Old Dec 04, 2012, 06:41 AM
Lee is offline
Lee
Find More Posts by Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
I got a couple of E-mails asking where to get the #16D camera. There are some fakes out there but this dealer is the manufacturer.
http://stores.ebay.com/eletoponline3...p2047675.l2563
I like the V2 with the D lens.
Lee
Lee is offline Find More Posts by Lee
Old Dec 06, 2012, 09:28 PM
Timtreo is offline
Find More Posts by Timtreo
Click my name for night blades
Timtreo's Avatar
United States, PA, Warminster
Joined Nov 2011
Thanks for the Link Lee. Ordered the 16G 120deg #16D cam should be here next month hopefully on the next slow boat from China that sets sail after my HK order ordered last month .
Awesome video mclarkson! How did you cut that together like that? And also very befitting song . I thought it was several planes at first, very cool!
Timtreo is offline Find More Posts by Timtreo
Old Dec 07, 2012, 03:22 AM
mclarkson is offline
Find More Posts by mclarkson
Must not buy more planes!
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
Thanks so much, Tim. I was actually trying something a little different in that one - after 150 or so videos, I get a little bored.
[long boring explanation]
I use Adobe Premiere to edit all my videos. I was doing some long exposure photos of one of my planes and rubber-banded one of my little #11 key cameras to the lens barrel, strictly to record motor sounds for another project. I've never shot any footage using a tripod before; I almost always use my 'hatcam' setup.
Shooting in the dark with a tripod opened up some new editing possibilities. I played with achieving light trails in a previous video. In that one, I manually created about 8 copies of the same video, each offset one frame in time and each only 75% as bright as the previous. I put these layers in SCREEN transfer mode, which basically adds the brightness from a layer to the layer below it.
For this one, I wasn't sure if I should use my regular #11, or the one I've JB Welded a fisheye lens onto, so I actually rubber-banded both cameras to my SLR's lens barrel. When I was editing the video together, I synched the two videos and placed one on top of the other in SCREEN transfer mode, allowing me to pick the one that had the best view of every shot.
I found that I liked some of the shots with both cameras. Since they have different lenses, the plane looks slightly different in each so, even if the same section of both videos is running, the perspective is different on each reinforcing the idea that you're looking at two different planes.
Then I decided to use the same effect for most of the cuts. Instead of cutting from A to B, I would start B, but let A continue to run until the plane naturally flew out of frame, if possible.
[/long boring explanation]
Glad you liked it. Remember to subscribe to me on YouTube.
mclarkson is offline Find More Posts by mclarkson
Old Dec 07, 2012, 06:57 PM
Timtreo is offline
Timtreo's Avatar
Joined Nov 2011
That's pretty cool how you did that, thanks for explaining it but still . I have Adobe Premiere Elements 9 but after 2 years I'm still learning the basics of it . I think they should come with an on-line collegiate course. I tried to download the "inspiration browser", which is supposed to be some kind of tutorial I guess, but it never downloads just looks like it's trying to for an hour until I just cancel it. Looks like you are using Premiere Pro which would confuse me even more I'm sure . The screen shot you have there shows "time remapping", that I have never stumbled across on my version. Have any links to an Adobe site or something that might help me get more out of my rather dated Elements 9? I have seen a couple youtube videos with 6 year olds explaining things (still I get confused ). Very cool job again on the video! I'll subscribe to your tube channel (I'm timmytube460 ).
Old Dec 07, 2012, 08:26 PM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
I've used premiere for a long time now... I think a very good place to find help is on the Adobe forums. Over the years I've discovered a few tips for using it...
1. Establish a workflow, and do every video the same way.
2. Learn the keyboard shortcuts
3. Learn to use titles properly and quickly... both the "default" titles and the media ones.
4. Learn to use transitions properly.
5. Don't worry about learning all the fancy effects unless you really need to for something special, focus on learning to be efficient with basic tasks, cutting and arranging clips.
Here's what I do, every time...
1. Create my project, selecting the appropriate edit mode
2. Import ALL the video and stills I want to use.
3. Watch the clips and get a mental picture of my video plan... except with HD which I watch in media player before creating my project
4. I drag each clip and still to the timeline in the order I need them to be.
5. Starting at the beginning, I watch the video clips in order, cutting them for in and out points and deleting unwanted parts.
6. After I make all my cuts, I add my transitions... usually I use the same one for all transitions, and I use the simple ones... dissolve, wipe, cut to black, etc
7. I add my titles after the transitions
8. Add intro and ending, fades, etc
I don't add music to my videos any more, but that changes the workflow. Video editing is tedious, there isn't a way around that.
jasmine2501 is offline Find More Posts by jasmine2501
Old Dec 07, 2012, 10:26 PM
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
My workflow is very similar to yours.
I almost always add music as it gives me a framework to cut around, and forces me to limit the video to 3 minutes or so.
Old Dec 08, 2012, 06:42 AM
Timtreo is offline
Timtreo's Avatar
Joined Nov 2011
Hey thanks guys I'll check out those Adobe forums. That's a good idea to have a whole plan with steps. I like to add music too as I usually cut my clip lengths to total the the whole song time also.
Old Dec 09, 2012, 07:51 PM
jabbey71 is offline
Find More Posts by jabbey71
United States, NC, Greensboro
Joined Mar 2011
quad legs
Hey gb, what are you using for the legs on the night flying quad. thanks
Originally Posted by gbmarsh View Post
Thanks, the LEDs are the high density stick on ones that HobbyKing sells. I used 2x 3 LED segments in the base of the egg pointing forward.
Like this:
Attachment 5226515
Cheers,
Geoff
jabbey71 is offline Find More Posts by jabbey71
Old Dec 09, 2012, 08:31 PM
gbmarsh is offline
Find More Posts by gbmarsh
Wait...what?
gbmarsh's Avatar
Canada, BC, Abbotsford
Joined Sep 2010
Hi jabbey71,
The landing legs are pieces of an old carbon fiber arrow shaft with heat shrink on the ends to keep them from splitting and held in place with zip ties.
Cheers,
Geoff
gbmarsh is offline Find More Posts by gbmarsh
Old Jan 01, 2013, 12:48 PM
phil007 is offline
Find More Posts by phil007
Night Flyer
phil007's Avatar
United States, TX, Round Rock
Joined May 2005
Curtis Youngblood 3D Quad Night Flight (1 min 46 sec)
phil007 is offline Find More Posts by phil007
Old Jan 01, 2013, 01:04 PM
Bombay is offline
Find More Posts by Bombay
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
Phil:
do you have any more info on the quad that was used?
Bombay
Night Flying Accessories for Sale (LEDs, controllers)
Bombay is offline Find More Posts by Bombay
Old Jan 01, 2013, 01:18 PM
phil007 is offline
Night Flyer
phil007's Avatar
Joined May 2005
It will be available soon. http://www.rcgroups.com/forums/showt...1788191&pp=100
Originally Posted by Bombay View Post
Phil:
Bombay
Old Jan 03, 2013, 12:43 AM
JAS3D is offline
Find More Posts by JAS3D
Lowand Fast
JAS3D's Avatar
Australia, QLD, Gold Coast
Joined May 2012
FPV Night Landing practice (1 min 50 sec)
JAS3D is offline Find More Posts by JAS3D
Old Jan 03, 2013, 12:58 AM
harrymc is offline
Find More Posts by harrymc
Just Happy To Be Here!!!
harrymc's Avatar
United States, AL, Tuscaloosa
Joined Nov 2004
Very nice! What aircraft were you using there?
harrymc is offline Find More Posts by harrymc
Old Jan 03, 2013, 01:19 AM
JAS3D is offline
Lowand Fast
JAS3D's Avatar
Joined May 2012
Just a Hobbyking bixler with FPV setup
Post your night bats pics here! EdBall Flies! Electric Plane Talk 11 May 28, 2004 12:07 PM
Post your Viper Twin Pics Here! Zagi-Extreme Foamies (Kits) 3 Mar 30, 2003 09:04 PM
Post Your Zagi 400X Pics Here HavingFun2002 Foamies (Kits) 63 Feb 02, 2003 01:21 AM
Post your Aeroflakes meet pics here Jgardner Scratchbuilt Indoor and Micro Models 38 Jan 24, 2003 03:44 PM
Post your fun fly pics here. Paul Susbauer 3D / Fun Fly Fuel Planes 8 Jan 23, 2003 03:11 AM
