Old Jan 18, 2008, 01:25 PM
whto is offline
Find More Posts by whto
Fremont, CA
Joined Jul 2007
Originally Posted by ccdengr
I agree. I flew three packs this AM and was amazed at how well the tail holds, even with the Esky rate gyro I'm using. (Much, much better tail control than my King 2.) The cyclic is also very responsive, and the amount of power is impressive. I think I can get 9 or 10 minutes from a 1250 10C pack, though I only flew for 8 today. All in all, it flies pretty much like I was hoping it would!
Wouldn't agree more, and I'm glad you like it.
It flies better than I have expected. My HB FP flyies quite well with dd tail and cut down blades. However, the Compy FP is on another league. Don't know if I want to fly my HB FP anymore
Too bad, after flying 6 packes, the motor seized in mid air. Luckily, the only damage is the stripped main gear, and the motor. Waiting for parts again.
Will take some pic's and vid once it's on the air again.
- Thomas -
whto is offline Find More Posts by whto
Old Jan 18, 2008, 03:59 PM
maarset is offline
Find More Posts by maarset
I can drift a heli
maarset's Avatar
USA, CA, Sacramento
Joined Mar 2005
Hey whto
How much do you trim your stock HB Main blades down?
I put a DD tail on my HBFP and use a 3s lipo and taking
a half inch off each tip of the blade helped with stability TONS!
I'm hovering at half throttle so I think I could probably trim a little more eh?
What did you do?
Should I maybe try trimming a little of the trailing edge of the main blades?
Or maybe get some flat bottom wood blades or M24's? I like using the stock blades and modifying them
cause I'm still just getting into side hovering and learning nose in hovering.
maarset is offline Find More Posts by maarset
Old Jan 18, 2008, 04:53 PM
whto is offline
Fremont, CA
Joined Jul 2007
Originally Posted by maarset
Hey whto
What did you do?
Mike,
Actually, my cut down blades are dynam 300 blades. They are heavier and stiffer than the stock blade. They flies better than stock w/o cutting.
I cut about an inch off from the tip, and I just following the contour of the original tip when cutting.
I haven't tried the M24 so can't comment on them. I did try the FP wood blades from heli-fever, and they flew very similar to the cut down blade. Tthe woodie are on my Compy FP.
Hope this help
- Thomas -
Old Jan 18, 2008, 05:00 PM
maarset is offline
I can drift a heli
maarset's Avatar
USA, CA, Sacramento
Joined Mar 2005
Ah yes the Dynam 300's are good. I fly with those too. White ones. The latest stock FP blades I have been getting from BPhobbies have been as stiff as the dynam 300 blades.
I took a half an inch off my blades but I am going to do another half inch and see how that goes.
Thanks THomas
Old Jan 18, 2008, 05:04 PM
whto is offline
Fremont, CA
Joined Jul 2007
No problem.
- Thomas -
Old Jan 18, 2008, 07:50 PM
maarset is offline
I can drift a heli
maarset's Avatar
USA, CA, Sacramento
Joined Mar 2005
I just got done flying a 10C 3s 800MAH pack on my stock HBFP with a inch taken off each main blade. Hovering just over half throttle. Thing flew like my Lama V3.
Just awesome. Was very comfortable turning the tail 90 degrees. Did a little forward flight inside. Very stable. Not sure if I even need M24's or woodies. They would be longer though. Any advantage to that?
Old Jan 18, 2008, 08:23 PM
kt74 is offline
Find More Posts by kt74
It's a heli valotta fun!
kt74's Avatar
Joined Apr 2007
Hey ccd,
Did you find that you needed the tail pitch slider almost all the way over to one side to get the tail to hold while hovering? I was using the FP main blades though, so maybe I wasn't getting enough headspeed for the tail to hold properly. Would you mind posting a photo of your tail pitch slider and where it sits when you are powered up?
kt74 is offline Find More Posts by kt74
Old Jan 18, 2008, 08:47 PM
whto is offline
Fremont, CA
Joined Jul 2007
That I can't really help. I'm not techincal enough to give you an answer as to whether running the longer woodies or M24's will be better or not.
Actually, there a quite a few discussions on using different blades in the Honey Bee FP Owner II thread. You might be able to get more info and help from that thread,
- Thomas -
Old Jan 18, 2008, 09:12 PM
MicroHeli-Nut is offline
Find More Posts by MicroHeli-Nut
The Rave.
Singapore Paya Lebar, Singapore
Joined Aug 2003
Originally Posted by kt74
My Compy came today!!!
So of course I've been building it for the past few hours. Here are a few pictures.
I had to use my HBFP main gear because the white one I got was terribly warped. Anyways... it's going well so far. I didn't order the deluxe kit. I ended up using the tail servo mount from my Belt-CP. I didn't want to drill into the frame to mount the servo.
It seems the revised battery tray is longer!
MicroHeli-Nut is offline Find More Posts by MicroHeli-Nut
Old Jan 18, 2008, 09:17 PM
ccdengr is offline
Find More Posts by ccdengr
USA, CA, San Diego
Joined Jun 2007
I'd say that hovering, the pitch slider is about halfway from hitting its forward stop, so my servo is binding in one direction. Piro rate seems OK both ways but I've only flown four packs at this point.
The Compy entry on eflightwiki ( http://www.eflightwiki.com/eflightwi...title=Compy300 ) cautions that it's possible to get the tail blade grips on backwards.
I'd also say that my belt is a little tight, and my boom is as far forward as it'll go, so the boom adjustability could be improved.
ccdengr is offline Find More Posts by ccdengr
Old Jan 19, 2008, 12:31 PM
KABAL99 is offline
Find More Posts by KABAL99
FRANCE
Joined Dec 2004
HI ALBERT
what the new Belt Pulley & CNC Main Gear Set give more than the old one ?
If the belt pulley is screwed on the gear it means the rotor lead the main gear when the motor is stopped ,rigth ?
Does not it brake the rotor when we decrease the motor sharply ?
THX
KABAL99 is offline Find More Posts by KABAL99
Old Jan 19, 2008, 01:45 PM
ccdengr is offline
USA, CA, San Diego
Joined Jun 2007
So this is about where my tail slider is in a stable hover. As you can see I don't have a lot of travel left. I don't think there's anything that can be done about this, though.
Old Jan 19, 2008, 08:16 PM
Albert_Moto is offline
Find More Posts by Albert_Moto
Aerofever.net
Albert_Moto's Avatar
Hong Kong Intl, Hong Kong
Joined Aug 2004
Originally Posted by KABAL99
HI ALBERT
THX
The old Compy 300 main gear is super-noisy and eat the brass pinions; but this Compy FP won't. It has no one-way and I don't think it is a neccessary esp. on Compy FP.
Don't worry, it won't brake the rotor and it is more durable in crashes coz the rotor won't continue to rotate when u pull the throttle down.
In windy day, the FP may have difficulty to bring in down from altitude coz the rotor will still rotating even u pull the throttle down . . . that's why I don't suggest to use one-way system on FP.
Albert
Albert_Moto is offline Find More Posts by Albert_Moto
Old Jan 19, 2008, 10:42 PM
kt74 is offline
kt74's Avatar
Joined Apr 2007
Yeah... that looks about the same as mine. I got my motor and 3s LiPo's today! I love the way the Compy flies!!! Even with the stock rate gyro the tail is rock-solid. I haven't tested the piro rate on it yet... it was too gusty outside to fly today.
Old Jan 19, 2008, 11:53 PM
KABAL99 is offline
FRANCE
Joined Dec 2004
Albert
OK THX
Discussion Motor/ESC combination for Compy 300 FP? generalbacardi Micro Helis 1 Oct 31, 2008 09:43 PM
Sold Excellent Compy 300 FP RTF with Lots of Extras!!! - Blowout Price - $170 SHIPPED cdbarnett Aircraft - Electric - Helis (FS/W) 14 Nov 16, 2007 05:16 PM
Discussion Compy 300 FP coming out? generalbacardi Micro Helis 2 Nov 08, 2007 11:50 PM
Video Compy 300 FP video testing the Esky beefed up paddle frame and Compy swash electric-flyer Electric Heli Talk 0 Oct 04, 2007 09:41 PM
Cool Compy 300 FP video electric-flyer Micro Helis 0 Jul 17, 2007 02:24 PM
