Old Dec 15, 2007, 07:51 AM
chrise2 is offline
Find More Posts by chrise2
Too dumb to upload an avatar.
chrise2's Avatar
On the LIRR somewhere
Joined Jan 2007
Question
How does governor mode work?
Governor mode is when the ESC holds the heli at a constant head speed no matter what the blade pitch, right? I have an ESC with governor mode because I'm too chicken to turn it on. Its a hobby wing esc and not a fancy cc esc so its just on or off.
My questions are more of using governor mode. I have this fear of when I put the ESC in governor mode, the heli will spool up to 100% when i plug in the battery. Does governor mode only kick in above a certain throttle setting from the TX? Basically, what are the steps to powering up the heli in governor mode?
chrise2 is offline Find More Posts by chrise2
Old Dec 15, 2007, 08:02 AM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
The throttle setting determines the speed.
You plug in the battery with the flight mode set to normal, throttle off.
If the ESC has a slow start then you flip to idle up with a flat throttle curve.
Adjusting the % in the curve adjusts the head speed.
If the ESC does not have a slow start then your normal curve is used to spool up, after which you switch to idle up.
Experiment with the blades removed for safety!
Are you sure the H-wing does governor?
I know it is on the programming card, but AFAIK it is not implemented in the ESC.
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Old Dec 15, 2007, 08:13 AM
chrise2 is offline
chrise2's Avatar
Joined Jan 2007
I assumed it would because it was on the program card. I have this guy:
http://www.helidirect.com/product_in...oducts_id=4407
Maybe it doesn't.
Old Dec 15, 2007, 08:25 AM
pmackenzie's Avatar
Joined Dec 2002
You can see if it is working by just running up the motor out of the heli.
Don't do anything to your curves.
With it enabled if you load the motor up with your finger against the motor shaft it should hold speed.
When you release it it often oscillates in speed while it tries to re-establish the set speed.
Try it both enabled and disabled to see if there is any difference.
I know on my 18 amp H-wings it did not work, but I bought them a while ago.
(You can change the songs on them - a much more useful feature )
( It is easier to do this test with an outrunner motor because you can get more load due to the larger diameter)
Pat MacKenzie
Old Dec 15, 2007, 11:42 AM
chrise2 is offline
chrise2's Avatar
Joined Jan 2007
Yeah. I was thinking of setting it to Jingle Bells for the holiday season. Way more useful than governor mode.
Does CC-25 Governor Mode work? bikenboatn Mini Helis 7 Nov 19, 2005 03:19 PM
How does RFFS and Actuators work?????? putt_13 Scratchbuilt Indoor and Micro Models 5 Aug 14, 2002 08:33 PM
how does a brushless motor work?? I FO nut Power Systems 4 May 31, 2002 08:13 PM
How does the govenor mode on a brushless ESC work? bradpaul Power Systems 0 May 18, 2002 12:46 PM
How does this all work? Teamairplane Electric Plane Talk 5 May 27, 2001 05:20 PM
