Old Jan 06, 2010, 06:41 PM
sonicj is offline
Find More Posts by sonicj
five by five
sonicj's Avatar
Panama City Bch, FL
Joined Jan 2009
i have a weird issue with my rc cars... spektrum dx3s & sr3300t with 900mhz 500mw. i place the car outside and attempt to drive and the car just freaks out. with video tx off, the car drives fine. if i use the same vid tx in my plane (spektrum 2.4 as well) everything is fine...
sonicj is offline Find More Posts by sonicj
Old Jan 06, 2010, 06:58 PM
year1camaro is offline
Find More Posts by year1camaro
RPV of DOOM
year1camaro's Avatar
Joined Dec 2007
Are u powering your vehicle and camera system on the same battery?
year1camaro is offline Find More Posts by year1camaro
Old Jan 06, 2010, 07:01 PM
sonicj is offline
five by five
sonicj's Avatar
Panama City Bch, FL
Joined Jan 2009
yes. its a 1/18th scale so im VERY limited on space. same battery works fine in the airplane.
Old Jan 06, 2010, 07:06 PM
Daemon is offline
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
It's most likely direct interference between 900Mhz Tx and the servos.
You'll probably have to change the servos out to cure it.
ian
Daemon is offline Find More Posts by Daemon
Old Jan 06, 2010, 07:07 PM
Wobby is offline
Find More Posts by Wobby
Closed Account
Joined May 2007
Yep, 900Mhz can be a real spektrum killer.
There are filters you can get to put on the base of the 900mhz Transmitter antenna, supposedly to settle down the garbage that the 900mhz units spew out.
Never tried one myself, i dont bother with 900mhz anymore.
The car spektrum units wor different to the airborne spektrum units, maybe they are even more sensitive to interference that the air stuff.
If you can, try putting the Video Transmitter 100% directly above the 2.4rc spektrum receiver.
Stand the Vtx upright, and the antenna upright as well.
This will place your spektrum car reciever in the null of the video transmission, doing this works in my fpv planes, may be similar in your car, cant harm trying.
Wobby is offline Find More Posts by Wobby
Old Jan 06, 2010, 08:39 PM
RPV of DOOM
Joined Dec 2007
A friend had that problem, I remember him sayin somethin about filters but he used a seperate battery camera system instead of the filters. Couldn't hurt to try for a test.
Old Jan 06, 2010, 08:53 PM
sonicj is offline
five by five
sonicj's Avatar
Panama City Bch, FL
Joined Jan 2009
hmm... i doubt its the servo (1 x hs56hb) as i haven't had any problems with hitec analog and 900mhz. its more of a general disobedience to all control inputs.
i've seen the filters and i guess thats a possibility. i have tried a few different antennas tuned for extremely low swr all with the same results. the stacked idea is something i hadn't considered yet... i'll attempt that next go round!
i wish i had the space for another battery... its just such a tight fit even before adding fpv gear! i put a torroid on the esc even though its not a switching bec. i'll try a filter on the power feed to the tx. i might need to consider going back &/or fm. its just such a small area to work...
-sj
Old Jan 09, 2010, 09:51 AM
Stylish187 is offline
Find More Posts by Stylish187
Technician Steve
Stylish187's Avatar
Rochester
Joined Jan 2010
Took the Havoc out in the snow last night, had to remove the FPV gear for jumping, not a great vid but i thought id share:
Havoc Bashing .m4v (0 min 52 sec)
Steve
Stylish187 is offline Find More Posts by Stylish187
Old Jan 09, 2010, 10:26 AM
eander315 is offline
Find More Posts by eander315
My other heli is a Vapor
eander315's Avatar
Houston, TX
Joined Dec 2007
-sj
You might need to add a toroid to every line going into the receiver. They're far cheaper than the 900MHz low-pass filter and should more or less fit on your truck easily. I agree with the others though that your battery arrangement will probably have to be resolved before you get much further.
eander315 is offline Find More Posts by eander315
Old Jan 14, 2010, 03:02 PM
Technician Steve
Stylish187's Avatar
Rochester
Joined Jan 2010
Hi All.
While waiting for some new gear to build my nitro FPV project...
I built a little FPV tank from some old parts.
Another rubbish video:
FPV Micro Tank with 2.4GHz wireless video system (0 min 53 sec)
Old Jan 18, 2010, 08:15 PM
speedygonzales is offline
Find More Posts by speedygonzales
Toronto, Canada.
Joined Dec 2006
Originally Posted by Stylish187 View Post
Hi All.
http://www.youtube.com/watch?v=FYJvf-LaI_w
thats a very respectable speed.
what did you use for the transmission
speedygonzales is offline Find More Posts by speedygonzales
Old Jan 20, 2010, 04:40 PM
kefir is offline
Find More Posts by kefir
Poland Gdynia
Joined Feb 2009
My first FPV and the first car ride
So far it flew airplanes
http://vimeo.com/8802835
kefir is offline Find More Posts by kefir
Old Jan 23, 2010, 04:06 PM
Technician Steve
Stylish187's Avatar
Rochester
Joined Jan 2010
The chassis has come from a little 1:32 scale infra red rc tank.
As its infra red it has virtually no range. The tracks are rubber and pull them selves off on any surface other than a polished one.
Ive taken the gear off the tank now and put it on a little rc subaru :
Its far more fun.
FPV RC car Subaru Impreza (2 min 45 sec)
The quality is terrible but i think thats just down to the camera.
I completely chopped the wiring for the tx and camera so there is only a couple of inches of it left.
Im now getting a better video signal than ever before.
Of course the chassis is now fully plastic!
I get a much 'richer' picture when i use a 12volt battery, but ive not got a light enough, or small enough one at the moment.
What do you suggest I use?
A 6 cell lipo?
Cheers
Old Jan 25, 2010, 02:34 PM
ashdec87 is offline
Find More Posts by ashdec87
ashdec87's Avatar
United States, MI, Detroit
Joined Feb 2004
is there a way to use a wireless system in a house to an advantage?? I get some massive cutout when I drive around the house. Guess the video doesnt like lots of walls lol
ashdec87 is offline Find More Posts by ashdec87
Old Jan 25, 2010, 02:50 PM
mkmkmk13 is offline
Find More Posts by mkmkmk13
mkmkmk13's Avatar
United States, CA, Orange
Joined May 2007
yes walls and if you are running ur video on 2.4, then routers and other electronics might affect it
mkmkmk13 is offline Find More Posts by mkmkmk13
Discussion Cheap FPV Car for Kids Domoson FPV Talk 8 Dec 28, 2007 05:13 PM
Looking for fun 51 build thread??Help??? fish2keel The Profile Brotherhood 0 Apr 07, 2005 04:27 PM
B-2 gets 48 minutes :) and other fun. Mikey-flies Parkflyers 2 Jul 27, 2003 08:44 PM
HECELLS, new video & other fun stuff Duf Parkflyers 0 Mar 24, 2003 08:35 AM
