Old Dec 17, 2007, 06:30 PM
Stan_in_AR is offline
Find More Posts by Stan_in_AR
Stan_in_AR's Avatar
Mayflower AR 24m WNW of Little Rock
Joined Mar 2007
Carbon fiber spars/? methods of fabricating
I'm going to build a set of wings for Grand Esprit using carbon fiber spars on inside panels.
It has been suggested to use finishing resin thickened with cabisol to adhere the spars to the balsa fillers. I cannot find a source for cabisol locally and on the internet I'd have to buy a "lifetime" supply.
Looking for one of two things:
1) alternate methods of adhesives
2) someone sell me less than a "lifetime" supply of cabisol
TIA
Stan
Stan_in_AR is offline Find More Posts by Stan_in_AR
Old Dec 19, 2007, 03:02 PM
mhodgson is offline
Find More Posts by mhodgson
mhodgson's Avatar
UK, Coventry
Joined Aug 2005
I am assuming you are using ready made carbon spars here.
You're problem is that under load the cardon may peel away from the wood carrier.
Personally I have always used plain unthickened finishing resin to adhere the carbon.
If you can, bind the carbon to the spar using kevlar thread. This will make the whole lot stiffer and prevent the carbon from pealing away from the wood carrier.
Try looking at how the freeflight guys do their carbon spars.
mhodgson is offline Find More Posts by mhodgson
Question Carbon Fiber Spars for SS wing needed, where to buy? LexTalionis Electric Plane Talk 7 May 24, 2004 05:58 PM
Where in Southern Calif can I go buy carbon fiber spars.. Jay_R Foamies (Kits) 9 Feb 01, 2004 06:48 PM
WTB: Carbon Fiber Spars Crunchie Aircraft - Sailplanes (FS/W) 1 Jan 06, 2004 03:54 AM
Carbon Fiber Spars Pitt76 Aircraft - Electric - Airplanes (FS/W) 7 Aug 02, 2001 10:00 AM
Carbon Fiber Spars Pitt76 Foamies (Kits) 5 Aug 02, 2001 01:55 AM
