Old May 02, 2008, 04:47 PM
GFBurke is offline
Find More Posts by GFBurke
allthingsthatfly.com
GFBurke's Avatar
USA, ID, Meridian
Joined Jan 2007
Works good. I used a 3s csrc 800mAh 10C lipos on mine.
GFBurke is offline Find More Posts by GFBurke
Old May 02, 2008, 05:07 PM
maarset is offline
Find More Posts by maarset
I can drift a heli
maarset's Avatar
USA, CA, Sacramento
Joined Mar 2005
I have one of those 3s 10c 800MAH CSRC. Get maybe 8 min flight times. And I have three 3s 8c 800mah CSRC's and get like 6 minutes fight time
maarset is offline Find More Posts by maarset
Old May 02, 2008, 05:09 PM
GFBurke is offline
GFBurke's Avatar
USA, ID, Meridian
Joined Jan 2007
Na, should be the same. Your C rating isn't relative to flight time in this case. Older maybe.. but not because of C.
Your 1000s should give you about 9-10min and retain the lipo @ 80%.
Old May 02, 2008, 05:43 PM
maarset is offline
I can drift a heli
maarset's Avatar
USA, CA, Sacramento
Joined Mar 2005
Sounds good. I'm pretty sure I shouldn't go under 10C at all. I need to hook my compy up to my watt meter. I've been watching my Cell Pro 4s to make sure I'm not discharging too much. I love this charger.
Old May 02, 2008, 05:56 PM
GFBurke is offline
GFBurke's Avatar
USA, ID, Meridian
Joined Jan 2007
Eh, you should be in the same range as mine was:
Arc110 motor, 3s lipo 800mAh, M24 blades = 5.7A @ 64W WOT
(.1A generated from 2 LEDs)
Old May 03, 2008, 03:22 AM
maarset is offline
I can drift a heli
maarset's Avatar
USA, CA, Sacramento
Joined Mar 2005
Originally Posted by maarset
I picked up some 190mm Trex metal flybars and Trex paddles.
I also got some Blade 400 Landing gear. Makes the compy sit a little taller. Not really doing it anymore but I was touching my tail on the ground everyonce in a while. Taller gear will be better for grass too.
The trex 450 flybar is like 7.5 inches long which might make the cyclic feel slugish.
But they might work well with my M24's cause the M24's spin so fast that the cyclic control is ubber sensitive.
I tried a 11 inch fly bar once on a HBFP and it was a total slug. These 190mm trex flybars might work perfect with the Compy wood blades. I hope.
How would a CommonSenseRC 3s 1000MAH 10c lipo work on a Compy with a HDX300 and wood or M24 blades?
Would I get atleast 10 minutes flight time?
Well I just got done doing some hovering with the Trex 450 flybar on my compy. Cyclic stayed very responsive and I could kind of tell the head speed went up. Heli felt even more stable. Maybe the trex paddles allow for a faster head speed?
Very happy. The Trex paddles were alot easier to setup too.
Had to drill some new holes in my Blade 400 landing gear for them to work. Tail rotor is now about 3/4 of an inch off the ground now.
Old May 03, 2008, 09:13 AM
KCinNC is offline
Find More Posts by KCinNC
that's gonna leave a scar
KCinNC's Avatar
United States, NC, Mooresville
Joined Aug 2007
i'd like to see a pic of the 400 landing gear on the Compy...if you got one
KCinNC is offline Find More Posts by KCinNC
Old May 03, 2008, 09:17 AM
Lutin is offline
Find More Posts by Lutin
Montreal St. Hilaire, Canada
Joined Feb 2002
Is the compy fp-deluxe still being made i looked at Aero-fever and did not see it...thank you
Lutin is offline Find More Posts by Lutin
Old May 03, 2008, 11:09 AM
USNAviationjay is offline
Find More Posts by USNAviationjay
US Navy AT2 1987-1995
USNAviationjay's Avatar
Houston Texas
Joined Mar 2008
its there... was just there yesterday.
hmm well just double checked and you're right the deluxe isn't there.
must be out of the CNC parts.
USNAviationjay is offline Find More Posts by USNAviationjay
Old May 03, 2008, 11:57 AM
maarset is offline
I can drift a heli
maarset's Avatar
USA, CA, Sacramento
Joined Mar 2005
I'll put a pic up later today. They look really good. Wider and taller.
Old May 03, 2008, 07:03 PM
maarset is offline
I can drift a heli
maarset's Avatar
USA, CA, Sacramento
Joined Mar 2005
Images of Mike's COMPY FP-BD with Blade 400 Landing gear.
Old May 03, 2008, 07:50 PM
Houston Texas
Joined Mar 2008
Just flew my freestyle today got 3 battery packs outa here before the wind smacked me pretty hard.
this bird is so easy to hover I constantly find myself saying wow..
I had to order some new parts from Australia since the only part I broke was a Freestyle only part.. Darn..
I'm wondering if I should get the EXI 450 I was planning on or just buying a Compy300FP deluxe instead.
Man these are fun and stable.
the only bummers are the blades M24 and Compy blades seem hard to get.
and of course Freestyle and Compy Unique parts which means ordering from Australia or HK respectively. which means 10+ days of shipping =/
Old May 03, 2008, 08:43 PM
Shogo is offline
Find More Posts by Shogo
Shogo's Avatar
Sunnyvale, CA
Joined Oct 2007
Can someone tell me whether plastic M24 blades are better on compy than 8 degreee woodies? I've tried to thin rotortech CF blades to get a higher head speed with less FP effect, but they started to flex up real bad, completely unusable. Do M24 flex upwards as well?
Shogo is offline Find More Posts by Shogo
Old May 03, 2008, 09:04 PM
maarset is offline
I can drift a heli
maarset's Avatar
USA, CA, Sacramento
Joined Mar 2005
The only Compy specific parts are the frame. Everything else is esky (head) and tail which is just like a Trex. And you can get those wood blades from Burke on the allthingsthatFly.com website.
Old May 03, 2008, 09:29 PM
maarset is offline
I can drift a heli
maarset's Avatar
USA, CA, Sacramento
Joined Mar 2005
So after posting those pics of my Compy I go out for another Test Hover and 2 min in I start losing power. Odd.... Then my blades flew off the rotor. I have them set up to fly off in a crash. My Jesus pin was GONE! I need to keep an eye on that. Using the stock Compy Main Shaft and CNC J-Team flybar cage.
Discussion Motor/ESC combination for Compy 300 FP? generalbacardi Micro Helis 1 Oct 31, 2008 10:43 PM
Sold Excellent Compy 300 FP RTF with Lots of Extras!!! - Blowout Price - $170 SHIPPED cdbarnett Aircraft - Electric - Helis (FS/W) 14 Nov 16, 2007 06:16 PM
Discussion Compy 300 FP coming out? generalbacardi Micro Helis 2 Nov 09, 2007 12:50 AM
Video Compy 300 FP video testing the Esky beefed up paddle frame and Compy swash electric-flyer Electric Heli Talk 0 Oct 04, 2007 10:41 PM
Cool Compy 300 FP video electric-flyer Micro Helis 0 Jul 17, 2007 03:24 PM
