This thread is privately moderated by Ghost 2501, who may elect to delete unwanted replies.
Old Mar 12, 2012, 02:06 AM
nick_75au is offline
Find More Posts by nick_75au
NeverAgainVolunteerYourse lf
nick_75au's Avatar
Australia, QLD, Regents Park
Joined Mar 2007
Well it depends,what size props, how fast you want to go, what KV is the motor?
Too many variables to answer the question without more Info
The battery has a rating, something like 20C this is the maximum draw the battery can handle, Higher mAH or higher C ratings allow higher to be drawn from the battery. If you exceed the C rating, which for a 20C 4500mAH battery is 90 amps you risk damaging the battery and possibly causing more damage than just the battery.
This Link will go to a page that answers a lot of questions on Li-po.
Cheers
Nick
nick_75au is offline Find More Posts by nick_75au
Old Mar 12, 2012, 02:17 AM
moonmist is offline
Find More Posts by moonmist
United States, MI, Alpena
Joined Jan 2012
Its for a quad copter... my first attempt is going to be with 13x6 props. The thing is made out of PVC pipe.... dont need it to go fast ...just fly with some weight
moonmist is offline Find More Posts by moonmist
Old Mar 12, 2012, 02:18 AM
moonmist is offline
Joined Jan 2012
710 kv motor
Old Mar 12, 2012, 02:26 AM
moonmist is offline
Joined Jan 2012
Im also using 50amp esc
Old Oct 29, 2012, 09:54 AM
mass flyer is offline
Find More Posts by mass flyer
I Am a Proud Registered User
United States, MA, Hamilton
Joined Sep 2012
im doing the 2 motor one esc method but i have no rudder so turning works by one motor going and not the other if i put in an esc will that still work? and do i need the fuses?
mass flyer is offline Find More Posts by mass flyer
Old Oct 29, 2012, 02:10 PM
mfr02 is offline
Find More Posts by mfr02
Blackpool, Lancs
Joined Feb 2006
Tank steering with one ESC and 2 motors needs a bunch of switches, possibly combined with rectifiers, worked by what would have been the rudder servo, and the entire question really belongs in its own thread. Yes, fuses will be needed.
mfr02 is offline Find More Posts by mfr02
Old Dec 06, 2012, 10:05 AM
Clancy Arnold is offline
Find More Posts by Clancy Arnold
I am 5' 8" the Taube is 7' 4"
Clancy Arnold's Avatar
USA, IN, Indianapolis
I solved the same problem!
You can not control two motors from one ESC without problems. You need two ESCs separately controlled.
I have an ESC, Black units, controlling each motor. The ESCs are controlled by U/Tronics Control single channel units, small Red pieces, that are controlled by a mechanical mixer I built.
The upper servo is the throttle and moves the brass plate, that runs in tracks, that the slide pots are mounted on to move both slide pots equally. The lower servo is the steering and moves the slide pot controls in opposite directions.
I disabled the BEC on one ESC and the two U/T units and the receiver, through a Y cable, are powered by the other ESC.
Clancy
Clancy Arnold is offline Find More Posts by Clancy Arnold
Old Dec 17, 2012, 09:19 PM
Boat Mixer rudderless
I posted a picture of the Boat mixer I built. Here is a schematic of the mixer and how it works.
Clancy
Old Jan 04, 2013, 02:00 AM
minerug is offline
Find More Posts by minerug
Joined Jan 2013
Circuitry for my boat
I am designing a RC naval type corvette with the following specs with regard to electronics. http://www.rcgroups.com/forums/showthread.php?t=1801355 to main thread of my boat.
1x 2 axis turret for air cannon
1x electrically actuated valve for cannon
2x small liquid pumps (I know what model I am getting for this)
1x nicrome wire coil to be powered when pumps are engaged
1x 2 axis turret for hobby rockets
4x nicrome wire coil for rocket turrets
1x pair of nicrome wire coils for home made smoke generator
1x nicrome wire coil on stern for fake depth charge rack
^these coils need to be set up so they can be selected with a 6 way switch or something so they can be powered separately. All coils on boat to be powered from same battery bank
1x push solenoid for fake depth charge rack
2x motors for hydrojet propulsion with ESC
1x rudder servo
Attached is my attempt at a layout diagram. I am new to RC stuff so I am not 100% clear on how everything need to be wired up.
Any help in the form of component recommendations and a proper layout diagram would be much appreciated
minerug is offline Find More Posts by minerug
Old Jan 04, 2013, 05:27 AM
mfr02 is offline
Blackpool, Lancs
Joined Feb 2006
Reading the first few posts in this thread will help a lot with understanding the schematic conventions used.
Reading through the more recent posts on "Well Enhancer" might help with control of the "extras", the earlier parts of that thread might help with the basic construction of a large model.
Old Jan 05, 2013, 02:24 AM
Ticonderoga is offline
Find More Posts by Ticonderoga
Ticonderoga's Avatar
Australia, QLD, Mudgeeraba
Joined Feb 2010
1x rudder servo
From your sketch it looks like you are going to need plenty of channels on your radio
You might be able to ease the complexity of the overall system a little by using a small on board computer, something like an Arduino Uno or Mega. They are not very expensive and are relatively easy to programme. By using a combination of Switches and pots on your transmitter, you could arrange for the Arduino to "manage" your pyrotechnics. The Arduino can handle digital and analog input/output and can be "trained" to interpret and issue servo control commands. Take a look at http://arduino.cc/en
I am going to use an Arduino to simulate a Gun Fire Control System on my large scale Russian Cruiser
Andrew
Ticonderoga is offline Find More Posts by Ticonderoga
Old Jan 05, 2013, 04:22 PM
minerug is offline
Joined Jan 2013
Hi Andrew,
Arduino sounds like it could be an option
One idea I had last night was to make a separate 6ch transmitter/rx system to control all the nichrome goodness, just with a bunch on push-to-make switches on it.
If all else fails, I came across this- http://www.robbe.de/f-14-4-8-3-40-mh..._from_store=de can be expanded up to 16 channels
Old Feb 27, 2013, 07:40 PM
hazegry is online now
Find More Posts by hazegry
United States, VA, Virginia Beach
Joined Sep 2006
hey guys I need some help I put a dumas 4.8v motor in my tug and I was using 2s 7.4v 2200MAH packs but I am only getting around 17 min of run time. I then put a small motor with a 4 to one planetary drive to increase run time but now it doesn't have enough speed. could I switch out to a brushless motor to increase the speed? I was thinking maybe a small outrunner.
hazegry is online now Find More Posts by hazegry
Old Feb 27, 2013, 09:16 PM
nick_75au's Avatar
Joined Mar 2007
Simplest solution is to go to 3s if the esc can handle it.
you need an rpm somewhere in between the dumas and other setup. do you know the rpm of each motor?
Old Apr 18, 2013, 06:15 PM
P31 is offline
P31
Find More Posts by P31
P31
United States, WA, Spanaway
Joined Dec 2011
Hi guy's I have a Linear BEC and I have no idea what they are used for.
Gary
P31 is offline Find More Posts by P31
Silicone hinge made easy. gator Electric Sailplanes 4 Feb 06, 2003 07:53 AM
