This thread is privately moderated by GWS CHEN, who may elect to delete unwanted replies.
Old Jan 25, 2008, 02:36 AM
GWS CHEN is offline
Find More Posts by GWS CHEN
Taipei, Taiwan
Joined Oct 2005
blueplane,
I was talking about the new motor GWBLM009A which came with EB J-10. It works great with EDF75 at 11.1V. But it's impossible to make 2000 watts on this setup.
Chen
edit: spelling
GWS CHEN is offline Find More Posts by GWS CHEN
Old Jan 25, 2008, 04:16 AM
kensp is online now
Find More Posts by kensp
kensp's Avatar
Darwin Australia
Joined May 2002
[QUOTE=latinflyer]
Originally Posted by kensp
I did by hand, slowly but sure and it works fine, no woble and it fits snug.
I won't say that you need any machining.
I have the 2.5 turn and it gives me 250W using a 2200MAH 25C TP.
Latinflyer.
The new GWS motor supplied with my Early Bird J-10 Drew 44.2 Amps at 11.2 volts and this is 495 watts.The battery used was a Loong Max 2250 mAh 25 C 3 cell pack.
Ken
kensp is online now Find More Posts by kensp
Old Jan 25, 2008, 05:12 AM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
please supply RPM for the fan at the given voltage, if everyone can post RPM and the voltage/amperage it was taken at we can get an idea of how well each fan is running and create a baseline.
Extreme_RC is offline Find More Posts by Extreme_RC
Old Jan 25, 2008, 05:34 AM
kensp is online now
kensp's Avatar
Darwin Australia
Joined May 2002
Extreme
Once I get my new 60 Amp ESC I will be able to make more runs to get RPM readings. I expect the new ESC to arrive early next week.
Ken
Old Jan 25, 2008, 07:02 AM
ParkJeff is online now
Find More Posts by ParkJeff
Birds do it, bees do it
ParkJeff's Avatar
Australia, WA, Perth
Joined Feb 2003
Originally Posted by Herb
I might fly it this weekend.
Herb,
Thanks very much for the information.
Have a good maiden. Looking forward to hearing about how it goes.
Jeff
ParkJeff is online now Find More Posts by ParkJeff
Old Jan 25, 2008, 10:31 AM
kensp is online now
kensp's Avatar
Darwin Australia
Joined May 2002
Extreme
Ken
GWS4CEO is offline
Find More Posts by GWS4CEO
Houng-wen Lin
GWS4CEO's Avatar
Shijr, Taiwan. DungGwan, China. City of Industry, California.
Joined Sep 2001
No matter how others said, pretty soon that you will find out that you should take off her without too worry!
With any GWS motor, you can take off from ground!
GWS4CEO is offline Find More Posts by GWS4CEO
Old Jan 25, 2008, 01:40 PM
blueplane is offline
Find More Posts by blueplane
Joined Sep 2007
Sorry for not answering the questions on my J-10 posed earlier
http://www.rcgroups.com/forums/showp...&postcount=208
- I haven't checked here in a while (busy).
Re the various questions posed earlier, I am using a set of airpower micro-retracts. The kinda work, but one leg was not going up down smooth, an air cilinder exploded so had to be re-glued and the airtank has two leaks at 80 psi. Other than that they work fine . I am waiting for replacements.
All the surfaces and most of the fuse is covered in silkspan, applied with elmers white glue. Paints are tamiya water based acrylics.
I am using a WeMoTec MiniFan 480 because that's what I had. The Het fan might work too. The HW-609 uses a 36mm motor so that will make the J-10 heavy as a lead brick. The MF480 is good to 1000+ Watts. I think this plane is very light and should fly very well on 400+ Watts.
I managed to get the CG right (as per instructions) by moving the fan something like 2 inches back (see my pictures above). So I don't need any lead in the tail. My weight rtf is 47.5 oz. Power wot is around 850W but I plan to mostly just cruise around at 1/3-rd throttle.
I had to do major canopy work to get all my applieances to fit . I also spent some time programming the radio (Fut 9C s) and the canard mixing. I think the aileron and canard throws in the instructions look like way too much, at least for the first flight.
Hi Herb,
Thanks for your advice.
Mine will be a bit lighter than yours because
I do not use the retracts.
blueplane is offline Find More Posts by blueplane
Old Jan 25, 2008, 05:24 PM
usmc_VTOL_mech is offline
Find More Posts by usmc_VTOL_mech
hotrod builder
usmc_VTOL_mech's Avatar
United States, TX, Arlington
Joined Jun 2007
I just finished mine
What a cool kit
and the Canards are awesome to see working
usmc_VTOL_mech is offline Find More Posts by usmc_VTOL_mech
Old Jan 25, 2008, 06:58 PM
300s is offline
Find More Posts by 300s
Captured RAF FW - 190
300s's Avatar
Worcestershire, UK
Joined Nov 2006
Nice looking example
300s is offline Find More Posts by 300s
Old Jan 26, 2008, 01:18 AM
sigma_fr is offline
Find More Posts by sigma_fr
julius
sigma_fr's Avatar
Grenoble france
Joined Jul 2005
Good job !
Any one have some flight video ?
Julien
sigma_fr is offline Find More Posts by sigma_fr
Old Jan 26, 2008, 08:13 PM
hotrod builder
Joined Jun 2007
I keep trying for a maiden but it has been constant rain here in socal
Could have done it today but had to work and afterwards it was kinda windy and I counted 15 + aircraft in the air at my flying field
I'll wait a bit longer
Thanks for the compliments
This plane looks great and is definately an attention getter
Old Jan 26, 2008, 08:49 PM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Rain what rain ??
I maidened mine today, the nosegear tended to dug into the mud, so I handlaunched. It flew fine, it was a tad nosehavy and needed a couple of clicks of up. I had hoped it would be a bit faster with 800+W . It lands nicely.
Herb is offline Find More Posts by Herb
Old Jan 26, 2008, 09:16 PM
hotrod builder
Joined Jun 2007
Herb
Was nice today the whole time I was at work
Of course when I got off the clouds started moving in again and Apollo field was a MADHOUSE as usual on the weekends
Maybe tommorrow evening or later this week
Old Jan 27, 2008, 01:15 AM
chewytm is offline
Find More Posts by chewytm
Ipoh, Perak Malaysia
Joined Jul 2006
Hi all,
I had the maiden flight today. It flew well, although not particularly fast I am using the stock fan/motor with a 2250mAH 25C 3S lipo. I was hoping to use the 3300 mAH 3S 20C but it was too big and too heavy. As it is, the cg is right where the manual says (80mm+/-). No uptrim was needed and just a few clicks of left trim.
I had the canard coupled to both the elevator and ailerons. it follows the elevon movements except in reverse for elevator movements. The test pilot who flew it thought the turning was a bit weird this way and asked me to decouple the canard from the ailerons. What do you think?
Sorry, I have no video camera and only a pretty slow digital camera. The flight pictures are pretty bad.
chewy
chewytm is offline Find More Posts by chewytm
Discussion GWS 262 EDF Jet GWS4CEO Foamy EDFs 14 Aug 03, 2008 08:28 AM
Cool Chinese J-10(Depron foam) picture & video aero-dreamworks Parkflyers 12 Aug 02, 2008 07:48 AM
Discussion Chinese J-10 aero-dreamworks Pusher Prop Jet Models 17 Jan 03, 2008 06:07 AM
Sold Good old Vet GWS A-10 twin EDF jet fighter bomber with 2 servos shschon Aircraft - Electric - Jets (FS/W) 3 Nov 24, 2006 02:26 PM
New to EDF - Opinions please! Best handlaunch parkflyer sized EDF jet model StahlmanGC Electric Ducted Fan Jet Talk 7 Aug 19, 2004 07:21 PM
