This thread is privately moderated by GWS CHEN, who may elect to delete unwanted replies.
Old Jan 27, 2008, 01:29 AM
ajreynolds is offline
Find More Posts by ajreynolds
I need a bigger garage...
ajreynolds's Avatar
USA, CA, San Diego
Joined Mar 2005
Chewy,
I see you're looking for pilots. Check out the ones from Dare Design at http://www.darehobby.com/accessories/pilots.htm. The small ones #1005-13 look about right in the A-4. See them in Skyhawk's A-4 at http://www.rcgroups.com/forums/attac...mentid=1638516. If the J-10 is about the same scale, they should go good there too.
Andy
ajreynolds is offline Find More Posts by ajreynolds
Old Jan 27, 2008, 09:11 AM
GWS4CEO is offline
Find More Posts by GWS4CEO
Houng-wen Lin
GWS4CEO's Avatar
Shijr, Taiwan. DungGwan, China. City of Industry, California.
Joined Sep 2001
The more of flyers take off GWS J-10, you will realize that you worry to much of not enough power!
A little more than 300+g, you can keep her flew level.
GWS4CEO is offline Find More Posts by GWS4CEO
Old Jan 27, 2008, 09:53 AM
chewytm is offline
Find More Posts by chewytm
Ipoh, Perak Malaysia
Joined Jul 2006
Originally Posted by ajreynolds
Chewy,
Andy
aj,
thanks for the thread. Just recruited 6 new pilots from there Hopefully, they are fully trained and ready to take action when they arrive.
chewy
chewytm is offline Find More Posts by chewytm
Old Jan 27, 2008, 10:19 AM
chewytm is offline
Joined Jul 2006
Just ordered 2 new 2500mAH 25C 3S lipos from UH to go with the J-10. Hopefully, I won't have to carve out too much of the fuse innards. The flight times was rather short with the 2250mAH 25C. Also ordered 2x1800mAH 25C 3S and may use this as 3s2p instead. Have to wait to see how it balances.
chewy
Old Jan 27, 2008, 10:38 AM
GWS CHEN is offline
Find More Posts by GWS CHEN
Taipei, Taiwan
Joined Oct 2005
Chewy,
Congratulations for the maiden !
Have you used an ESC with more than 55A rating ? And it'd be much better NOT to use 4S with this motor on EDF75.
Chen
GWS CHEN is offline Find More Posts by GWS CHEN
Old Jan 27, 2008, 11:28 AM
ajreynolds's Avatar
USA, CA, San Diego
Joined Mar 2005
Has anybody got video of their J-10 yet?
Andy
Old Jan 27, 2008, 11:38 AM
GWS4CEO is offline
Houng-wen Lin
GWS4CEO's Avatar
Joined Sep 2001
You MUST not to use a 4s pack on GWS 2815 RED!!!
Originally Posted by GWS CHEN
Chewy,
Chen
I guess that I should not use "suggest" you....
I should say: You MUST not to...
Old Jan 27, 2008, 11:42 AM
GWS4CEO is offline
Houng-wen Lin
GWS4CEO's Avatar
Joined Sep 2001
Andy
I also expect to see how you guys did.
Although that we had many sucess flights in Taiwan.
Old Jan 27, 2008, 04:25 PM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
More details on my air retract installation here
http://www.rcgroups.com/forums/showt...=799819&pp=100
and here
http://www.rcgroups.com/forums/showthread.php?t=808977
They seem to work - kinda
J-10 after maiden last weekend:
Herb is offline Find More Posts by Herb
Old Jan 27, 2008, 11:36 PM
Jcopter is offline
Find More Posts by Jcopter
Jcopter's Avatar
United States, CA, Downey
Joined Jun 2005
While looking thru the Instructions I noticed there is a servo extention that is supost to go in between the two side fuse halfs and it shows two servos on the bottom (in an Illustration) and nothing about them any where else? what are they fore Got any Ideas IE. Retracts Etc. Also there seems to be a hardpoint for placement of Tanks, Bombs and or Missles is GWS going to make a set for this? it just screams for some, or do I have to make them my self.
Jcopter
Jcopter is offline Find More Posts by Jcopter
Old Jan 28, 2008, 12:25 AM
GWS CHEN is offline
Taipei, Taiwan
Joined Oct 2005
Jcopter,
The retract, tank, bombs and missles were not mentioned by the manual. I'm afraid that you have to work on them if you'd like to add any one of them on it.
There're 3 pages illustrated the two servos on its bottom, P.10 one mentioned the servos used on operating aileron and nose gear, the other two pages mentioned the servos used on the canards. You could use one single servo to operate the canards.
Chen
Old Jan 28, 2008, 01:03 AM
Jcopter is offline
Jcopter's Avatar
Joined Jun 2005
Hey GWS Chen Ya I Know that retract, tank, bombs and missles are not In the manual I was wondering if GWS was planning to make a Bomb/Missle set? Maybe a misunderstanding, I would Like to see one. I can make myown, but much easer if GWS had one available as an ad on.
As to the Servos on the bottom see pg 4 #1.5 (31 servo extention wire W26/30) What does it go to? it says nose gear servo Is that where it goes? on the next pg. it shows cutout for two servo positions also on Pg.10 #7.7 I see two servos in the Illustration and no linkage to anything this is not clear.
If this is for the nose gear servo why not show the linkage setup in section 5 Landing gear Assembly, as this is where it shows to install the Gear and no mention as to servo placement and linkage. I thought it mite have went inside the canope area?
Also when do you expect the new rotors to be in the USA?
Jcopter
Old Jan 28, 2008, 01:19 AM
chewytm is offline
Joined Jul 2006
Chewy,
Chen
Thank you. The esc I used was a HXT 80A with a separate 3A BEC. I might try the 4S one day, but not soon. Maybe some braver soul will try it first.
chewy
Old Jan 28, 2008, 02:06 AM
GWS CHEN is offline
Taipei, Taiwan
Joined Oct 2005
Chewy,
Forget this crazy idea if you care about your budget.
Chen
Old Jan 28, 2008, 04:43 AM
GWS CHEN is offline
Taipei, Taiwan
Joined Oct 2005
Jcopter,
I'm afraid that my colleagues at R&D are working more at new airplanes and another projects. It seems that they do not have enough hours spending on these add-on items including telling how to install the retract. Well, GWS new retracts have been released http://www.gwsus.com/english/dealer/dealer.htm http://www.gwsus.com/english/product...gear_rg-mn.htm
Be reminded page 4, 1.5 was telling the nose gear servo to be installed on the bottom and how to insert its extension leads which to be connected with receiver. Page 8 did tell how to install the nose gear. I'm sure you know how to connect the servo arm and the steering arm of nose gear.
Page 10 did illustrate the locations of nose gear servo and aileron servos clearly, and the linkage between aileron servos and ailerons. Page 11 did tell how to connect all servos with receiver and battery pack, and mixer or delta wing function as well.
Chen
Discussion GWS 262 EDF Jet GWS4CEO Foamy EDFs 14 Aug 03, 2008 08:28 AM
Cool Chinese J-10(Depron foam) picture & video aero-dreamworks Parkflyers 12 Aug 02, 2008 07:48 AM
Discussion Chinese J-10 aero-dreamworks Pusher Prop Jet Models 17 Jan 03, 2008 06:07 AM
Sold Good old Vet GWS A-10 twin EDF jet fighter bomber with 2 servos shschon Aircraft - Electric - Jets (FS/W) 3 Nov 24, 2006 02:26 PM
New to EDF - Opinions please! Best handlaunch parkflyer sized EDF jet model StahlmanGC Electric Ducted Fan Jet Talk 7 Aug 19, 2004 07:21 PM
