This thread is privately moderated by Ghost 2501, who may elect to delete unwanted replies.
Old Dec 30, 2009, 04:44 AM
HeavyCruser9 is offline
Find More Posts by HeavyCruser9
HeavyCruser9's Avatar
Adelaide,Australia
Joined Dec 2009
Thx mfr02 that explains it! Better 2 ask now than burn the boat up with a 24 volt short!
HeavyCruser9 is offline Find More Posts by HeavyCruser9
Old Dec 30, 2009, 11:13 AM
Ghost 2501 is offline
Find More Posts by Ghost 2501
no wings any more, just dust!
Ghost 2501's Avatar
stoke on trent
heavycruiser, my sydney star has 3 esc's and 6 fuses. 15a esc's with 3a output fuses, and 10a imput fuses, if motor stalls, fuse pops saving esc before it gets to the 15a limit, if esc goes mental and starts to draw, imput fuse pops killing esc power before boat goes smokey
Ghost 2501 is offline Find More Posts by Ghost 2501
Old Dec 30, 2009, 03:17 PM
Adelaide,Australia
Joined Dec 2009
I like that setup! cheers Ghostie!
Thx Bruce
Old Dec 30, 2009, 05:53 PM
Ghost 2501's Avatar
stoke on trent
no problem bruce
you may need to play around with fuse values to get a set up you are happy with, and if you want, you can always replace fuses with breakers.
Old Feb 17, 2010, 08:50 PM
Ticonderoga is offline
Find More Posts by Ticonderoga
Ticonderoga's Avatar
Australia, QLD, Mudgeeraba
Joined Feb 2010
Hi everyone, I am new to the forum and have just read this thread. What a mine of information......For info, I am about to embark on my first RC build, I am going to build a Ticonderoga Cruiser, hence the screen name. The plan is to "animate" the 5inch guns, the twin arm launcher, aft radar running and special ops lights, deck landing lights, internal bridge red night lights and, bit ambitious, maybe the starboard anchor.
I am ex RAN, so if you ahve questions about what mast head, stern light, nav lights etc, mean I will be happy to answer. thanks for thifo so far, especially Ghost and Gill
Ticonderoga is offline Find More Posts by Ticonderoga
Old Feb 18, 2010, 09:23 AM
Ghost 2501's Avatar
stoke on trent
tico welcome to RCG, we hope to see your build soon.
get a mode3 radio where you can have elevon mixing on the left stick. this will help you when it comes to control as you can use ELEVON mixing to put the motors on one stick, save buying additional hardware
Old Feb 19, 2010, 08:46 AM
Joined Feb 2010
Hello Ghost, thanks for the warm welcome.
I am very new to the world of R/C, what due you mean by mode 3 controller?
Old Feb 19, 2010, 10:23 AM
GILL RC is offline
Find More Posts by GILL RC
GILL
GILL RC's Avatar
United States, NJ, Hopatcong
Joined Aug 2005
Any good 6-12 channel computer radio will have enough mixes to tie the ESC together. On one of my modelsI have 3 motors.
Radio: 8 channel Tracker III
ESC 1 in channel 3 (center motor)
ESC 2 in channel 6 (port motor)
ESC 3 in channel 7 (starboard motor)
Programe:
P-mix 1, channels 3 & 6 @100%
P-mix 2, channels 1 & 7 @100%
P-mix 1 & 2 on function switch A
P-mix 3, channels 1 & 6 @50%
P-mix 4, channels 1 & 7 @-50%
P-mix 3 & 4 on function switch B
Operation:
1. Function switchs A & B off
Center motor only
Controled by left stick
2. Function switch A on
All 3 motors work together
3. fuction switch A off
Function switch B on
Port and starboard motors
controled by right stick (rudder)
GILL RC is offline Find More Posts by GILL RC
Old Feb 19, 2010, 11:10 AM
Ghost 2501's Avatar
stoke on trent
mode2 has elev + aileron on RIGHT HAND stick
mode3 has elev + aileron on LEFT HAND stick, with throttle and rudder on Right hand stick
Old Feb 20, 2010, 01:16 AM
Joined Feb 2010
Thanks Gill,
It should be straight forward to be able to handle both engines independently of each other then. i.e slow ahead starboard, slow astern port to swing the stern in going alongside starboard side to.
Old Feb 20, 2010, 12:15 PM
Ghost 2501's Avatar
stoke on trent
well originally a wiring thread, now radio set up, ho hum!!
Tico. if you get a Futaba 6EX radio 2.4ghz, you can put esc's in ch1 and 2, and engage "elevon" mixing, turn radio off, press and hold [mode] & [select] when you are powering up and you will see a number, probably 2, push [data entry] until you get "3", turn off radio and reboot radio as normal. you now your motor control MIXED and back on the left stick.
Old Feb 20, 2010, 09:01 PM
more coffee is offline
Find More Posts by more coffee
Cheif Bottlewasher
more coffee's Avatar
Canada, NS, Sydney Mines
Joined Sep 2005
Actually Ghosty
In need wiring set up to reverse the inside motor on a turn with Darby ..
Left hand turn ..left had motor reverses and so on ..but only on the hard over
I saw a set up using a set of lever switch'es DPDT I think..but im lost as wether or not I need momentry swtiches or other wise
more coffee is offline Find More Posts by more coffee
Old Feb 21, 2010, 07:01 AM
Ghost 2501's Avatar
stoke on trent
more Coffee, if you add a mixer between the ESC's and RX you will get that exact effect and it will be more controllable, and it removes the need for a load of connections. if your radio has in-built software mixes, you could use them
Old Feb 21, 2010, 11:04 AM
Cheif Bottlewasher
Joined Sep 2005
Mixer?
Any suggestion's ?
A link would be helpful
Thanks Ghost
Old Feb 21, 2010, 11:16 AM
Ghost 2501's Avatar
stoke on trent
any V-tail mixer as used by the fly boys will do,
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXHHS3
plug your esc's into one of these.
Silicone hinge made easy. gator Electric Sailplanes 4 Feb 06, 2003 07:53 AM
