This thread is privately moderated by GWS CHEN, who may elect to delete unwanted replies.
Old Jan 24, 2009, 10:07 PM
GWS4CEO is offline
Find More Posts by GWS4CEO
Houng-wen Lin
GWS4CEO's Avatar
Shijr, Taiwan. DungGwan, China. City of Industry, California.
Joined Sep 2001
A new out runner BL motor come with 24.5mm core for EDF75 at 3800KV will samples production in small qty.
This motor had proved pefect match with GWS J-10 performance very well.
Detail will be posted as soon as possible when avalible datas measured. However, GWS China is on the Chinese New Year long vocation.
GWS4CEO is offline Find More Posts by GWS4CEO
Old Jan 24, 2009, 10:18 PM
GWS4CEO is offline
Houng-wen Lin
GWS4CEO's Avatar
Joined Sep 2001
Tommy Lai of GWS had tested this combination.
He said that will make GWS J-10 even more speedy than most inrunner BL motors!
Old Jan 24, 2009, 10:24 PM
Tram is offline
Find More Posts by Tram
Fly it like you stole it..
Tram's Avatar
Florence, Al
Joined Oct 2000
Speedy... is... good...
Tram is offline Find More Posts by Tram
Latest blog entry: Wow.. 3 years..
Old Jan 25, 2009, 07:39 AM
chewytm is offline
Find More Posts by chewytm
Ipoh, Perak Malaysia
Joined Jul 2006
Mr. Lin, the problem is with the q.c. Has that been fixed?
chewy
chewytm is offline Find More Posts by chewytm
Old Feb 07, 2009, 12:59 PM
herk1 is offline
Find More Posts by herk1
Trash Hauler emeritus
herk1's Avatar
Maryland, USA
Joined Oct 2006
I maidened my J-10 (pusher-prop powered) this morning. Report here. This plane flies wonderfully...another fantastic job by the plane designers at GWS!
herk1 is offline Find More Posts by herk1
Old Feb 07, 2009, 04:06 PM
GWS4CEO is offline
Houng-wen Lin
GWS4CEO's Avatar
Joined Sep 2001
Thanks to Spackles94 did such a great job for test and writting this GWS J-10 review.
http://www.rcgroups.com/forums/showt...4#post11529864
Also thanks to herk1 did such a great job for test and writting this GWS J-10 review of another pusher version..
http://www.rcgroups.com/forums/showt...7#post11529878
Old Feb 07, 2009, 06:37 PM
GWS4CEO is offline
Houng-wen Lin
GWS4CEO's Avatar
Joined Sep 2001
chewy
We keep trying to be better.
I had cuson in law back to Taiwan from Brazil. He told me that he lost a lot of money when import made in China products.
GWS China QC manager was from Taiwan, yet he had long years experience teaching China QC staffs.
Sorry, if any miss from GWS China caused your inconvenience.
Old Feb 24, 2009, 02:52 PM
cray2602 is offline
Find More Posts by cray2602
Fan-atic
cray2602's Avatar
Plain ole KS
Whats the latest word on the new motor? Any idea when it will be available? I have been looking for an outrunner in the 3800kv~4000kv range that will fit my GWS 75mm fan.
cray2602 is offline Find More Posts by cray2602
Old Mar 13, 2009, 11:46 AM
GWS4CEO is offline
Houng-wen Lin
GWS4CEO's Avatar
Joined Sep 2001
The new out runner sample for EDF75 was sent to an RC flyer in USA to make test report.
Hope that we can see his review soon.
Old Mar 25, 2009, 10:51 PM
cray2602 is offline
Fan-atic
cray2602's Avatar
Plain ole KS
Here is a thread i posted in the Foamy EDF forum. Thought i should post it here as well.
I got my hands on a prototype GWS 3800kv outrunner motor designed for the 75mm fan for the J-10 and or A-4. Nice looking motor. I dont have any specs on the motor other than the amp draw that i recorded. I will see if i can get some more technical info on the motor to post here.
3s lipo -
GWS 75mm stock 4-blade fan = 46 amps
GWS 75mm 6-blade fan = 43 amps
I was told this motor may or may not be able to handle a 4s lipo. Aparently it hasnt been tested on 4s yet and i dont have a large enough 4s to find out.
I went for a maiden flight on the new motor today with my J-10 and almost had a catastrophy. I lined up on the runway and pinned the throttle, the plane took off like a catapult launch, it was impressive. The instant i pulled back on the stick to send her skywards i heard a loud POW and the fan sound went from a smooth scream to a very loud resonateing vibration. The nose wheel kicked up a piece of gravel and it went right into the fan just as i rotated to climb. I should have known that it would happen sooner or later with a large cheater hole in the bottom as the runway i use is littered with some gravel here and there. But even with only 2 blades left on the stock 4-blade fan i was able to limp the plane back around and safely land it on the runway.
So no flight report yet. I can say that the static thrust seems very good. One thing worth mentioning - i am useing a CC Thunderbird 54amp ESC on my setup and the motor wants to stutter when starting up from a dead stop. I have noticed this same problem when useing some very aggresive motors on cheap ESC's. The problem isnt the motor, its the ESC's startup sequence as it tries to sense the location of the magnets from what i have learned in past experiences. A good quality ESC usually solves this strange dilema although ive never seen this happen on my Thunderbird ESC's before.
I have installed the 6-blade rotor and a wire mesh cover for the cheater hole. When weather permits i will get a flight report and hopefully video posted.
Old Mar 26, 2009, 02:04 AM
DominicM is offline
Find More Posts by DominicM
DominicM
DominicM's Avatar
Fleet, Hampshire, UK.
Joined May 2003
Just make sure your wire mesh doesn' go through the fan...it wouldn't like that much either
Good to see this thread still going strong. I've just resurrected my J10 and will be running a 3 blade HET fan and Hoffman Magnetics 'Wild Beast' on 3S in it. Have also added horizontal and vertical thrust vectoring paddles in the thrust tube to try to get some real high alpha moves.
DominicM is offline Find More Posts by DominicM
Old Mar 26, 2009, 04:06 AM
chewytm is offline
Joined Jul 2006
Could you please show some details of how you added, including the linkages
chewy
Old Mar 26, 2009, 04:42 AM
GWS CHEN is offline
Find More Posts by GWS CHEN
Taipei, Taiwan
Joined Oct 2005
Hi Cray,
Thank you very much for this initial report. My colleague told me the same as what you said, this's a very powerful motor. I'd expect to read a detailed one, but be sure to clear your runway well next time. Thank you again.
Chen
GWS CHEN is offline Find More Posts by GWS CHEN
Old Mar 26, 2009, 06:00 AM
Tarro is offline
Find More Posts by Tarro
Long Island, New York
Joined Jun 2008
Originally Posted by GWS CHEN
Hi Cray,
Chen
Mr. Chen,
Will this motor handle a 4s pack?
Tarro is offline Find More Posts by Tarro
Reply With Quote  (Disabled)
Old Mar 26, 2009, 08:50 AM
chewytm is offline
Joined Jul 2006
Originally Posted by Tarro
Mr. Chen,
Check this out: 3-4S up to 1700watts
http://www.hoffmanmagnetics.com/
chewy
Discussion GWS 262 EDF Jet GWS4CEO Foamy EDFs 14 Aug 03, 2008 08:28 AM
Cool Chinese J-10(Depron foam) picture & video aero-dreamworks Parkflyers 12 Aug 02, 2008 07:48 AM
Discussion Chinese J-10 aero-dreamworks Pusher Prop Jet Models 17 Jan 03, 2008 06:07 AM
Sold Good old Vet GWS A-10 twin EDF jet fighter bomber with 2 servos shschon Aircraft - Electric - Jets (FS/W) 3 Nov 24, 2006 02:26 PM
New to EDF - Opinions please! Best handlaunch parkflyer sized EDF jet model StahlmanGC Electric Ducted Fan Jet Talk 7 Aug 19, 2004 07:21 PM
