This thread is privately moderated by GWS CHEN, who may elect to delete unwanted replies.
Old Jan 05, 2008, 02:20 PM
L0stS0ul is offline
Find More Posts by L0stS0ul
Ship first, Improve often
L0stS0ul's Avatar
Virginia
Joined Apr 2005
Originally Posted by ParkJeff
Do you mean the canards move opposite of elevator direction? Can't imagine elevator would be reversed.
It really depends on how the user will program the plane. I would put the majority of the elevator control on the canards which must function opposite of normal elevator. I would then probably provide a small amount of elevon mixing for elevator on the ailerons. I would not think you would need much elevator action on the ailerons as those canards look quite large and should provide a lot of control as is. Elevator on the ailerons would be mixed like standard elevators.
L0stS0ul is offline Find More Posts by L0stS0ul
Old Jan 05, 2008, 03:38 PM
sebsoupe is offline
Find More Posts by sebsoupe
sebsoupe's Avatar
Bourg-en-Bresse, FRANCE
Joined Mar 2005
Originally Posted by GWS CHEN
Here is the new GWS-J10 EDF jethttp://tw.video.yahoo.com/video/play?vid=1380040
Itís a lighter EDF jet comparing to another same size ones. It flies fast and with more aerobatics in the air by controlling the elevon and the front stabilizer.
Hello!
the Multiplex Twister got almost the same Specification (and he's made of Elapor, a foam like EPP or EPO ) :
Wingspan 850 mm
Overall fuselage length 1115 mm
All-up weight (with 2500 mAh battery) approx. 880 g
Wing area approx. 25.5 dm≤
Wing loading (FAI) min. approx. 31 g/dm≤
impeller DF 69 with Himax A2825-3600
RC functions Elevator, aileron and motor
and in this video, the MPX Twister flies almost better than th J10...
Twister Jet von Multiplex (1 min 57 sec)
sebsoupe is offline Find More Posts by sebsoupe
Old Jan 06, 2008, 03:04 AM
sebsoupe is offline
sebsoupe's Avatar
Joined Mar 2005
Amp drawn : 36A max with the oldest orange rotor
Thrust output: 660g max with the oldest orange rotor
"GWAEO030B" is for GWS J-10 EDF75-BL2815-2 white.
Hello Chen,
are you talking about the GWBLM005C Inrunner BL Motor 2028 Yellow kV2300 ???
Bye,
sebsoupe
Old Jan 06, 2008, 07:11 AM
ParkJeff is offline
Find More Posts by ParkJeff
Birds do it, bees do it
ParkJeff's Avatar
Australia, WA, Perth
Joined Feb 2003
Yes, but it's not a delta with canards ala Eurofighter.
ParkJeff is offline Find More Posts by ParkJeff
Old Jan 06, 2008, 07:59 AM
GWS CHEN is offline
Find More Posts by GWS CHEN
Taipei, Taiwan
Joined Oct 2005
Hi Sebsoupe,
I'm afraid that these two J-10's flew faster,
http://tw.video.yahoo.com/video/play?vid=1506805
they were with their landing gears,and all powered by the stock motor GWBLM009 BL2815 (red) KV3700-3800. http://www.gwsus.com/english/product/motor/gwblm009.htm
Chen
GWS CHEN is offline Find More Posts by GWS CHEN
Old Jan 06, 2008, 08:55 AM
FresnoJay is offline
Find More Posts by FresnoJay
To drive or to fly......BOTH!!
FresnoJay's Avatar
USA, CA, Clovis
Joined Apr 2007
That one with the blue paint sounded like it was about to explode trying to stay airborne. While the all grey one sounded like it had no problems at all and seemed faster with alot less noise. Is it just me?
Jason
FresnoJay is offline Find More Posts by FresnoJay
Old Jan 06, 2008, 01:31 PM
kensp is offline
Find More Posts by kensp
kensp's Avatar
Darwin Australia
Joined May 2002
Hi Sebsoupe,
Chen
Chen
What is the kV of the GWBLM009 BL2815-2 (white).
The quoted figure of 30 Amps for the GWBLM009 BL2815-2 (red) agrees with my preliminary test data of 30 amps at 31,600 RPM when the old style four bladed EDF-75 fan was used.
Ken
kensp is offline Find More Posts by kensp
Old Jan 06, 2008, 02:26 PM
skyhawk is offline
Find More Posts by skyhawk
A-4 nut!!
skyhawk's Avatar
Vancouver B.C.
Joined Apr 2002
Chen,
Is this the motor that came with the A-4 EB's?
Why is the amps lower?
skyhawk is offline Find More Posts by skyhawk
Old Jan 06, 2008, 02:31 PM
crxmanpat is offline
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Chen/Mr Lin,
When do you expect to send EB kits out? Are you sending to Taiwan first to keep EMS costs down?
Pat
crxmanpat is offline Find More Posts by crxmanpat
Old Jan 06, 2008, 09:30 PM
GWS CHEN is offline
Taipei, Taiwan
Joined Oct 2005
Hi Ken, skyhwak & Pat,
EB kits will be shipped out from GWS China directly. My colleagues are further testing the new batch of the motor, same BL2815-2 (red). I've been told that the new BL2815-2 (red) could power EDF75 better, generate more thrust but less Amps drawn. All J-10 kits will be with this new motor and the upgraded impeller/rotor.
The video two J-10's were all powered by the motor of the first batch one + 3S 11.1V 25C 2000 mAH Lipo pack. The motor was the same as EB A-4 ones. The EDF rotors were the old orange ones.
Ken, yours was the same from the first batch one, still with red shrunk tube. Their KV value were between 3700 - 3800.
Chen
Old Jan 06, 2008, 09:50 PM
chewytm is offline
Find More Posts by chewytm
Ipoh, Perak Malaysia
Joined Jul 2006
Chen
Goody! Better is always, of course, better! . Can I use 4S if I add a heat sink with some extra slots ground on the sides of the stator/motor shroud to provide additional cooling for the motor?
chewy
[EDIT] Btw, you did not answer when they are scheduled to be shipped out. I hope we get them long before your ship arrives at the US shores. Otherwise, it sorta defeat the purpose of being early birds, doesn't it?
chewytm is offline Find More Posts by chewytm
Old Jan 06, 2008, 10:17 PM
GWS CHEN is offline
Taipei, Taiwan
Joined Oct 2005
It'd be much much better to use 3S Lipo with this motor when powering EDF75. My colleagues at GWS China will try to ship out EB kits earlier.
Chen
Old Jan 06, 2008, 10:47 PM
kensp is offline
kensp's Avatar
Darwin Australia
Joined May 2002
Chen
Chen
I measured a kV of 3711 on the sample you sent to me. I am still waiting on a 2250 mAh 25 C battery pack and a 40 Amp ESC to continue testing. The Christmas break has caused mail delays.
I have run this motor using a 7 x 3.5 three blade propeller and two cells but my 25 Amp ESC goes into protection mode shut down at around 27 Amps.
Ken
Old Jan 06, 2008, 10:57 PM
Bill Covert is offline
Find More Posts by Bill Covert
Bill Covert's Avatar
Grove City, PA
Joined Sep 2007
Yep, I was thinking maybe we should compare the J10 with the Wright Flyer too, while we're doing these
similar comparisons.
Bill Covert is offline Find More Posts by Bill Covert
Old Jan 07, 2008, 02:09 PM
sebsoupe is offline
sebsoupe's Avatar
Joined Mar 2005
I agree
it was just a comparison between 2 planes of similar size and motorization
Discussion GWS 262 EDF Jet GWS4CEO Foamy EDFs 14 Aug 03, 2008 08:28 AM
Cool Chinese J-10(Depron foam) picture & video aero-dreamworks Parkflyers 12 Aug 02, 2008 07:48 AM
Discussion Chinese J-10 aero-dreamworks Pusher Prop Jet Models 17 Jan 03, 2008 06:07 AM
Sold Good old Vet GWS A-10 twin EDF jet fighter bomber with 2 servos shschon Aircraft - Electric - Jets (FS/W) 3 Nov 24, 2006 02:26 PM
New to EDF - Opinions please! Best handlaunch parkflyer sized EDF jet model StahlmanGC Electric Ducted Fan Jet Talk 7 Aug 19, 2004 07:21 PM
