I'm not sure why anyone would want to modify the existing airfoil with all the terrific airfoils we have available today. Why not set up and make a set of 3014 0r 3021 ribs?
Just my thoughts on it. Jack |
Latest blog entry: The BEST!
Joined Jun 2005
It isn't necessary to deepen any rib notches or trim any shear webs. Just get a couple pieces of aluminum identical in thickness to the original spar and at least as long. Screw them to something like a scrap 2x4 a spar's width apart and attach something at one end to serve as a stop-block. Laminate your carbon to the spar, let cure and then slide it into the jig carbon-side-down. Then simply plane/sand the spar to the correct thickness. Simple, neat and works with tapered carbon strips, too!
Kevlar tow is easier to work with and a better product for wrapping spars. See: http://www.rcgroups.com/forums/showthread.php?t=587629 for a post by Little Flyer with photos. The thread is closed, but he has lots of Kevlar (and Carbon tow) available. |
Dallas TX
In the age of high tech design it is somewhat silly to design wings for bi-directional loading. Spar failure is generally identified as a compression failure to the upper cap. The major lift force occurs at about 60% of each half of the wing, with the pressure of compression constantly increasing to the wing root. One can increase spar depth by simply rotating the upper spar cap 90 degrees while securing it to a plane of sheeting so that the sideway resistance to spar motion is improved (plate wing concept). Laminating top spar from the region of maximum lift to root, making it square in cross section, is another simple technique to intensify spar incompressibility. The bottom spar is attached to the top spar by a web of vertical material typically. A fancier construction can use a horizontal grain for the base web core material while using vertical grain front and back laminations for the area of greatest stress (balsa plywood). This tapers the laminated spar with its web transfer to match the build up of compression stress. As the upper spar is deflected, the tension buildup in the lower spar increases with web coupling reinforcing straightness, thus a bit of stable film on balsa is a zealous overkill. If curious, take a strip of 8 lb balsa and attempt to pull it apart – you will be amazed at its strength; whereas, pushing it together - it will snap easily. Obviously I am using a wood standard, however the phylosophy is adaptable to exotic materials. Have fun making lighter wings this way. Rib height can reduce spar material as proved by the old (extremely strong) MB 253515. [Mine was built with balsa spars for super light.]
