Old Dec 13, 2007, 12:28 PM
golem is offline
Find More Posts by golem
golem's Avatar
Maryland, USA
Joined Mar 2006
Question
Rewinding the unworthy...2410 suggestions solicited.
'Tis that time of year when we find more time to construct than fly so I figured I might as well change out that slightly toasted wire on my old BM2410-08. She still works as new but was wondering if I might be able to squeeze a bit more out of her. I found many a thread pertaining to rewinding the 2410's but none really specified successful torque winds.
I just ran mine up in stock form and am seeing the expected performance - GWS9x5HD/9.94v/7.7a/6,900rpm/493g/64%ef. I'm sure a stronger battery able to hold voltage up would allow 550g+. What I'm hoping for is that someone can advise of a tested wind that will allow >650g thrust and >30mph pitch speed using a minimum of 9" prop while being somewhat dependable. Pie-in-the-sky?
Cheers,
golem
golem is offline Find More Posts by golem
Old Dec 14, 2007, 09:34 AM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
I would wind it a 5 or 6 turns WYE terminated with 2 strands of 26 AWG wire or a single strand of 24 AWG. That will allow for about 18 Amps current and a fairly efficient motor compared to the spaghetti winds Tower Pro uses. You might even try 22 AWG, but I am unsure if 22 will squeeze in there. 5 turns will give about 1200 or so kv, six will run around 1000 I think.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
