Its completed and flys with the M24s even better than the FREEP =D With the ARC130I and a 10t I hover at 49 and have so much punch its insane.. full power would send this thing to the next area code in about 2 secs. yes the stock drivetrain can handle the high headspeed. JPC did this before any of us and he had no issues except for the now tried and true Align Flybar swap. |
Yah the Compy is noticeably heavier its quite the stocky little bird. the freestyle is a flyweight contender the heaviest part is the tail. even with the battery on and the canopy on it is very light in comparison. It gets kited alot easier than the Compy |
again maars read very carefully... I'm not TALKING ABOUT THE FREEP.. I'm talking about the Compy 300 FP BD.. seriously man I spelled it out for you 3 times. I havent even really flown the FREEP since I finished the compy. The Compy 300 is what the last 3 posts I made directly to you were about. I HAVE BOTH... |
It is not because the motor cannot produce enough power, it is because the motor will spin no faster on the available voltage. Lots of people on this forum are running much higher KV motors, so will not see this limitation.Maarset, I'd see what happens with solid links on both sides of the head. I have found the Compy to be pretty susceptible to weird induced oscillations, even when everything seems pretty well balanced. I know I run my gyro at lower gain than I'd like otherwise I get that low frequency up and down bobble in the tail, but I got that with the woodies as well. - Doug |
or is the ARC130 actually a bigger motor (higher output) than the outrunners these guys are useing or just a different design? I thought their motors were higher output then the little ARCs |
This is exactly what I was trying/hoping to clarify. There is a difference between the power a motor will produce and its max speed. For example, on a 3 cell pack producing 11.5 volts under load a 3100 KV motor (say 90% efficient) will turn at 3100x11.5x.9 = 32085 RPM. It will turn at more or less that same speed regardless of the load, so long as the load is less than the max current load. The KV rating is what is limiting the motor speed, not the power available or size of the motor. You can put a larger 3100 KV motor in that can produce more power, but it will not deliver higher WOT headspeed, it will just be heavier and therefore give you poorer performance. Unless you are pushing max current at WOT, you don't need a bigger motor. This situation is easier to see in a CP heli because you can hear the motor bog down when you feed in full collective if it is unable to deliver the required power. In most FP cases, you have enough power and you need a bigger pinion to reduce the gear ratio and get more headspeed. On the other hand, you don't want too big a pinion or then you are flying around at a low throttle % all the time which is inefficient. Brushless motors like to run up near their peak RPM. With a fixed pitch, you have to balance efficiency and available RPM increase for vertical performance. I don't think Maarset's problem really relates to his motor or gearing at all, though, since he didn't complain about a lack of performance, but rather instability near WOT. I think at his near WOT headspeed there is some kind of an oscillation near resonance. It is probably a complicated oscillation involving some vibration in the airframe inducing poor behavior in the gyro in a closed loop. Not easy to diagnose.... - Doug |
The FP head and what I've discovered
For the longest time, I've 'fought' the blade tracking-vibration-wobble problem and finally figured out a 'good' solution. Some have discovered that advancing the blade before lift off stopped the problems, so I decided that the blades MUST be VERY tight/snug on the head to avoid the lead/lag that occurs with collective/throttle changes (add power...they lag behind the head--in other words, the head spins faster than the blades)....which causes the wobble/vibration/tracking problem.
What I found was....you must use M2.5 bolts with fiber nuts (they come with a set of blades..usually). You must use a good head stiffener ! Start with a brand new FP head. Use a drill bit one size under the M2.5 bolt. Drill out the holes for bolts. Start the bolts and tighten in the head (do NOT overtighten). Assemble head with blades (if using the woodies, you'll need to drill the metal pitch washer for 2.5 bolts)...fiber nut on bottom. While holding head of the M2.5 bolt, tighten the fiber nut and check the blade for movement. It should just start to move with 'some' pressure. the trick is to have them as tight as possible, but still be able to move in the event they're attracted to 'other' things Ohhh....it's still a good idea to advance both blades before flight. I still sometimes have minor wobbles (skid shake), but it's because the fiber nuts need to be re-snugged. Please post your results if I've helped ![]() -Dave P.S....good STIFF tail blades are a most as well. I use the trex 'batwing' style |
| Thread Tools | |
| Discussion Motor/ESC combination for Compy 300 FP? | generalbacardi | Micro Helis | 1 | Oct 31, 2008 09:43 PM |
| Sold Excellent Compy 300 FP RTF with Lots of Extras!!! - Blowout Price - $170 SHIPPED | cdbarnett | Aircraft - Electric - Helis (FS/W) | 14 | Nov 16, 2007 05:16 PM |
| Discussion Compy 300 FP coming out? | generalbacardi | Micro Helis | 2 | Nov 08, 2007 11:50 PM |
| Video Compy 300 FP video testing the Esky beefed up paddle frame and Compy swash | electric-flyer | Electric Heli Talk | 0 | Oct 04, 2007 09:41 PM |
| Cool Compy 300 FP video | electric-flyer | Micro Helis | 0 | Jul 17, 2007 02:24 PM |
