Old Aug 18, 2012, 09:03 AM
sharonx is offline
Find More Posts by sharonx
sharonx's Avatar
Originally Posted by Barn-E-Stormer View Post
Much much more effects
http://www.ebay.com/itm/110906344045...84.m1439.l2649
sharonx is offline Find More Posts by sharonx
Old Aug 21, 2012, 04:32 PM
digitalight is offline
Find More Posts by digitalight
United States, TX, Pflugerville
Joined Apr 2011
Super Dave and his IFO night flying.
Central Texas welcomes Super Dave to night flying with his IFO!
digitalight is offline Find More Posts by digitalight
Old Aug 21, 2012, 10:18 PM
harrymc is offline
Find More Posts by harrymc
Just Happy To Be Here!!!
harrymc's Avatar
United States, AL, Tuscaloosa
Joined Nov 2004
Cool!!! Let's see a picture of it sittin' still with the lights on.
harrymc is offline Find More Posts by harrymc
Old Aug 22, 2012, 10:34 AM
MAP123 is offline
Find More Posts by MAP123
AMA 964040
MAP123's Avatar
United States, NY, Fulton
Joined Oct 2008
Originally Posted by sharonx View Post
Have you used that controller? I'm thinking about getting a similar controller and and LED setup:
http://www.amazon.com/TaoTronics-TT-...ref=pd_cp_hi_2
Did you install the whole controller, or take off the casing and shorten the wires? It looks like it would be pretty heavy as is, but I'm sure a lot of weight could be saved.
MAP123 is offline Find More Posts by MAP123
Old Aug 22, 2012, 03:24 PM
Barn-E-Stormer is offline
Find More Posts by Barn-E-Stormer
Dark Yet??
Barn-E-Stormer's Avatar
United States, VA, Narrows
Joined Dec 2009
That controller looks heavy. Most of those other effects are useless. It's hard to fly with any kind of flashing or chasing lights. I do like the strobe and slow fade effect.
Barn-E-Stormer is offline Find More Posts by Barn-E-Stormer
Old Aug 22, 2012, 03:41 PM
Nin3rsAllDay is offline
Find More Posts by Nin3rsAllDay
Nin3rsAllDay's Avatar
United States, NV, Las Vegas
Joined Jun 2012
If you don't need to change the effects from the ground while flying you can always contact member Bombay as he sells both regular l.e.d. strip and the rgb l.e.d strip contollers that are light weight.
http://www.rcgroups.com/forums/showthread.php?t=1682549
Nin3rsAllDay is offline Find More Posts by Nin3rsAllDay
Old Aug 22, 2012, 05:18 PM
Dark Yet??
Joined Dec 2009
Yes it should be noted that the remote only works from about 20 feet. I had to fly by close and slow to have someone change the light mode.
Old Aug 22, 2012, 10:18 PM
Aerocowboy is offline
Find More Posts by Aerocowboy
Aerocowboy's Avatar
United States, TX, College Station
Joined Jun 2012
Originally Posted by Aerocowboy View Post
My Parkzone T-28 equipped for night. Running directly off the 3S balance connector for now. I'd like to add a brushed speed control soon to dim it down a bit for flying in total darkness.
Put 4 batteries through it last night -- I *love* this. Very cool.
Attachment 5077989
Attachment 5077990
Just installed a brushed speed controller (Turnigy 20A -- overkill) as a voltage regulator, so now my DX8's Aux1 dial knob is a dimmer knob, with a range from 'dimly lit' to 'full power'. Additionally, I programmed in an offset mix on the 3-position Flaps switch that basically operates as an OFF/MID/HIGH range selector for the dimmer switch. This way I can't dumb-thumb the dial wheel into complete darkness -- I have to use the actual off switch on the other side of the TX to go dark.
Should be cool. I'll do a test flight tomorrow night.
Aerocowboy is offline Find More Posts by Aerocowboy
Old Aug 23, 2012, 02:52 AM
ALEX HEWSON is online now
Find More Posts by ALEX HEWSON
Remember... Fly for fun!
ALEX HEWSON's Avatar
Christchurch, New Zealand
Joined Jul 2005
This is my new night flyer:
Night Rocket Glider test flight (1 min 32 sec)
ALEX HEWSON is online now Find More Posts by ALEX HEWSON
Old Aug 23, 2012, 10:18 AM
MAP123 is offline
AMA 964040
MAP123's Avatar
Joined Oct 2008
Originally Posted by ALEX HEWSON View Post
OK, now let's see a night video! Hopefully you can see it better in person than what we see in the video, because it looks like a streak that very quickly fades to nothing. Then again, it might be easier to see at night while it's lit up against the dark night sky.
The rocket gliders that I've seen have all been much bigger, and therefore launch much more slowly, about the same as what you would expect of a motor glider. Yours, on the other hand, is a rocket that you can also glide. Well done.
Old Aug 23, 2012, 08:11 PM
mclarkson is offline
Find More Posts by mclarkson
Must not buy more planes!
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
Very cool!
mclarkson is offline Find More Posts by mclarkson
Old Aug 24, 2012, 10:31 AM
KFC is offline
KFC
Find More Posts by KFC
KFC
Blue Foam Master!!!
KFC's Avatar
United States, KY, Hanson
Joined May 2007
I did pretty much the same thing with my rocket wing a while back. You can see it at about 3:00 into the video.
seff 2011 night bowling (3 min 22 sec)
KFC is offline Find More Posts by KFC
Old Aug 26, 2012, 06:32 PM
Joined Jul 2005
Following on, here are the pics and a video:
Forsyth 2012: Micro Rocket Glider (0 min 10 sec)
Old Aug 26, 2012, 10:01 PM
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
Wicked!
Old Aug 26, 2012, 10:52 PM
MAP123 is offline
AMA 964040
MAP123's Avatar
Joined Oct 2008
Very cool, Alex. I love those night pics with the rocket exhaust. I still think it's crazy, but it looks like it could also be a lot of fun.
Short flight time, though. Can you launch it straight up? It seems to be wasting a lot of the launch going sideways ... going sideways really fast! I'm amazed it didn't do a half of a loop right into the ground, actually. I'm not sure I could handle that as well as you did, and in the dark. Nice flying. Does it pull around that fast because of the trim for gliding? If that's the case, maybe you could either readjust the CG for it to be closer to neutral, or use a launch preset that zeros out the trim so you get a straight launch, kind of the opposite of what a launch preset does for a DLG.
Post your night bats pics here! EdBall Flies! Electric Plane Talk 11 May 28, 2004 01:07 PM
Post your Viper Twin Pics Here! Zagi-Extreme Foamies (Kits) 3 Mar 30, 2003 10:04 PM
Post Your Zagi 400X Pics Here HavingFun2002 Foamies (Kits) 63 Feb 02, 2003 02:21 AM
Post your Aeroflakes meet pics here Jgardner Scratchbuilt Indoor and Micro Models 38 Jan 24, 2003 04:44 PM
Post your fun fly pics here. Paul Susbauer 3D / Fun Fly Fuel Planes 8 Jan 23, 2003 04:11 AM
