Old May 19, 2001, 05:49 PM
Steve Wrona is offline
Find More Posts by Steve Wrona
I am M I G H T Y !
Steve Wrona's Avatar
Ipswich, England
Joined Feb 2001
Batt charger as power/thermal source for hot wire foam wing cutting bow? - UK
I have a VERY basic batt charger that I bought when I bought with my LS to charge its batts. I have since moved on to bigger and more complex aspects of modeling. I am wondering if I may be able to successfully use my charger as a power/thermal source for a foam wing cutting bow. Also if anyone has any advice/ideas for the construction of such a bow and or wing profile templates it would be greatly appreciated!
Thanks!
Steve
"Keep it up!"
[This message has been edited by Steve_Wrona (edited 05-19-2001).]
Steve Wrona is offline Find More Posts by Steve Wrona
Old May 19, 2001, 10:07 PM
Larry Dudeck is offline
Find More Posts by Larry Dudeck
Larry Dudeck's Avatar
Williamsville, NY, USA
Joined Sep 2000
I have heard of using a battery with an ESC, rx and tx for cutting foam. The output of the ESC is connected to the bow. The amount of current, which will determine the temperature, is controlled by the throttle on the Tx.
Larry Dudeck is offline Find More Posts by Larry Dudeck
Old May 19, 2001, 10:58 PM
DeaninMilwaukee is offline
Find More Posts by DeaninMilwaukee
Motors beat engines!
Milwaukee Wisconsin, United States
Joined Feb 2001
I did that and it worked very well.
DeaninMilwaukee is offline Find More Posts by DeaninMilwaukee
Old Feb 29, 2004, 04:07 PM
Matt Chester is offline
Find More Posts by Matt Chester
Matt Chester's Avatar
Newnan, GA
Joined Oct 2002
What would you say the minimum ESC size should be? I may try this method to make a Red Herring.
Matt Chester is offline Find More Posts by Matt Chester
Best Wire for Hot Wire Foam Cutter andyg Foamies (Kits) 20 May 02, 2014 03:05 AM
Discussion will this work as a power suppy for a hot wire foam cutter NEWBIEHELI Foamies (Kits) 7 Jul 14, 2006 02:22 AM
Power Supply Transformer, for hot wire cutter, or flight pack charging Salin Electric Plane Talk 1 Aug 25, 2002 04:38 PM
Batt charger as a power/thermal source for foam cutter? - UK Steve Wrona Foamies (Kits) 2 May 19, 2001 02:58 PM
