Old Aug 20, 2009, 11:14 AM
Troy is offline
Find More Posts by Troy
Caution:Makes sharp left turns
Troy's Avatar
United States, CA, Lake Forest
Joined Feb 1999
Night flying my GTP flying car:
http://www.rcgroups.com/forums/showa...mentid=1383319
Troy is offline Find More Posts by Troy
Latest blog entry: Flying Ghost
Old Aug 20, 2009, 08:05 PM
sharonx is offline
Find More Posts by sharonx
sharonx's Avatar
Night Fest in Israel :
night flying (3 min 38 sec)
sharonx is offline Find More Posts by sharonx
Old Sep 01, 2009, 09:51 PM
TriTipTim is offline
Find More Posts by TriTipTim
Addicted To Glass !!!
TriTipTim's Avatar
Glamis,ca
Joined May 2008
Night Flight Glamis California
IFY 60 TWINN Night Flyer (6 min 34 sec)
TriTipTim is offline Find More Posts by TriTipTim
Old Sep 03, 2009, 04:47 PM
muppet61 is offline
Find More Posts by muppet61
Night Flyer
muppet61's Avatar
France, Normandy
Joined Jul 2006
Less light, but more firework...
Le vol de nuit 2 (0 min 53 sec)
Vol de nuit FPV a l'Aigle 9 mai 2009 (2 min 31 sec)
muppet61 is offline Find More Posts by muppet61
Old Sep 03, 2009, 05:42 PM
flyingrally is offline
Find More Posts by flyingrally
Where did Steve go ?
Alexandra
Joined Jul 2007
Thats awesome.
I bet as soon as someone in the industry see's this they will look at putting aeroplanes into real firework displays.
http://vimeo.com/1028051
http://vimeo.com/4619763
flyingrally is offline Find More Posts by flyingrally
Old Sep 06, 2009, 12:52 AM
Darth_Elevator is offline
Find More Posts by Darth_Elevator
How do I change this text?
Darth_Elevator's Avatar
The Beautiful Mountains of Utah
Joined Oct 2006
I put the Hobbycity glow strip LEDs into a 48-inch EPP combat wing. Kudos to Chimaera for coming up with the idea to cut a slit and insert the LED strips sideways into the foam. This makes installation super simple and quick. Cut off a segment of LEDs (they cut apart in groups of three, in between the sets of solder tabs). Solder on two wires to connect a segment to the previous segment, cut a slit in the EPP and slide the LED strip down into the foam. If you want pinpoints of light and brighter diffusion on both sides of the strips, put in a second strip facing the other way. Couldn't be easier. Cut a very shallow strip in between the segments so the wires can also be embedded to reduce drag. Once I finished the lights, I covered the wing with clear 3mil laminate that lets the light shine through brightly. I suppose you could also use transparent or transculent monokote.
Darth_Elevator is offline Find More Posts by Darth_Elevator
Old Sep 06, 2009, 01:47 AM
chimaera is offline
Find More Posts by chimaera
THEY MOSTLY COME OUT AT NIGHT
chimaera's Avatar
Kaysville, Utah
Joined Jul 2005
nice Darth
chimaera is offline Find More Posts by chimaera
Old Sep 06, 2009, 06:15 AM
Alexandra
Joined Jul 2007
Cool Darth but how do you tell which way is up
Old Sep 06, 2009, 02:00 PM
Joined Oct 2006
It's washed out on the pics, but the bottom has pinpoints of light that are much brighter and crisper than the top. Also, the top has a light strip by each wingtip that lights up the wingtips as well as adding sparkle whenever you see the top of the wing.
Old Sep 16, 2009, 08:20 PM
Bombay is offline
Find More Posts by Bombay
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
Brushless Slo-V with glowire and flashers
Not the best pics, but you get the idea.
Bombay is offline Find More Posts by Bombay
Old Sep 25, 2009, 07:46 AM
f4addict is offline
Find More Posts by f4addict
Fly, Crash, Burn,
f4addict's Avatar
United States, CT, Danbury
Joined Jul 2008
i had the first flight on PA mini katana, not in complete dark but during dusk. it was ok, but not that bright as i expected, any suggestions?
f4addict is offline Find More Posts by f4addict
Old Sep 25, 2009, 08:56 AM
warhead_71 is offline
Find More Posts by warhead_71
Always Ready!
warhead_71's Avatar
Chicago, IL
Joined Dec 2006
Yeah, I have a suggestion... wait for it to get dark out. Dusk is not dark enough.
warhead_71 is offline Find More Posts by warhead_71
Old Sep 30, 2009, 06:43 AM
f4addict is offline
Fly, Crash, Burn,
f4addict's Avatar
Joined Jul 2008
you're right warhead,,,, it was ok in dusk but as soon as it turned pitch dark., i need more lights...
Old Sep 30, 2009, 09:28 PM
DRITCH is offline
Find More Posts by DRITCH
DRITCH's Avatar
ST.LOUIS
Joined Aug 2006
First set of glow wire
Two flights in so far. Awesome
DRITCH is offline Find More Posts by DRITCH
Old Sep 30, 2009, 09:49 PM
Bombay is offline
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
Nice. What plane is that?
Post your night bats pics here! EdBall Flies! Electric Plane Talk 11 May 28, 2004 12:07 PM
Post your Viper Twin Pics Here! Zagi-Extreme Foamies (Kits) 3 Mar 30, 2003 09:04 PM
Post Your Zagi 400X Pics Here HavingFun2002 Foamies (Kits) 63 Feb 02, 2003 01:21 AM
Post your Aeroflakes meet pics here Jgardner Scratchbuilt Indoor and Micro Models 38 Jan 24, 2003 03:44 PM
Post your fun fly pics here. Paul Susbauer 3D / Fun Fly Fuel Planes 8 Jan 23, 2003 03:11 AM
