Old Jul 30, 2012, 01:17 PM
When in doubt, gas it!
KTMRacr's Avatar
United States, KS, Spring Hill
Joined Dec 2010
Originally Posted by jasmine2501 View Post
Be careful, I have a plane that is to bright to fly. It hurts your eyes to look at it.
The white LEDs are the brightest by far. Followed by blue, green, and red (in that approximate order). You do want to be concerned about weight on smaller planes. My 33" 3DHS Extra has 180 lights on it and I could definitely feel the weight after I added them. It still flies pretty good and is a little better in a breeze, but it was noticeable. I also had to add some bracing to the wings! The Hacker motor I had on it was OK before I put the lights on, after that vertical performance was noticeably retarded. I ended up putting a little bit bigger Motrolfly on it and it does fine with that.
There would be a number of ways you could "tone down the brightness" if you found it to be too much. A small GWS brushed ESC is one way. You could also probably do something with some diodes as well.
I sure enjoy the night flying in the hot summer! I've flown 10 times as much at night as I have in the day for the past few months! Lots o fun...
KTMRacr is offline Find More Posts by KTMRacr
Old Jul 30, 2012, 02:18 PM
Rocket Programmer
jasmine2501's Avatar
United States, CO, Golden
Joined Jul 2007
Yes, I show those methods in my video, and explain some of the issues with the LED strips and alternative methods. Each method has advantages and disadvantages.
All About LEDs for RC Night Flying (23 min 52 sec)
jasmine2501 is offline Find More Posts by jasmine2501
Old Jul 30, 2012, 06:41 PM
DS Addict
ALEX HEWSON's Avatar
Christchurch, New Zealand
Joined Jul 2005
My old T-rex 450 night flyer initially had the canopy and boom lights rinning off the main 3s pack. But the halo effect was terrible! Orientation was almost impossible!
Solution was a small 250mah 2s pack velcroed underneath.
T-Rex 450 Night Flight - Forsyth 2011 (2 min 2 sec)
ALEX HEWSON is offline Find More Posts by ALEX HEWSON
Old Aug 06, 2012, 08:35 AM
Dark Yet??
Barn-E-Stormer's Avatar
United States, VA, Narrows
Joined Dec 2009
I have used a Hobby King RC switch and some diodes for a dimmer switch.
Dimmer Switch1.wmv (2 min 9 sec)
Barn-E-Stormer is offline Find More Posts by Barn-E-Stormer
Old Aug 12, 2012, 04:42 PM
Aerocowboy's Avatar
United States, TX, College Station
Joined Jun 2012
My Parkzone T-28 equipped for night. Running directly off the 3S balance connector for now. I'd like to add a brushed speed control soon to dim it down a bit for flying in total darkness.
Put 4 batteries through it last night -- I *love* this. Very cool.
Description:
Description:
Aerocowboy is offline Find More Posts by Aerocowboy
Old Aug 12, 2012, 06:03 PM
Dark Yet??
Joined Dec 2009
I did a double foamy build. One has a RGB controller. It was a lot of extra work to wire 3 circuits but it has some nice effects. It has dimming, strobe, chase and random flash, plus 12 combinations of on/off.
Old Aug 12, 2012, 06:09 PM
Dark Yet??
Joined Dec 2009
The second one I put a strip of LED behind the fuse brace. It looks like a flourescent light bulb. On the SFG I put a line one inch above the wing, so it shines on the wing and fuse. I like this one the best.
Old Aug 12, 2012, 06:22 PM
KTMRacr's Avatar
Joined Dec 2010
I can tell a lot of effort went into the last three posts!!! They all look great!
I always wanted to put strips like you did on the bottom of your wing, but MAN is that a lot of soldering!!!!!!!
Very nice, thanks for sharing, and have fun with em!
Old Aug 13, 2012, 06:47 AM
Dark Yet??
Joined Dec 2009
Maiden flight of the RGB foamy.
RGB Foamy (2 min 6 sec)
Old Aug 13, 2012, 11:20 AM
United States, NC, Cary
Joined Apr 2011
Has anyone tried mounting LED on white EPP foam with the LEDs facing inward? It seems like most of the light would still make its way through the foam, although it would be scattered in more directions.
Randino is offline Find More Posts by Randino
Old Aug 13, 2012, 11:36 AM
Dark Yet??
Joined Dec 2009
Yes, it works great. Makes a nice effect. Have seen several Fun Cubs done that way.
Old Aug 13, 2012, 03:21 PM
When pigs fly rc
rcrich's Avatar
USA, NY, Chester
Joined Apr 2008
Barn e stormer
What rgb strip controller did you use?
Rich
rcrich is offline Find More Posts by rcrich
Old Aug 13, 2012, 06:05 PM
Dark Yet??
Joined Dec 2009
RGB controller
http://www.lowpricerc.com/product_in...c0e2ce94965441
Old Aug 15, 2012, 01:24 PM
Joined Jul 2012
Crack Yak 55 32" with 120 LED's Night Fly (1 min 32 sec)
MrDMAX745i is offline Find More Posts by MrDMAX745i
Old Aug 18, 2012, 07:58 AM
sharonx's Avatar
Mugi with fireworks
Mugi night with fireworks (1 min 30 sec)
Mugi 125% with green laser
Mugi Night Flying with chases and lasers haimgil, sharonx (4 min 47 sec)
Quad at fireworks meeting (Mugi with extreme fireworks) - UFO style soundtrack - lets see if you can identify it's source (-:
UFOs Meteors and Dots of Light (2 min 1 sec)
sharonx is offline Find More Posts by sharonx
Post your night bats pics here! EdBall Flies! Electric Plane Talk 11 May 28, 2004 12:07 PM
Post your Viper Twin Pics Here! Zagi-Extreme Foamies (Kits) 3 Mar 30, 2003 09:04 PM
Post Your Zagi 400X Pics Here HavingFun2002 Foamies (Kits) 63 Feb 02, 2003 01:21 AM
Post your Aeroflakes meet pics here Jgardner Indoor and Micro Models 38 Jan 24, 2003 03:44 PM
Post your fun fly pics here. Paul Susbauer 3D / Fun Fly Fuel Planes 8 Jan 23, 2003 03:11 AM
