Old Mar 05, 2008, 09:17 AM
P. Tritle is offline
Find More Posts by P. Tritle
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Back in the Saddle Again
After getting some other projects buttoned up I've been able to get back on the CC in a serious fashion.
The last of the side planking is on now, and the first four are on the bottom. Hope to get the better part of the bottom planked today. Then, the fun begins on the deck -- which is my favorite part of building these old mahogany boats.
PAT
P. Tritle is offline Find More Posts by P. Tritle
Old Mar 05, 2008, 08:54 PM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Planking the Bottom
Well, didn't make it as far as planned today, but got all but 4 planks are in place. Will get on those in the morning, then it's on to the top side.
PAT
Old Mar 05, 2008, 09:00 PM
green-boat is offline
Find More Posts by green-boat
Boats on the brain!!
green-boat's Avatar
Arnold, Mo.
Joined Jul 2005
There's still a few hour left in the day. LOL
Looks great so far.
green-boat is offline Find More Posts by green-boat
Old Mar 05, 2008, 09:16 PM
Aerominded is offline
Find More Posts by Aerominded
Monterey Bay California
Joined Feb 2004
Ahhh, Mahogany...
Looking great, Pat!
Aerominded is offline Find More Posts by Aerominded
Old Mar 10, 2008, 09:31 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Finishing Up the Hull Planking
The last of the bottom planking is on, and the stem cap has been molded and glued in place. The stem cap was formed using a heated plank bender. The template provided in the kit was used to get the preliminary shape bent into the planks before the 3 laminations were glued in place. Once the glue had dried, the cap was carved to shape using a sharp wood chisel and block sanded into final contour.
Old Mar 10, 2008, 09:34 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Getting Started on the Deck Planking
The rpeliminary centerline and edge planking were glued in place per the instructions. The next step will be the fist plastic caulk strips, then the fill planking will get underway.
PAT
Old Mar 13, 2008, 11:42 AM
Tug Lover is offline
Find More Posts by Tug Lover
Tugs & Bugs
Bronx NY
Joined Mar 2005
Stunning work, getting there for sure.....Ivan!
Tug Lover is offline Find More Posts by Tug Lover
Old Mar 25, 2008, 07:50 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Deck Planking is underway
Got a real good start planking the decks yesterday morning. Looks like the last of the wood will go on today, then it'll be time to move it all outside and start sanding -- a messy process to be sure. Things are starting to get exciting now!!!
PAT
Old Mar 25, 2008, 02:28 PM
Predreadnut is offline
Find More Posts by Predreadnut
Predreadnut's Avatar
Joined Jul 2007
Looking very good.
Predreadnut is offline Find More Posts by Predreadnut
Old Apr 08, 2008, 09:11 PM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
The Last of the Mahogany is On!!!
Finished up the last of the planking late this afternoon. It began with the engine hatch cover, then on to the 1/8 sq. planks on the sideboards. There was a good bit of fitting required there, bit it all went well. And finally, the transom planking was added.
Once all the planks were trimmed, the detail sanding began. At this point the deck is pretty well done, and the easy parts of the hull have been smoothed. Tomorrow its on to the hard parts.
PAT
Old Apr 22, 2008, 10:34 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
The Grunt Work -- Phaze 1
Been sanding the hull for the last few days and have the planks all trimmed and leveled up. Once sanded, the dust was blown out of the gaps and the entire hull was given a "hand rubbed" application od Minwax Mahogany colored filler putty.
The putty was thinned about 70/30 with lacquer thinner and a glob smeared on with a putty knife. The glob was rubbed into the wood in a circular motion via "finger power". By the end of the day, enough is enough, but I have never found a better way to work the putty all the way into the gaps. Then once the putty was smeared in, the entire hull was rubbed down with an old t-shirt to remove the excess and evenly distribute the stain.
At this point, only a light finish sanding will be needed, then the hull will be stained again, allowed to fully cure, then the glass work will begin.
Old Apr 22, 2008, 10:37 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Fitting the Running Gear
While the putty is curing I figured it would be a great time to cut in the rudder and prop bearing tubes. At this point, the stuffing box is ready to glue in place, but first, I'll fiberglass the bottom of the hull since sanding would be difficult with the stuffing box in place.
PAT
Old Apr 22, 2008, 11:05 AM
toesup is offline
Find More Posts by toesup
USA'd ex Brit
toesup's Avatar
Back.. In California
Joined Aug 2006
Just out of interest...
Are the white lines between the mahogany planks an 'American thing'?... i dont recall seeing other boats having this feature.
toesup is offline Find More Posts by toesup
Old Apr 23, 2008, 08:08 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
toes, The decks on the Chris-Craft's were planked with a narrow gap between each plank. The white lines are the caulking used to seal the gaps. On the model, the caulk strips are simulated with .040 wide white styrene plastic.
PAT
Old Apr 23, 2008, 08:12 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Fiberglassing the Hull Bottom
The rudder and stuffing box was removed and the hull bottom fiberglassed with 5 oz. cloth and West Systems resin. The area around the stuffing box will be puttied and sanded, then the tube glued in place and faired into the hull with WS and Micro Ballons.
Chris Craft Triple Cockpit Barrel Back cpaxson Scale Boats 26 Jan 31, 2010 11:02 PM
Chris Craft Barrel Back houfek Dock Talk 4 Sep 27, 2004 03:21 PM
Dumas 1940 Chris Craft Barrel back kit richphoto Boats (FS/W) 2 May 12, 2003 09:29 PM
Dumas Chris Craft Barrel Back 1940 boat kit richphoto Aircraft - Electric - Airplanes (FS/W) 2 May 12, 2003 01:31 PM
