Go Back   RC Groups > Boats > Scale Boats
This thread is privately moderated by Ghost 2501, who may elect to delete unwanted replies.
Old Jun 01, 2008, 07:42 AM   #16
boating addict
trawlerlover's Avatar
Could any of you post the wiring diagrams for LED running lights? I'm thinking of doing them sometime but I don't know how to properly wire them.
trawlerlover is offline Find More Posts by trawlerlover   Reply With Quote
Old Jun 01, 2008, 08:04 AM   #17
pick013
pick013's Avatar
Send a message via Yahoo to pick013
Try http://www.theledlight.com/ledcircuits.html for good LED hookup information.
Daryl
pick013 is offline Find More Posts by pick013   Reply With Quote
Old Jun 01, 2008, 09:21 AM   #18
boating addict
Thanks that should help.
Old Jun 13, 2008, 05:35 AM   #19
Many thanks for all this, which is very helpful. But I have another question. My ESC requires red and blue wires to be connected to yellow and green wires on the motor. Can you please tell me how to pair them?
Kaskazi is offline Find More Posts by Kaskazi   Reply With Quote
Old Jun 13, 2008, 06:20 AM   #20
connect them as you want...
depending on how you connect the wires the motor will spin in one direction or the other when you move the stick on you TX to forward.... when the motor spins the wrong direction, just change the esc to motor wire connections...
valo is offline Find More Posts by valo   Reply With Quote
Old Jun 13, 2008, 07:07 AM   #21
Thank you -that's what I thought, but wanted to check.
Old Jul 11, 2008, 11:41 AM   #22
E-Challenged's Avatar
Motor Reversing Switch
Here's the wiring for a drive motor reversing switch if you have a spare channel on your transmitter. I used a truck type heavy duty toggle switch and toggle it with a servo and pushrod attached to the toggle lever with a spring "servo saver" setup. To change from forward to reverse, go to throttle off position, operate the reversing channel and throttle up in the desired direction. Boats don't steer well in reverse and take some time to react due to lack of prop blast on rudder(s). Reverse is mostly helpful in docking including stopping the model to prevent plowing into the dock.
E-Challenged is offline Find More Posts by E-Challenged   Reply With Quote
Old Jul 31, 2008, 08:28 PM   #23
reversing switch
I like the idea of a reversing switch for things like bow thruster, sail winch etc controlled by a servo. A toggle switch will require a good amount of energy. Has anyone experimented with that idea? Did take a slide switch apart & remove the ball that gives it it's snap but feels like a common servo wouldn't have the torgue either. Anyone try that? Am I barking up the wrong tree? MSD has the device that would do it but a lot of money.
An experimenter: Mike
mtilston is offline Find More Posts by mtilston   Reply With Quote
Old Nov 16, 2008, 03:16 PM   #24
Send a message via Yahoo to rmdesignworks
Hi-Low Voltage/Amps
Here is a simple diagram for a voltage conversion switch.
  • Name: 6-12 converter JPG.jpg
rmdesignworks is offline Find More Posts by rmdesignworks   Reply With Quote
Old Dec 24, 2008, 08:57 AM   #25
Is he possible is construction the arrangement steers 4 engines, leaning on receiver set of 2 channel joint from speed controler ?
There are on two engines and receiver 2- the channel sets scheme in this section. .
I greet, rafiw
rafiw is offline Find More Posts by rafiw   Reply With Quote
Old Dec 24, 2008, 11:12 AM   #26
Xantec
Ghost 2501's Avatar
Send a message via MSN to Ghost 2501
put a microswitch in the rudder assembly so as you throw the rudder over, it breaks connection with the inboard motor.
Ghost 2501 is offline Find More Posts by Ghost 2501   Reply With Quote
Old Jan 03, 2009, 11:08 AM   #27
Xantec
Ghost 2501's Avatar
another nav light set up that enables you to have a switched circuit
note one negative supply
please note:
the red wire simply crosses over the black between its split and the RC switch
  • Name: Image9.jpg
Old Jan 27, 2009, 08:16 AM   #28
Ghost, I have a question plz I plan on putting in two Torpedo 500 motor and gearbox's in my tug I'll be using a Werker 6V 12Ah sealed battery do I need one ESc or two ?thank you
saltyNscaler is offline Find More Posts by saltyNscaler   Reply With Quote
Old Jan 27, 2009, 01:29 PM   #29
Xantec
Ghost 2501's Avatar
depends on what the amp pull is, on the first page are several diagrams.
if you have a 4+ chan radio, go the twin esc route, if you have a two chan radio you could get away with 1esc.
diagrams found on page 1 of this thread
Old Jan 27, 2009, 05:56 PM   #30
I was going to go the 4 channel route and thank you
Re: [Allegro-Lite] Phil Barnes "Vacuum Bagging Made Easy" Raschow@aol.com RCSE 0 May 15, 2003 04:02 AM
Phil Barnes "Vacuum Bagging Made Easy" Bill & Rose Haymaker RCSE 0 May 15, 2003 04:02 AM
VAC pump made easy jackman, tomer RCSE 1 Apr 16, 2003 04:03 AM
Vacuum Bagging Made Easy is a A++ DVD Albert Wedworth RCSE 1 Apr 11, 2003 04:03 AM
Silicone hinge made easy. gator Electric Sailplanes 4 Feb 06, 2003 08:53 AM
Bored? Want to fight?
Join the RCGroups clan!
