My A-10 build log
Hi everyone this is going to be my build log. The main reason I am making a build log is to show the steps that I made to build a awesome A-10. The first thing you’ll notice is that I cut the canopy out because the stock battery bay is a joke. I hope my pictures and build log help or inspire more people to build this awesome plane.
On mine, I cut some 3/16" wide carbon fiber strips, used a razor saw to slot the bottom of the wing tip, and slid the carbon fiber strips into the slots and CA'd. Now any wintip that contacts the runway, hits on the carbon fiber, that prevents any runway rash on the wingtips, and doesn't add much weight.
Frank Quote:
Latest blog entry: Spaceship One
The 121 was when the battery (FP EVO25 1800) leveled off after 2.5 mins of WOT. I am useing the 370's because I have a matching pair 3600 kv, I never ran two motors so we will see. I cut the stock 6 blade down to 3 blades and now the motors are at their max amps 11 after the battery levels off about 15 amps on a fresh pack. If it is two slow I'll open up the fans with some 400's, I am going to make the fan very serviceable but now I am working on the wing, will post some more pictures tonight!!!!
This is it for tonight!!! It is 11pm I am going to bed!!
Hey there, noticed your project.
I just finished mine, so I'll share some knowledge. I'm using the GWS brushless motors (3900kv) with a 2050mah 20C 3S. I re-enforced the engine housing with carbon fiber spars. Word of advise, when y lost battery and dumped in the grass, it broke in half right behind the wing, right where that bamboo stick ends. My friends A-10 broke in exactly the same place. I recommend epoxying carbon spars on the inside running the length of the plane. I didn't fiberglass, but I sanded and painted. Here are some pics and a video of it's maiden flight.
Hey guess what I did?? I setup my DX7 for differential thrust; my rudder stick varies the motor speed between the two motors giving me yaw. I have tried it on the carpet and it works great!!! Since I used two different ESCs I had to have some offset in the programming but I can’t believe it works!!! I have attached pictures of my programming (use at your own risk I haven’t used it before). I am going to make another mix to turn this function off so I can try it real high up first lol.
| Thread Tools | |
| Build Log Lumberjack 48, my first build log | ktoey | Slope | 24 | Jan 24, 2007 02:14 AM |
| Discussion Smiley build log: my first home built micro | jconwell | Indoor and Micro Models | 43 | Jan 08, 2007 12:38 AM |
| Gallery ~My Mini SR~ Not "really" a build log... | THUREN | Slope | 53 | May 14, 2006 10:49 AM |
| my $10 build/helper stand... | DbleX | The Builders Workshop | 1 | Nov 21, 2005 02:14 AM |
| 2nd. set of pics my A-10 build | tomme21 | Electric Ducted Fan Jet Talk | 0 | Oct 24, 2005 05:41 PM |
