Old Dec 15, 2007, 11:30 AM
dirtbag1 is offline
Find More Posts by dirtbag1
Joined Dec 2007
Ryobi weed eater engine clutch
Hello everyone, first post.
Question:I have a Ryobi 30cc engine that could be used for a large scale airplane, or something to annoy my neighbors. Problem is i cant figure out how to get the clutch off. Any advice would be greatly appreciated.
I thank you in advance
Dave
dirtbag1 is offline Find More Posts by dirtbag1
Old Dec 15, 2007, 01:00 PM
punkin438 is offline
Find More Posts by punkin438
Fulton.Mississippi
Joined Mar 2006
If it is a weedeater engine there is a screw in the center where the shaft goes.I think it is a torx head but not 100% sure.
punkin438 is offline Find More Posts by punkin438
Old Dec 15, 2007, 01:34 PM
Wayne V is offline
Find More Posts by Wayne V
Wayne V's Avatar
London, Ontario, Canada
Joined Jan 2006
Well on my weedeater brand engine that i'm just starting to convert the clutch was threaded onto the shaft, is there an arrow on the clutch that says "off", if so that is the direction to turn it off.
Wayne V is offline Find More Posts by Wayne V
Old Dec 16, 2007, 08:48 AM
Chip01 is offline
Find More Posts by Chip01
United States, TX, Weatherford
Joined Dec 2006
It is a Torx #20 or 25, taken them off 31 CC, and the 4 Cycle engines too. Once you get entry under the outer clutch housing, the inner clutch mechanism does indeed fit on the threaded output shaft (crankshaft). The inner clutch mechanism is a centrifical arrangement with springs and relies on increased revoltions to engage the outer clutch housing.
The two cycle engine is a basic Homelite engine used in a variety of weed eaters, Ryobi, Troy Built etc.
Cheers,
Chip
Chip01 is offline Find More Posts by Chip01
Old Dec 18, 2007, 09:22 PM
dirtbag1 is offline
Joined Dec 2007
Thanks everyone
Thanks for the tip on the clutch removel, I was ready to take a cutting wheel to it.
Dave
Yippee! R/C Tarantula Weed Eater hall woo Robotics 2 Aug 13, 2006 01:44 AM
Discussion Talon Weed Wacker Engine - Remove clutch? john howell Racing Boats - Internal Combustion 11 Aug 01, 2006 03:57 AM
Weed Eater Conversions ALEX DOUGHTY Engines 3 Aug 19, 2005 09:26 AM
Using a Weed Wacker Engine - How do I do it? gamingguy87 Racing Boats - Internal Combustion 2 Mar 13, 2005 12:44 PM
