They're having trouble keeping the 11.1V 1300's in stock. Mine just shipped after a 2 month backorder. |
I didn't bend it, I snapped it in 2. I'd take the machinist another, but it's just the embarrassment factor of taking him another and having to tell him how I stupidly broke the first I'll relate the stupid thing I did. I was thinking I'd just chuck the shaft in my Dremmel and use a hack saw blade to cut it down. Apparently the dremmel chuck does not have a lot of rigidity, or the main shaft fit in there a bit off center or something. At any rate when I spun it up it had a fair amount of runnout and I was noticing that it looked like it was due to flex in the shaft as the runout increased with rpm. Well, my stupid mistake was running the dremmel up to top speed to see how much the shaft would flex, which turned out to be a lot, which then caused the shaft to snap at the main gear pin hole. Just give me a power tool and see what trouble I can get into - LOL - Doug |
Unless the gyro was damaged from a crash.. or ya, mechanical. It was , rock solid as HH tail should ever be and very fast pyro. Even if you trim it , it still comes back to center? |
did when I set this up on the DX6i does it need to be reset? its flys well but like a rate.. needing to be fed some trim to stay put. I'm sure it pyros fast as hell.. i don't have the balls to try it yet.. still doing head in and side in hovers. not sure what you mean by trim on the rudder/gyro. |
Last vid I saw was you flying the MX 400...quite well I might add I've got one also....although it's not really an MX now More like a Mtrex It was flying so well...until yesterday Guess it's kinda like a light bulb that burns really bright before it goes out ? So...during the rebuild, I've stretched the tail ! Should be able to turn 325s now ![]() -Dave |
Fremont, CA
Joined Jul 2007
1. Plug the yellow wire from the gyro to the gear channel. Make sure the wire goes to the 'ohm' pin. 2. Set Aux2->Aux2 and Gear->Gear in the input select menu. 3. Set the travel adjust for the gear. + value for HH, - value for Rate. This is to set the gain of the gyro via the TX for HH and Rate mode. 4. Turn the gyro's gain to 0. Fineless video is oppsite. You can try both setting. 5. Adjust subtrim/rudder in the subtrim menu if there's drifting. With this setting, you should be able to use the Gear switch the switch between HH and Rate mode on the fly. Hope this hlep. - Thomas - |
The old tool had a double stacked bearing at the output shaft. The 80's models had a nice flanged bearing there. When the "big box stores came along and started selling Dremel products, like a lot of other products, they started cutting corners, making them to Wally World specs...etc. I burned up up a supposedly top of the line cordless model(mechanical speed control) a couple of years ago, grinding clearance for a taller cam lobe profile in a cam bearing boss on the aluminum motor case of my Harley.I took the POS apart to see what the problem was. Not only was there no output bearing, but the "bushing" was made from a piece of 1/4" od polyethelene tubing. The cheap, 5¢ a foot, milky white tubing that used to be used for ice maker lines in refridgerators. With this junk, as soon as you put any side bearing pressure on the shaft it just burns off the poly. Come on, at least put a bronze 10¢ bushing or Delrin plastic. A lot of hand held power tools made to meet a Wal-Mart price point lost thier bearings to cheaper alternatives. I hate junk tools. Sorry for the OT rant.... |
I'm gonna have to try to figure out what that all means. specially step 2 and 3.. |
Fremont, CA
Joined Jul 2007
Here is step 2: 1. Goto Model Select menu by pressing DOWN/SELECT button at the same time then turn on the TX. 2. Press DOWN until gets to the INPUT SELLECT menu 3. Set AUX2-> AUX2 and GEAR-> GEAR. Don't set any of these to Gyro. That only works for 7ch reciever. AR6100 is 6ch. 4. Exit Model Select by pressing DOWN/SELECT button at the same time. 5. We are now at normal display screen Here is step 3. 6. Goto Function Mode by pressing DOWN/SELECT button at the same time at the normal display screen 7. Use the UP/DOWN button to get to TRAVEL ADJUST menu. 8. You'll see THRO, AILE, ELEV, RUDD. all with xxx%. This is the TRAVEL ADJUST menu. 9. Press the SELECT button to move the -> (right arrow) until it scroll to the next screen of TRAVEL ADJUST menu 10 GEAR will show up. Use the INCREASE/DECREASE button the increase of decreate the % value. 11 + value is for HH mode, - value is for non HH mode. 12. Use the GEAR toggle switch (upper left corner of TX, my TX is the airplane verson) to toggle the -> (arrow) between + or - % Hope this help. - Thomas - |
The hdx300 pulley works quite well ! http://www.helidirect.com/product_in...oducts_id=1989 You'll need to watch Finless Bobs vid http://www.helifreak.com/showthread.php?t=16105 (Main gear, head and belt install) to understand how to install it. Since I'm using the microheli main gear w/auto-rotation bearing, i had to use an old hdx300 auto-rotation hub and cut a small bushing (2mm) to fit into the pulley to space it between main gear and belt pulley. You'll understand after watching the vid You'll also need to flat spot the shaft for the grub screws.-Dave |
| Thread Tools | |
| Discussion Motor/ESC combination for Compy 300 FP? | generalbacardi | Micro Helis | 1 | Oct 31, 2008 09:43 PM |
| Sold Excellent Compy 300 FP RTF with Lots of Extras!!! - Blowout Price - $170 SHIPPED | cdbarnett | Aircraft - Electric - Helis (FS/W) | 14 | Nov 16, 2007 05:16 PM |
| Discussion Compy 300 FP coming out? | generalbacardi | Micro Helis | 2 | Nov 08, 2007 11:50 PM |
| Video Compy 300 FP video testing the Esky beefed up paddle frame and Compy swash | electric-flyer | Electric Heli Talk | 0 | Oct 04, 2007 09:41 PM |
| Cool Compy 300 FP video | electric-flyer | Micro Helis | 0 | Jul 17, 2007 02:24 PM |
