Old Dec 17, 2007, 10:23 AM
captain at the is offline
Find More Posts by captain at the
Captain at the helm
london
Joined Dec 2007
Help!
Building a Modern Tug Mast
Hi,
I am a new member as I have been looking at the site for some time I thought I should join an become a member.
I am about to start my first attempt at building a TUG and I want to create my own mast, I do not know where to start so thought I would ask the members for some advice.
I want to build the mast from brass tubing, the TUG will have modern lighting i.e. all round vision so it will have quite a lot of lights, as in navigation, towing and all other lights required by a modern TUG.
So what I need help and advice on is the mast construction and how to do the wiring, I hope some members can steer me in the right direction.
Yours Aye
captain at the helm
captain at the is offline Find More Posts by captain at the
Old Dec 17, 2007, 10:30 AM
Boatfox is offline
Find More Posts by Boatfox
Give the dog a bone
Boatfox's Avatar
USA, NV, Las Vegas
Joined Aug 2005
Best bet is to look through some other build threads. Tito has exactly what you want starting on page 9 Tito Build Ask away and I'm sure others will chime in with suggestions. Take pictures too.
Boatfox is offline Find More Posts by Boatfox
Old Dec 17, 2007, 10:42 AM
patmat2350 is offline
Find More Posts by patmat2350
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
Welcome!
Learn to solder! Learn to SILVER solder! Plain solder doesn't have adequate strength for butted structural joints (for those times when you don't have any other mechanical joint).
Plan your joins so that you use high temp silver solder first, then stick little things on with electrical solder. Also use heat sinks, heat pastes, etc. to protect previous joints. Search at places like www.micromark.com under "solder"...
Commit yourself to making fixtures to hold parts for soldering... it's nice when one part can be drilled to accept another, then you get the benefit of an assembly aid. See the ceramic soldering pad at Micromark which accepts push-pins.
Minimize the number of wires by running the hot lead(s) up the tube, then using the mast itself for a ground (Tom Gorman tip).
Have fun, good luck, and post pix!
Pat M
patmat2350 is offline Find More Posts by patmat2350
Old Dec 17, 2007, 02:52 PM
EMSPAUL is offline
Find More Posts by EMSPAUL
Joined Feb 2005
What scale are you doing this in?
H o scale bulbs do wonders ,l.e.ds work great if the scale is on the larger size.
lets see some picks
Paul
http://www.homeportmodels.com/
EMSPAUL is offline Find More Posts by EMSPAUL
Old Dec 17, 2007, 03:29 PM
norgale is offline
Find More Posts by norgale
Retired for now
Bonita Springs,Fl.
Joined Sep 2007
http://www.rcgroups.com/forums/showthread.php?t=783582
try his link. If it doesn't work look at the very top of the topics under "scale boats" where it says wiring diagrams. Theres on there just for the mast on any boat. Add or subtract from it what you want on your tug. Pete
norgale is offline Find More Posts by norgale
Old Dec 17, 2007, 04:10 PM
keith S is offline
Find More Posts by keith S
r/c ships and workboats
bellingham, wa
Joined May 2006
Welcome to the group. Question, as to what type of modern tug mast as there are different types base on the type tug as well. Some are square tubed, triangled, and others round tubed. If you follow all the previous advise, you should be able to create any style of modern mast.
keith S is offline Find More Posts by keith S
Old Dec 17, 2007, 06:16 PM
Umi_Ryuzuki is offline
Find More Posts by Umi_Ryuzuki
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
This is a good summary of Nav lighting..
http://www.rcgroups.com/forums/showthread.php?t=713996
It is one of the threads linked in the Past Reviews and Build up thread.
I think everyone has pointed out the basics of Mast construction.
Solder, drilled or recessed contact points, and jigs...
These are a few different masts I have constructed of brass...
Umi_Ryuzuki is offline Find More Posts by Umi_Ryuzuki
Old Dec 17, 2007, 06:47 PM
CG Bob is offline
Find More Posts by CG Bob
KC8WPF
CG Bob's Avatar
Euclid, Ohio, United States
Joined Sep 2004
You want to look at Part C of the NavRules, which deals with lights and shapes. The tugboat will have a specific set of navigation lights (side lights, mast head light(s), & stern light) for its length, over or under 50 meters. The actual towing lights are the same regardless of the size of the tugboat or towing vessel; and indicate the length of tow, over or under 200m. Be prepared to install a few switches (manual or rc) as well, as not all of the lights are used by all tugs all of the time. Six switches will get you the tug light combinations shown here: 1 - side lights and mast head light; 2 - white stern light (could be combined with #1, not good for some Inland rules); 3 - 2nd masthead light; 4 - 3rd masthead light; 5 - yellow towing light; 6 - 3nd yellow towing light for Inland rules.
The following diagrams are generic in nature, and are of various towing combinations. There are other lights needed as well, for vessel rectricted in ability to manuever or vessel not under comand.
CG Bob is offline Find More Posts by CG Bob
Old Dec 17, 2007, 07:39 PM
Captain at the helm
london
Joined Dec 2007
WOW!!
I am overwhelmed at the response and help so far!
The TUG will be 1.50 scale; I am not sure just what mast will be yet probably hollow brass and maybe part enclosed at the base.
I intend to try and create one from different types by using what I like from ones I like.
It will have quite a lot of lights based on the current rules for sight rather than direction.
I am new to this so have to first of all get the right tools for the job, and of course the right materials such as brass rod and hollow brass tubing, silver solder and the right gun to do the job not sure what that will be?
Once I get underway I will post pictures of my progress but it will be after the festive season now.
Thanks for all the advice and help and please if you think you have more it will be humbly received.
Regards
Captain at the helm
Old Dec 17, 2007, 09:59 PM
toesup is offline
Find More Posts by toesup
USA'd ex Brit
toesup's Avatar
Back.. In California
Joined Aug 2006
Originally Posted by captain at the
....please if you think you have more it will be humbly received.
Have a look at some of the details on this..
http://www.shipmodels.info/mwphpBB2/...er=asc&start=0
Might give you something to aim for...
toesup is offline Find More Posts by toesup
Old Dec 22, 2007, 11:52 AM
Adam66 is offline
Find More Posts by Adam66
Netherlands
Joined May 2004
The main mast of the AHTS Smit Kamara under construction in 1:50.
All done with brass tube and rod, and plain solder.
And an other one
Adam66 is offline Find More Posts by Adam66
Old Dec 22, 2007, 12:38 PM
Sea Dragon-Lover
PDX, OR
Joined Dec 2002
Adam66,
Gorgeous work. Is this AHTS a new addition to your Wagenborg fleet, or
will you paint it in the actual Smit Colors?
Start a new thread with a build up when you get a chance we want to see
the rest of the boat....
Old Dec 23, 2007, 05:38 AM
Adam66 is offline
Netherlands
Joined May 2004
Umi,
The "Wagenborg fleet" is no longer mine. Last spring I have sold the last ship of the fleet, the Waterman, to make space for the Smit Kamara.
In schipmodelling I have gone back to my "roots", and this is building (offshore related vessels) in 1:50.
This is a scale I like the most.
So the Smit Kamara comes in the orignal Smit colour, and she will fit perfectly with the other ships in my fleet, the AHTS Smit-LLoyd 123 and the most beautiful tug ever build, the oceangoing salvage tug Zwarte Zee.
A build log is a bit difficult for me, because my english is not that good to discribe in details how i have done things.
I will try to write a very summier log with pics.
One pictures tells more the hunderd words
Old Dec 23, 2007, 12:01 PM
Boatfox is offline
Give the dog a bone
Boatfox's Avatar
USA, NV, Las Vegas
Joined Aug 2005
Originally Posted by Adam66
Umi,
.....A build log is a bit difficult for me, because my english is not that good to discribe in details how i have done things.......
Yes pictures please. We appreciate it.
Old Dec 23, 2007, 05:02 PM
bigford is offline
Find More Posts by bigford
master boat slacker
USA, NY, Mastic Beach
Joined Feb 2006
LOT OF PIC'S
she will be a very nice ship in 1/50
bigford is offline Find More Posts by bigford
Build Log Building The Lackawanna Tug For My Father [ssssh! Itís a Secret.] scubber Scale Boats 56 Jan 02, 2014 02:18 AM
Build Log Scratch building the Erreka tug in 1:32 Capt_Christo Scale Boats 73 Jul 15, 2008 10:45 PM
