This thread is privately moderated by GWS CHEN, who may elect to delete unwanted replies.
Old Jan 22, 2008, 01:54 PM
darmar is online now
Find More Posts by darmar
USA, PA, Pittsburgh
Joined Jul 2001
Latinflyer,
Would it ROG with canards in fixed position?
Just got it, UPS delivered it. Great model and you get allot for the money even if you ditch the old style 75mm fan, at least I got old style, no "RIBS" inside the rotor.
I wish they included cheater cover like on f-15.
Again great model.
darmar is online now Find More Posts by darmar
Old Jan 22, 2008, 03:32 PM
blueplane is offline
Find More Posts by blueplane
Joined Sep 2007
Originally Posted by Herb
The fuse is big, but space is quite a bit tight in the front. I had to carve out the canopy floor to make everything, incl the 6s pack, fit. The canard servo is kind of in the way too.
I used elevon mixing (ch 1 and ch2) on my Futaba 9C, and added the canards (ch 6) to the elevator channel using a programmable mix. I have twice as much throw on the 'elevator' as I have on the 'aileron'. The canard motion is just a few mm up and down, elevons are plenty for takeoff and landing.
I think problem arise when you use the recommended mixer in line with the elevons, then it's impossible to program less 'aileron' throw than 'elevator' throw on the elevons. That's when the canard come in handy, to help lift the nose a bit more. Othewise you end up with crazy aileron response.
Hi Herb;
I truly enjoy your posts and
need your advice with the choice of fan.
Years back in 2003-2004 you used the 609 on
one of your Jets and I think that fan is a good
choice here for this particular model; but you are using
the minifan instead. I wonder is there a good reason
that you prefer the mini over the 609? like better efficiency?
lighter weight? availability???
IMHO, the 609 is a better choice here.
Please advise.
Thanks.
blueplane is offline Find More Posts by blueplane
Old Jan 22, 2008, 07:58 PM
kensp is offline
Find More Posts by kensp
kensp's Avatar
Darwin Australia
Joined May 2002
Originally Posted by darmar
Latinflyer,
Again great model.
Probably yes. But you would need to have the ability to make in flight adjustments of the Canard incidence to find out the correct angle to fix the canards at. I.E. a servo moving the canards that is not linked to the elevator stick. It would be better to fit an elevator stick link to the Canards.
For those persons wishing to know the size of the battery compartment the dimentions are 35.5mm x 37 mm x 150 mm
Chewy this means that the battery compartment needs to be enlarged to fit the Zippy-H 3300mAh 3S1P 20C battery pack but there is enough foam there to allow the compartment to be widened at the bottom.
Ken
kensp is offline Find More Posts by kensp
Old Jan 22, 2008, 08:32 PM
GWS CHEN is offline
Find More Posts by GWS CHEN
Taipei, Taiwan
Joined Oct 2005
Latinflyer and Herb,
You're the first two pilots of EB J-10. Would you post video or more photos of your great J-10.
Chen
GWS CHEN is offline Find More Posts by GWS CHEN
Old Jan 23, 2008, 08:59 AM
USA, PA, Pittsburgh
Joined Jul 2001
Could anyone post a picture of new updated rotor please?
I got the kit yesterday but see no reinforced rotor with ribs. Have no idea if this one is new or old style.
Old Jan 23, 2008, 10:10 AM
THREEWING is offline
Find More Posts by THREEWING
Dam Dutch Fokker.
USA, UT, Farmington
Joined Jul 2003
New rotor was only in the EB kits!
THREEWING is offline Find More Posts by THREEWING
Old Jan 23, 2008, 11:29 AM
USA, PA, Pittsburgh
Joined Jul 2001
Thanks. Ended up using kyosho 75mm rotor anyway.
Old Jan 23, 2008, 12:22 PM
Blaze.45 is offline
Find More Posts by Blaze.45
Seeing the Farside.
Blaze.45's Avatar
Seattle WA, USA
Joined Aug 2005
My two came in from Caliber a few days ago... this model is BIG. It almost looks as if the wings are too small for a fuse of this size!
-Chris
Blaze.45 is offline Find More Posts by Blaze.45
Old Jan 23, 2008, 02:07 PM
crxmanpat is offline
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
I got two kits recently, the A-4 from Epyaya at the AMA Convention a few weekends ago, and the J10 through the EB program.
The rotor in the A-4 kit is the old one without reinforcing ribs.
The rotor in the J10 is supposed to be the updated one, but it is on there very tight and I cannot get it off (or more appropriately, I'm afraid of pulling on it too hard so I don't break it).
Pat
crxmanpat is offline Find More Posts by crxmanpat
Old Jan 23, 2008, 02:16 PM
USA, PA, Pittsburgh
Joined Jul 2001
well I busted one while testing it yesterday, that's why I ask. Center piece broke of at full throttle, It was vibrating bad from 3/4 to full throttle. I did balance it first best I could.
Old Jan 23, 2008, 02:22 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
I will most definitely be reinforcing the A-4 hub I have before installing it. That trick with the depron disc should work OK. I just hope the J-10 hub holds up (GWS says it was already tested on a 3 minute run).
Pat
Old Jan 23, 2008, 02:38 PM
Dam Dutch Fokker.
USA, UT, Farmington
Joined Jul 2003
I did not see any indication that my fan in the EB J -10 kit had been run. There were no rub marks ,and mine when I test run it at about 1/2 throttle started to vibrate and rub,tried to throttle up and smoked the motor. Less than 40 seconds. Cracked one rotor tip and smoked the motor. 3s 2250 loogmax 25c battery 75 amp align ESC. (Fan sticker marked 850 grams.) REPEAT! ran on 3s.
Old Jan 23, 2008, 02:55 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Well, mine definitely has rub marks on the shroud, so I know it was run at least once.
Did your shroud have a thrust sticker on the side?
Pat
Old Jan 23, 2008, 04:27 PM
Joined Sep 2007
Hi darmar?
what center piece is it?
the center piece of the GWS rotor or the center
housing that hold the motor. Details please. Thanks
I am thinking of discarding the GWS rotor, using only the
GWS 75mm fan's housing with my home made 75mm rotor.
And I wonder how this GWS housing can handle
700-800 watts.
Old Jan 23, 2008, 06:00 PM
Joined Sep 2007
Originally Posted by blueplane
Hi Herb;
Please advise.
Thanks.
never mind, I got it.
Thanks.
Discussion GWS 262 EDF Jet GWS4CEO Foamy EDFs 14 Aug 03, 2008 09:28 AM
Cool Chinese J-10(Depron foam) picture & video aero-dreamworks Parkflyers 12 Aug 02, 2008 08:48 AM
Discussion Chinese J-10 aero-dreamworks Pusher Prop Jet Models 17 Jan 03, 2008 07:07 AM
Sold Good old Vet GWS A-10 twin EDF jet fighter bomber with 2 servos shschon Aircraft - Electric - Jets (FS/W) 3 Nov 24, 2006 03:26 PM
New to EDF - Opinions please! Best handlaunch parkflyer sized EDF jet model StahlmanGC Electric Ducted Fan Jet Talk 7 Aug 19, 2004 08:21 PM
