Old Dec 11, 2007, 04:03 PM
foam and tape is offline
Find More Posts by foam and tape
Retardedly intelligent
foam and tape's Avatar
beavercreek,ohio
Joined Jan 2007
Gallery
post your night flyer pics here
looks like we finnaly got the forum
foam and tape is offline Find More Posts by foam and tape
Old Dec 11, 2007, 05:57 PM
Darth_Elevator is offline
Find More Posts by Darth_Elevator
How do I change this text?
Darth_Elevator's Avatar
The Beautiful Mountains of Utah
Joined Oct 2006
I currently have three functional nightflyers in my fleet. A Slow Stick, a geobat-like flying saucer called the "Light Emitting Disc" (LED), and a Glostik.
Darth_Elevator is offline Find More Posts by Darth_Elevator
Old Dec 12, 2007, 04:51 PM
StephanB is offline
Find More Posts by StephanB
Restricted User
StephanB's Avatar
Frankfurt-region, Germany
Joined Mar 2003
Fun
Hi,
at this years inter-ex event we had a nightflying-session. Pilots were wearing caps with small illuminated models of models, so that the audience was able to match the pilot with the model.
http://static.rcgroups.com/forums/at...r-Ex07_238.jpg
Yes, we are a little bit crazy.
more:
http://www.inter-ex.com/english/inte...achtflug01.htm
http://www.inter-ex.com/english/iexoverview1.htm
Stephan
edit: i do not know, why the picture does not show up. Please click the first link.
StephanB is offline Find More Posts by StephanB
Old Dec 13, 2007, 03:08 PM
Captain Speedy is offline
Find More Posts by Captain Speedy
Over the Hill, 3rd Oak Tree on left
Joined Nov 2005
This is cool !
What lights / system are you guys using ? They seem to be very bright.
CS
Captain Speedy is offline Find More Posts by Captain Speedy
Old Dec 13, 2007, 04:10 PM
warhead_71 is offline
Find More Posts by warhead_71
Always Ready!
warhead_71's Avatar
Chicago, IL
Joined Dec 2006
Nerds!
I love it
warhead_71 is offline Find More Posts by warhead_71
Old Dec 13, 2007, 08:02 PM
Atom1025 is offline
Find More Posts by Atom1025
Fly me to the moon...
Atom1025's Avatar
Sacramento
Joined Jun 2005
This is a Ritewing FS48 built to slope.
Atom1025 is offline Find More Posts by Atom1025
Old Dec 14, 2007, 09:35 AM
eran_k is offline
Find More Posts by eran_k
Eventually...I will fly
Israel
Here is mine
Well, congrats on the new forum.
here is my night flyer, it only flew once during daytime to test. i guess it will be after the winter when our nught flying group re-joins.
Eran
eran_k is offline Find More Posts by eran_k
Old Dec 14, 2007, 09:48 AM
StephanB is offline
Restricted User
StephanB's Avatar
Joined Mar 2003
Eran,
that illuminated wing is beautiful. Please tell us more about structure of wing and lighting system.
Thanks.
Stephan
Old Dec 14, 2007, 12:54 PM
ColinB is offline
Find More Posts by ColinB
Canada, BC, Victoria
Joined Mar 2004
Here's mine: GWS Beaver, LED's mounted in drinking straws. Running off 6 or 8 cell nimh motor battery. It is not a clean install - wires and lights just taped on for quick removal. But it works great, and I can fly in pitch dark. The landing lights light the runway when I am several feet above.
Colin
ColinB is offline Find More Posts by ColinB
Old Dec 14, 2007, 01:58 PM
eran_k is offline
Israel
My light system
Originally Posted by StephanB
Eran,
Thanks.
Stephan
First of all thanks for the compliment, Stephan.
This plane is a very simple 3ch trainer sold here and is called bannana. it's originaly designed for a 1/2A Cox engine. i'm using the 400XT on it.
the light are super bright LED'S that i mounted inside each wing bay,one facing foraward and the next fcaing back, i hope it's clear from the picture of the wing before covering.
for wiring i used "magnet wire" and i made three Bus bars one negative in the midlle and a positive bus at the LE and one at the TE.
each LED is solderd to it's own Resistor and they are all connected in paralel.
on each wing tip i stuck two special wide angle LED's just to make sure left and right will be easily visible from any direction.
the tail is ilimuminated by 6 LED's each two inside a drinking straw and attached on the tips of the stabilizes.
at the front i added (this is not on the pictures) one white super led on each side, sligtly facing downward, to aid in landing.
the whole system is powerd by a small old TP730 3S battery, the system is seperated from the rest of the plane electronics.
Hope it's clear
Eran
Old Dec 15, 2007, 07:07 PM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
My Slow Stick with Lights. Here's a short video too, before I added the lights on the edges.
jasmine2501 is offline Find More Posts by jasmine2501
Old Dec 16, 2007, 09:48 AM
_Lunchbox_ is offline
Find More Posts by _Lunchbox_
Hodgehound # 3
_Lunchbox_'s Avatar
Adrian, GA
Joined Mar 2005
Lee, that is insane...
How hard is it to keep up with?
_Lunchbox_ is offline Find More Posts by _Lunchbox_
Old Dec 16, 2007, 12:36 PM
Lee is online now
Lee
Find More Posts by Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
The 36" Roswell Delta and 36" Pinata are fast but easy to fly. I've flown this style of plane for so many years that isn't a big deal. They will both do vertical performance. You just have to watch out for trees and spectators wandering the flying area.
For those of you still to scared to try flying at night...... Night flying isn't harder than day flying if you know your plane and your flying site. I was very anxious the first time I went out in the night but it was great even with faster planes. The plane flies the same in the dark as in the light so as long as you can see your plane well and you know your flying site you will do just fine.
Fly your plane in the light and get it trimmed in with your light system up and running before you try night flying. A trial run also is a good way to make sure you don't have any loose connections. If your light system fails in the dark it's impossible to land the plane and can be hard to find the plane once it's down. In the video I have a small light stick on each plane in case such an occurrence happens but they were not needed. The Christmas lights worked great.
This video doesn't show much background but the Christmas lights are bright enough to fly in the city against city lights which is not true for the glow sticks. Each plane has 10x 12V lights wired directly to my 3S 1320 TP/PL battery in parallel. If one light gets smashed or burns out the rest of the lights will say on. Each plane only has $2 of lights including the wiring.
Nightflying with Pinata flying wing 11-07 (4 min 20 sec)
Lee is online now Find More Posts by Lee
Old Dec 16, 2007, 03:47 PM
Pudknocker71 is offline
Find More Posts by Pudknocker71
Pudknocker71's Avatar
Debary, Fl.
Joined Oct 2007
I keep waiting for Chuck Mangione to start playing. Nice background music.
Flying is not bad either.
Pudknocker71 is offline Find More Posts by Pudknocker71
Post your night bats pics here! EdBall Flies! Electric Plane Talk 11 May 28, 2004 12:07 PM
Post your Viper Twin Pics Here! Zagi-Extreme Foamies (Kits) 3 Mar 30, 2003 09:04 PM
Post Your Zagi 400X Pics Here HavingFun2002 Foamies (Kits) 63 Feb 02, 2003 01:21 AM
Post your Aeroflakes meet pics here Jgardner Scratchbuilt Indoor and Micro Models 38 Jan 24, 2003 03:44 PM
Post your fun fly pics here. Paul Susbauer 3D / Fun Fly Fuel Planes 8 Jan 23, 2003 03:11 AM
