and don't really want to loose that.
Old Dec 18, 2002, 06:55 PM
Sail 'n Soar is offline
Find More Posts by Sail 'n Soar
Cincinnati, OH
Joined Aug 2002
Better question is, "If it flys well now, why worry about the aft battery location?"
Sail 'n Soar is offline Find More Posts by Sail 'n Soar
Old Dec 22, 2002, 11:14 PM
exempt is offline
Find More Posts by exempt
exempt's Avatar
Providence, RI
Joined May 2001
I had almost the same problem with my home made Zagi style wing, but with mine it's tail heavy (i think) when I tried to launch it, it just did a backwards loop?? I dunno, I guess somethings wrong.
exempt is offline Find More Posts by exempt
Old Dec 23, 2002, 05:32 AM
Robbie d is offline
Find More Posts by Robbie d
Crazy Cessna Owner
Robbie d's Avatar
Australia, SA, Windsor Gardens
Joined May 2001
you can calculate the cg of any wing easily using nothing but a ruler and a pencil. First measure your root and tip chords.
The red lines on the diagram represent the root chord and the light blue lines are the tip chords. You draw the chord lines top and bottom. Then draw two intersecting lines (the dark blue ones) from the tip of each line and where they cross is the c of g.
Robbie d is offline Find More Posts by Robbie d
Old Dec 23, 2002, 11:03 AM
Ascended Master
Palmdale, CA
Joined Oct 2000
Not quite.
That procedure locates the mean aerodynamic chord.
You must then compute where the c.g. is on that chord, and project that location to the root chord.
