This is my third Opus
no hardware other than motor mount lightest yet 57g. The “22 inch” fuse pattern is cautiously too long. Bevel top inside edge, optional. I suggest, first, cut in motor mount slot, then trim ‘fuse’ to 20 inches then cut fin slot and last, glue fuse panels Not as easy to build as a profile but much, much stronger and no carbon or bamboo required on blue single side fanfold. …edit 23dec… The fuselage sides are twisted … no angle cut required. This twist occurs naturally during build process. Cut two fuselage panels. Glue nose section flat together (like in a vice) an inch or so. After glue sets, remove from vise, twist tail section open 90 degrees (I use a 2inch steel cube covered wax paper) and glue two inch length in front of fin cutout. At this point every thing is cock eyed, not to worry (yet). After glue sets, place fuselage on flat surface and glue length from nose to tail. Top fuse-panel line must be straight, bottom fuse-panel line (on table surface) will be curved (like drawing an >arc< on paper), not to worry (yet), the fuse-sides will twist (monocock) here sets part of its strength the OPUS. Now the worry part, glue wing to fuse… Maintain desired dihedral AND push that >arc< to a straight line. No effort or force required just patience waiting for glue to set. I start at tail with hot melt and apply about 2 inches at a time. Glue second wing panel, then flip model and glue underside wing to fuse, keep it sparse a little dab of hot melt goes a long way. At first, I found it easier to cut motor mount slot before gluing wings. BOXHEAD found a much better technique, a twist off bottle cap motor mount. See detail in post 44 and 53. TNX Box! dubbed Ducks Guts Maiden …19 dec 07 dihedral one inch each tip zero degree reflex, vertical roll unlimited fantastic s l o w dead stick glide Video http://www.rcgroups.com/forums/showt...87#post8767340 and post 65 http://www.rcgroups.com/forums/showt...=785530&page=5 150g (5.25oz) no batt 24g 1500kv UH pink-wonder motor APC 7X5 apx 80W on 3-cell She is quick and wild! Opus (2.25 inch each tip) is more a new pilot entertainer than Ducks Guts Opus 2.25 each tip AND elevator/rudder (verses elevon) post # 55 is a docile trainer
Dekan,
Thank you. Lazertoyz http://www.ncweb.com/biz/dan/Motors.html and not tested yet 50W baby sister weighed in at 9g, ain’t she sweet? I will probably buy a second 9g and try a twin tractor Opus-71 |
Gramps I have flown my Mini Arrow.
http://www.rcgroups.com/forums/showt...20#post8740957 I have only flown it 2s at the moment, too chicken to to try it 3s as most of the time unless it vey low I have problem telling which way up it is. Very tight loops even on 50% rates, very hi rate of roll. It needs a much better pilot. My FB who flys very hi speed ducted fan planes....refused to fly it. He said "it hurt his eyes trying to fly someting that small"! |
| Thread Tools | |
| Discussion 3.5 oz plane | UFly | Foamies (Scratchbuilt) | 8 | Dec 17, 2006 03:24 AM |
| 3.5 oz carbon fly | sloper steve | Parkflyers | 29 | Jan 18, 2004 01:07 PM |
| 3.5 oz Mosquito Class | MrThermal | Indoor and Micro Models | 2 | Apr 16, 2002 07:31 AM |
