Old Dec 18, 2002, 12:15 AM
rkremser
rkremser
Guest
n/a Posts
loctite red vs blue
What is the difference between loctite blue and red? I was sold red but
I've only recently seen reference to blue.
Old Dec 18, 2002, 02:35 AM
Wilbur Wilburforce
Wilbur Wilburforce
Guest
n/a Posts
Re: loctite red vs blue
Red is permanent, blue is semi-permanent.
Will
Philip Martin
Philip Martin
Guest
n/a Posts
"rkremser" <rkremser & @hotmail.com (remove &)> wrote in message
news:3e000e89$1_2@news.teranews.com...
Red sets HARD, you will be pushed to undo a screw set with this, especially
on a heli (small screws etc). OTOH, blue will hold but is easily breakable
for when the inevitable repair\maintenance session is required.
Phil Martin.
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.423 / Virus Database: 238 - Release Date: 25/11/2002
Old Dec 18, 2002, 02:45 AM
Richard D.
Richard D.
Guest
n/a Posts
The RED loctite, the color of the fluid not the bottle, is a PERMANENT
Loctite and should only be used on components that you are not planning
to remove.
The BLUE loctite, the fluid, is removable loctite, one of the names it is
given is "Thread 'n lock" as it is placed onto the threads of the screw
or bolt and then screwed together. It will harden up after awhile and
prevent the bolt or screw from coming apart from vibration.
Hope this helps.
Richard D.
Former Airline Mechanics Credo:
We the willing
Led by the ungrateful!!!
Have been doing the impossible
For so long
With so little
That we are now qualified
To do anything
With nothing at all...
Old Dec 18, 2002, 12:36 PM
Blair Stearn
Blair Stearn
Guest
n/a Posts
I had a problem with blue being too permanent
on really small parts (2mm allen bolts etc) and have
gone to Loctite Purple for the really small bits.
Works great! No more stripped allen bolts.
Blair
On Wed, 18 Dec 2002 08:29:27 GMT, "Richard D." <ramboamt@prodigy.net>
>to remove.
> Hope this helps.
>Richard D.
>We the willing
>For so long
>With so little
>To do anything
Old Dec 18, 2002, 05:03 PM
Graham F Taylor
Graham F Taylor
Guest
n/a Posts
A tip from Down Under..... Don't use INOX to lube anything near your
Loctite ... it dissolves it !!!! A friend lost tail rotor control because
of it.
GT Darwin
Old Dec 18, 2002, 10:02 PM
stymye
stymye
Guest
n/a Posts
the purple milky(222ms) is for 1/4(6mm) and smaller screws .blue
milky(222) is for anything larger.
"Blair Stearn" <milli-pilot@shaw.ca> wrote in message
newsgf10v4qi0t9b9ce7u3psh9ol1oj1jstbv@4ax.com...
> Blair
> >to remove.
is
> > Hope this helps.
> >Richard D.
> >We the willing
> >For so long
> >With so little
> >To do anything
but
Old Dec 22, 2002, 04:32 PM
easynews
easynews
Guest
n/a Posts
If you ever find it difficult to undo a thread with loctite on it, try
gently heating it (small soldering orn / blow torch etc), once warn it will
be MUCH easier to undo. Obviously be careful not to damage anything with the
heat!
Anthony
"Richard D." <ramboamt@prodigy.net> wrote in message
news:3E00328E.7040405@prodigy.net...
> to remove.
> Hope this helps.
> Richard D.
> We the willing
> For so long
> With so little
> To do anything
easynews
easynews
Guest
n/a Posts
heat!
Anthony
> to remove.
> Hope this helps.
> Richard D.
> We the willing
> For so long
> With so little
> To do anything
easynews
easynews
Guest
n/a Posts
gently heating it (small soldering iron / blow torch etc), once warm it will
heat!
Anthony
> to remove.
> Hope this helps.
> Richard D.
> We the willing
> For so long
> With so little
> To do anything
Old Dec 23, 2002, 03:22 AM
Wilbur Wilburforce
Wilbur Wilburforce
Guest
n/a Posts
is there an echo round here?
Will
