This thread is privately moderated by GWS CHEN, who may elect to delete unwanted replies.
Old Jan 15, 2008, 04:57 AM
kensp is offline
Find More Posts by kensp
kensp's Avatar
Darwin Australia
Joined May 2002
Originally Posted by THREEWING
The J-10 sticker lists 850 g s/n 7500704. Haven't put the rotor on the balancer yet .
My J-10 Fan unit lists 830 grams at 11.1 volts and S/N 75000698. I will test the unit on a 2250 mAh 25 C battery tomorrow.
Ken
kensp is offline Find More Posts by kensp
Old Jan 15, 2008, 07:12 AM
camship is offline
Find More Posts by camship
Resistance is Futile
camship's Avatar
United States, FL, Panama City Beach
Joined Oct 2001
830g/29.8 oz. thrust on 3 cells? Is this an installed in airframe number or just bench in open air?
Camship
camship is offline Find More Posts by camship
Old Jan 15, 2008, 10:22 AM
GWS4CEO is offline
Find More Posts by GWS4CEO
Houng-wen Lin
GWS4CEO's Avatar
Shijr, Taiwan. DungGwan, China. City of Industry, California.
Joined Sep 2001
Originally Posted by ParkJeff
Mr Lin,
Could you tell us what is the difference, apart from kV, between the previous 2815 RED and this new 2815 RED? What sort of improvements were made?
Thanks.
Jeff
New one is about 3800Kv.
GWS4CEO is offline Find More Posts by GWS4CEO
Old Jan 15, 2008, 11:16 AM
chewytm is offline
Find More Posts by chewytm
Ipoh, Perak Malaysia
Joined Jul 2006
hmmm this new motor seems to have quite a few vent holes at the end caps
chewy
chewytm is offline Find More Posts by chewytm
Old Jan 15, 2008, 12:21 PM
chewytm is offline
Joined Jul 2006
Sounds like you need another house for your planes.
Heh heh. I only have a room for all my planes and books. I need a larger room. Maybe I will commandeer the back kitchen : it's 32ft x 15ft. Ugghh, no, on second thoughts. There are snakes (cobras etc) just behind the backyard walls due to undeveloped land that's full of underbrush (a mini jungle). Sometimes they climb over on branches. They are not so bad if you know they are they. It's when you don't realize that they have hidden themselves in the nooks and crannies or under you computer table, that when it's a problem. Shudder!
chewy
Old Jan 15, 2008, 02:55 PM
crxmanpat is offline
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Originally Posted by GWS4CEO
New Gen. 4th 2815 RED BL motors will be over 800+g when equipped into EDF75.
Mr Lin (or Chen),
Will this new version handle 4S? I ask as the BLM005a's are also about 3800kv and will handle 4S.
Also, when do you expect these new motors to land in the US? I have one for the J-10, but will need one for the A-4 also.
Thanks.
Pat
crxmanpat is offline Find More Posts by crxmanpat
Old Jan 15, 2008, 04:07 PM
blueplane is offline
Find More Posts by blueplane
Joined Sep 2007
Originally Posted by crxmanpat
Mr Lin (or Chen),
Thanks.
Pat
IMHO, if you use 4 blade 70mm fan like HET 6904, instead
of the 4 balde 75mm GWS fan then it should be OK using
4S, especially with that new nice GWS heat sink
blueplane is offline Find More Posts by blueplane
Old Jan 15, 2008, 04:40 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
As an Earlybird member, I like to use GWS stock parts as much as possible so that I may make an accurate report on the kit and the power system. If I find power lacking on initial flights, I can always change out for something with more gusto.
But if the new motor will take 4S, it should have plenty of giddyup. Even on just 3S it may be OK as GWS testing shows almost a 1:1 T/W ratio.
Pat
Old Jan 15, 2008, 04:42 PM
Joined Sep 2007
But if the new motor will take 4S, it should have plenty of giddyup. Even on just 3S it may be OK.
Pat
it's all up to you.
But Mr Lin gave it a red light on 4S
BTW, I only love stock foam with some modification, no matter GWS or not
Old Jan 15, 2008, 04:54 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Well, his post that said 4S was bad was based on a 4100kv rating. Now it seems closer to 3800kv. It would be nice to be in the 1K club, but I guess I can settle for 830g.
Pat
Old Jan 15, 2008, 07:32 PM
Joined Sep 2007
Pat
well then just do the red parts: STOCK ONLY AND BE HAPPY
why care for the 4S then.
Old Jan 15, 2008, 07:34 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Yes, but stock has nothing to do with battery size. If the motor will handle 4S, why not use it? But if the fan system/motor won't handle 4S, I'll stick with 3S.
Pat
Old Jan 15, 2008, 07:52 PM
chewytm is offline
Joined Jul 2006
I too would prefer to go 4S if the system can handle it. More speed. Cooling is usually pretty good for edf. I think this fan unit provides quite good cooling for the motor as the is a large gap between the hub/rotor and the stator and there are all those cooling holes in the motor. Should give the windings/magnets a good breeze, don't you think?
chewy
Old Jan 15, 2008, 08:07 PM
Joined Sep 2007
Pat
GWS manual on this 2815 motor states: Optimal power is 400 watts.
12 volts draws 38 amps out put 450 watts and 735 grams (26oz) of thrust.
So I guess we can push to 4S (13+volts) at 500 watts short bursts,
not always WOT and use their new heat sink for safety's sake.
However another user just posted that
with 3S 2200 lipo (10V) the motor draws 37 amps, put out 375 watts
So... Give 4S a try then
Old Jan 15, 2008, 08:54 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
I'll try to bench test my fan before installation. My rotor housing says 850g tested thrust.
BTW, both this plane and the A-4 definitely have a "presence". I'm not used to GWS planes this big!
Pat
Discussion GWS 262 EDF Jet GWS4CEO Foamy EDFs 14 Aug 03, 2008 08:28 AM
Cool Chinese J-10(Depron foam) picture & video aero-dreamworks Parkflyers 12 Aug 02, 2008 07:48 AM
Discussion Chinese J-10 aero-dreamworks Pusher Prop Jet Models 17 Jan 03, 2008 06:07 AM
Sold Good old Vet GWS A-10 twin EDF jet fighter bomber with 2 servos shschon Aircraft - Electric - Jets (FS/W) 3 Nov 24, 2006 02:26 PM
New to EDF - Opinions please! Best handlaunch parkflyer sized EDF jet model StahlmanGC Electric Ducted Fan Jet Talk 7 Aug 19, 2004 07:21 PM
