Sacramento
Joined May 2003
rotor balance
![]() I might consider just using GWS fans from now on if this works.
GWS rotors are generally molded to acceptable tolerances for our uses. If you took a lot sample, you may find say 10% that could really be a bit better. Please don't argue the numbers here, as its all hypothetical. Now if GWS wanted to have all 100% at tight tolerances, they would pay a much higher cost to have the manufacturer reject the few severely off-tolerance rotors, and for the most part, the rotors that would pass the QC and be shipped to GWS would not be much better if any, than the rotors GWS already gets from them. I have literally seen this happen: You spec no tolerance, but with modern maufacturing you get high tolerance parts (relating to your actual CAD file's dimensions) without paying any additional costs for high tolerance. You spec tolerance, pay like hell for it, and end up with the same part tolerances that you would get in the first scenario, but just pay twice as much. The real bottom line here is that the best option for us (customers) would be to simply buy a large lot of rotors, and personally reject the ones we feel are out of tolerance. In the end, the cost would be no more than if we paid for it up front. |
Joined Sep 2007
you have to balance those two round plugs and then make sure the shaft is straight. How do I know? I suffered about it too much and never used it again
Joined Sep 2007
plugs that hold the Rotor in the middle of the shaft for balancing. Mine are horrible unbalanced and why would I bother and waste time with these craps.
Joined Sep 2007
So the first thing to do with these balancers is to balance them before you start to use them. How Ironic!
I just used a GWS "B" gear to insert and CA glue in the rear of the rotor hub of an EDF64 rotor. This is a gear from the 300 series gearboxes. Given that only a few teeth were only slightly damaged, I can say that a new one should should fit right in perfectly.
I am also fully convinced that the hubs are what explode, and not the blades. This should really help dampen vibration and keep the hub together. Quote:
How do you balance the EDF64 rotor?
I'm getting ready to install the EDF64s in my -15 and would love to balance the rotors but I'm missing how to go about getting the rotors onto a balance shaft as the hole through the rotor is quite small? I must be suffering a lapse
Would someone mind offering a brief tutorial on how to balance these rotors? TIA |
| Thread Tools | |
| Discussion Good Tuning Tips For Your BCP!!! | speeddemon281 | Micro Helis | 2 | Jan 13, 2006 06:55 PM |
| Discussion Here are some easy snow skis for your Slow Stick | CactusJackSlade | Beginner Training Area (Aircraft-Electric) | 2 | Dec 22, 2005 12:05 PM |
| Easy way of making parallel tail mounts for your CF tubes | PLD | Hand Launch | 4 | Feb 06, 2005 09:12 AM |
| Question How about this motor for your EDF | ScienceGuy | Electric Ducted Fan Jet Talk | 9 | Jun 27, 2004 01:52 PM |
| EDF for your AUTOMOBILE!?! | scififlyer | Electric Ducted Fan Jet Talk | 13 | Aug 02, 2003 09:15 PM |
