This thread is privately moderated by GWS CHEN, who may elect to delete unwanted replies.
Old Dec 13, 2009, 11:46 AM
DominicM is offline
Find More Posts by DominicM
DominicM
DominicM's Avatar
Fleet, Hampshire, UK.
Joined May 2003
Having the canards working is fundamental to the model flying well. I would not try them fixed unless you can be sure to get a very rear CG which you might be able to do if you don't have the canard servos. Wouldn't do it though. Kinda defeats the point of buying this model.
DominicM is offline Find More Posts by DominicM
Old Dec 13, 2009, 04:03 PM
cray2602 is offline
Find More Posts by cray2602
Fan-atic
cray2602's Avatar
Plain ole KS
Nah, it will fly fine with the canards fixed. Many people have allready flown it that way. I agree though it would take away from the cool factor of this model. But if i was building it as a bullet ship i would fix them rigid and save weight.
cray2602 is offline Find More Posts by cray2602
Old Dec 13, 2009, 04:56 PM
Tarro is offline
Find More Posts by Tarro
Long Island, New York
Joined Jun 2008
What batteries are you guys flying with, I flew my J10 today with a 3s 4400 pack and it flew awesome.
Tarro is offline Find More Posts by Tarro
Reply With Quote  (Disabled)
Old Dec 13, 2009, 06:24 PM
cray2602 is offline
Fan-atic
cray2602's Avatar
Plain ole KS
I fly on a 2200mah 3s to keep it light. I have used a 3300mah 3s but performance isnt quite as good with the extra weight at least for me.
Old Dec 21, 2009, 04:48 AM
Metallica2000 is offline
Find More Posts by Metallica2000
Campinas - Sao Paulo - Brazil
Joined Jul 2008
Thanks So much "braden conza", you save my J10...hehehhee Finally this plane cross my brazilian air space!
Metallica2000 is offline Find More Posts by Metallica2000
Old Dec 23, 2009, 07:09 PM
InvalidUsername is offline
Find More Posts by InvalidUsername
RC = Empty wallet
InvalidUsername's Avatar
Australia, VIC, Melbourne
Joined Jan 2005
Your welcome, glad I could help!
Photos of my j-10. Working canards(seperate servos), rudder, nose steering, ailerons. 2650mah 4s lipo, Airpower 70mm edf. Motor still to come. Complete with 2 pilots!
InvalidUsername is offline Find More Posts by InvalidUsername
Old Dec 23, 2009, 07:24 PM
Tarro is offline
Joined Jun 2008
How long are your flight times with a 2200mah?
Old Dec 23, 2009, 08:12 PM
cray2602 is offline
Fan-atic
cray2602's Avatar
Plain ole KS
About 3 minutes maybe 4 minutes absolute tops. Im running the stock fan with 6 blade rotor and a 3800kv outrunner, a decent 70mm fan setup is the best option for this jet. 600 watts will fly this jet well.
Old Dec 23, 2009, 08:16 PM
Tarro is offline
Joined Jun 2008
I am running an HET 2w motor in an HET 6904 fan, it flys awesome and with a 4400 lasts over 7 minutes.
Old Dec 23, 2009, 11:06 PM
chewytm is offline
Find More Posts by chewytm
Ipoh, Perak Malaysia
Joined Jul 2006
Tarro,
How did you manage to stick a 4400 in there? Or is it 2x2200 laid length-wise? If so, how's the cg? does it fly nose heavy?
chewy
chewytm is offline Find More Posts by chewytm
Old Dec 24, 2009, 03:31 AM
Tarro is offline
Joined Jun 2008
Originally Posted by chewytm View Post
Tarro,
chewy
I widened the bay with a soldering iron and placed it in flat, it fits fine, balances perfectly and handles the weight without a problem. I love the way my J-10 flies and with a 4400 battery I don't worry about running out of juice early. I picked up 5 4400 packes from Hobby City for $21.21 each, if you can believe that?
http://www.hobbycity.com/hobbycity/s...idProduct=6504
Old Dec 24, 2009, 04:07 AM
chewytm is offline
Joined Jul 2006
Tarro,
Are you running 3S or 4S?
chewy
Oops, nevermind, you answered it with your link
Old Apr 02, 2010, 09:43 PM
AlouetteIII is offline
Find More Posts by AlouetteIII
AlouetteIII's Avatar
near the Beach
Joined Sep 2007
Each to his own, moving canards - or fixed. Personally I have installed them into quite a few Deltas including the Haoye J-10 and find they do add a little bit of an edge at high alpha recovery but generally have a minor effect like a 1/4 compared to the elevons. By setting the canards to be switch selectable, I found I could fly with them both on and off and compare. Having done that, I agree with CRAY, and now building my GWS j-10 with fixed canards. Also closing the bottom cheater hole to preserve the high pressure zone under the wing and adding two top/read/side cheaters similar to the Guai tigershark delta which is a very fast EDF on low power. How thin are these wing tips and fragile too - and the sharp leading edges? The Haoye wing is fantastic in the air and has a more conventional rounded leading edge, thicker - maybe i'll add a sheet of depron on the underside which needs cleaning up and shape these GWS j-10 wing tips properly. Love the 2 pilot canopy - nice work GWS!
AlouetteIII is offline Find More Posts by AlouetteIII
Site Sponsor
Old Apr 02, 2010, 09:52 PM
cray2602 is offline
Fan-atic
cray2602's Avatar
Plain ole KS
The wing tips are very thin and fragile. Mine tipped onto a wing while slowing down after landing and it ground about 3/4" off the wing tip. I then moved the rear gear farther aft and outwards a bit to prevent it from tipping any more. Im surprised this model isnt more popular. You can buy it A/F only and build it any way you like, tons of options for power setups.
Old Apr 02, 2010, 10:31 PM
near the Beach
Joined Sep 2007
Hey Cray - Artech had some good ideas (not many) and one of them was hard plastic molded wing tips on their little SU-27. Took all the minor tip scrapping and saved the wings. If you were going to sell paper thin wings GWS maybe supply a plastic part in V2 which is molded to fit over the leading edge and wing tip?
Site Sponsor
Discussion GWS 262 EDF Jet GWS4CEO Foamy EDFs 14 Aug 03, 2008 08:28 AM
Cool Chinese J-10(Depron foam) picture & video aero-dreamworks Parkflyers 12 Aug 02, 2008 07:48 AM
Discussion Chinese J-10 aero-dreamworks Pusher Prop Jet Models 17 Jan 03, 2008 06:07 AM
Sold Good old Vet GWS A-10 twin EDF jet fighter bomber with 2 servos shschon Aircraft - Electric - Jets (FS/W) 3 Nov 24, 2006 02:26 PM
New to EDF - Opinions please! Best handlaunch parkflyer sized EDF jet model StahlmanGC Electric Ducted Fan Jet Talk 7 Aug 19, 2004 07:21 PM
