Old Jan 14, 2008, 09:18 AM
P. Tritle is offline
Find More Posts by P. Tritle
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Fitting the Sub-Deck
The 1/16 play sub-deck was fitted and trimmed then glued in place. The 3 foreward deck sections will be fitted and glued in next, then it'll be time to build up the deck edges.
PAT
P. Tritle is offline Find More Posts by P. Tritle
Old Jan 14, 2008, 04:46 PM
Tug Lover is offline
Find More Posts by Tug Lover
Tugs & Bugs
Bronx NY
Joined Mar 2005
This is looking sweeeeeeet....Ivan!
Tug Lover is offline Find More Posts by Tug Lover
Old Jan 14, 2008, 05:38 PM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Ivan, Got the sideboards built up today. With the exception of getting the transom sub layer in place she's ready for mahogany. Now it's getting to be fun!!!!!
PAT
Old Jan 16, 2008, 09:38 PM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Adding the Deck Sheer Fill
The fill on the side deck sheers is laminated using several layers of 1/8 X 1/32 balsa glued in on edge, then trimmed to shape and sanded into contour.
Old Jan 16, 2008, 09:41 PM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Fitting the Transom Sub Planking
The plywood transom is glued in place, trimmed and sanded to contour.
Old Jan 16, 2008, 09:43 PM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Final Prep for Planking
And finally, the entire hull is detail sanded and the minor boo-boo's filled with balsa colored filler. At this point, the hull is finished and we're ready to start the mahogany planking process.
PAT
Old Jan 16, 2008, 10:08 PM
woodybob is online now
Find More Posts by woodybob
WooHoo!
woodybob's Avatar
Lake Balboa, CA
Joined Jun 2007
Looks great Pat. Congratulations. You gonna slap the Mahogany on as Dumas would have you or try it with proportional dividers?
woodybob is online now Find More Posts by woodybob
Old Jan 16, 2008, 10:17 PM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Bob, I plan to plank it up as per the instructions. If those curved sideboards are anything like the Typhoon, there will be plenty of dividing, beveling and tapering going on anyway.
PAT
Old Jan 16, 2008, 10:59 PM
Kmot is online now
Find More Posts by Kmot
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
I see no balsa or other dust anywhere. What do you use when sanding to keep the dust down?
Kmot is online now Find More Posts by Kmot
Old Jan 17, 2008, 08:09 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
K, Actually, the pictures were taken after the big stuff was cleaned up. The shop is really small compared to some, so frequent cleaning is the order of the day.
But, one way I've found to keep the dust under control is to carve as much, and sand as little as possible. For shaping the deck edges I use a 1" wide Craftsman wood chisel to "carve" the basic shape, then sand to the final finish using a smal vibrator sander ($9.00 at Harbor Freight). Then once the sanding is done, the bench is wiped down with a damp towel and the floor gets swept.
PAT
Old Jan 17, 2008, 10:39 AM
H.Lauer is offline
Find More Posts by H.Lauer
H.Lauer's Avatar
Camden Maine
Joined Feb 2005
Hatch problem....
Hi Pat,
Your boat is coming along nicely. I still don't know how you work so fast.
The main hatch on my boat "flattened" out all by itself so I went back and added more frames. It cured the problem.This was after it was planked. It might be easier to do this before you plank yours. just a thought....
Harry
H.Lauer is offline Find More Posts by H.Lauer
Old Jan 17, 2008, 07:02 PM
Bud Faulkner is offline
Find More Posts by Bud Faulkner
Bud Faulkner's Avatar
Mt Airy Maryland
Joined Aug 2004
Pat, what are you using to glue your mahogany planking with?
Bud Faulkner is offline Find More Posts by Bud Faulkner
Old Jan 21, 2008, 09:42 AM
Tugs & Bugs
Bronx NY
Joined Mar 2005
PAT, looking great, soon the running hardwear will be in her....WOW!...as always incredible!
Old Jan 21, 2008, 10:41 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Bud, I'll use medium Cya to glue up the planks. The hull will be marked with the plank location and the glue applied there. The plank will be primed with kicker and applied to the preglued surface. Doing that way requires accuracy in putting the plank in place, but after doing a few of these I find it the quickest and easiest to do it this way.
Tug, Once the planking goes on, then we get to started drilling holes in the bottom and fitting the running hardware. Then the fiberglass work can begin.
PAT
Old Jan 21, 2008, 08:28 PM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Planking Has Begun
Got started planking the hull sides today. The first 3 went on nice and straight, but the fourth one was a bit of a stretch, so will start looking for some curved (warped) sticks to do the 5th. So far, so good.
PAT
Chris Craft Triple Cockpit Barrel Back cpaxson Scale Boats 26 Jan 31, 2010 11:02 PM
Chris Craft Barrel Back houfek Dock Talk 4 Sep 27, 2004 03:21 PM
Dumas 1940 Chris Craft Barrel back kit richphoto Boats (FS/W) 2 May 12, 2003 09:29 PM
Dumas Chris Craft Barrel Back 1940 boat kit richphoto Aircraft - Electric - Airplanes (FS/W) 2 May 12, 2003 01:31 PM
