Old Dec 09, 2007, 09:52 AM
aireze is offline
Find More Posts by aireze
Ocala, Florida
Joined Apr 2001
Question
Conversion factor2 to 3 blade prop
Hi all, need to know how to convert 2 bladed prop to 3 or 4 blades. Landing gear to short for bigger prop. Need to use a 3 or 4 blade prop. Need to know what the conversion factor is. Thanks In Advance, Rich
aireze is offline Find More Posts by aireze
Old Dec 09, 2007, 10:06 AM
56S is online now
56S
Find More Posts by 56S
56S
Certified Balsa Breaker
56S's Avatar
Joined Nov 2006
Here on this forum the Good Dr. Kiwi has tested some of the new GWS HD three-bladers. All the info you would ever need is most likely there. or here...
http://www.rcgroups.com/forums/showthread.php?t=781035
56S is online now Find More Posts by 56S
Old Dec 09, 2007, 10:25 AM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
I haven't yet accumulated enough data to determine what 2-blade prop is the exact equivalent (thrust/pitch speed) to a 3-blade prop. .... but I'm working on it!
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Dec 09, 2007, 06:29 PM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
Propeller design theory says:
2 to 3 blades, reduce diameter by 10%,
2 to 4 blades reduce diameter by 15%,
pitch stays the same in both cases.
Steve
slipstick is offline Find More Posts by slipstick
Old Dec 11, 2007, 12:15 AM
LBMiller5 is offline
Find More Posts by LBMiller5
Use the Force!
LBMiller5's Avatar
San Marcos, CA
Joined Jan 2005
aireze,
There is a very complicated formula for determining the load factor of a propeller, but in it's most simplistic form, for a 2-bladed prop, the load that a prop places on a motor is equal to the diameter cubed times the pitch or D x D x D x P. For a 2 bladed 10x6 prop, the load factor would be 10 x 10 x 10 x 6 or 6,000. For a 12x8 prop it would be 12 x 12 x 12 x 8 or 13,824.
The more complete formula, which takes the number of prop blades into account is D x D x D x P x Square root (N-1), where N = the number of prop blades. For a 2 bladed prop, the square root of (2-1) is the square root of 1 which is 1, so the term just drops out of the equation.
For a 3-bladed prop, the correction factor is the square root of (3-1) or the square root of 2, which is 1.414.
For a 4 bladed prop, the correction factor is the square root of 3, which is equal to 1.732
So if you have a 3-bladed 9x7 prop, then the load factor is 9 x 9 x 9 x 7 x 1.414, which is 7,216, and this would be roughly wquivilent to a 2-bladed 10x7 prop, which has a load factor of 7,000.
If you had a 4-bladed 12x7 prop, then the load factor would be 12 x 12 x 12 x 7 x 1.732 or 20,950 This would be roughly equivelent to a 2-bladed 14x8 prop, which has a load factor of 21,952.
In the end, if the load factor of 2 props is the same, you will get similar RPMs from the two props, and similar performance.
So there you go, hope that helps!
Lucien
LBMiller5 is offline Find More Posts by LBMiller5
Site Sponsor
Old Dec 11, 2007, 08:05 AM
flypaper 2 is online now
Find More Posts by flypaper 2
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Go down 1 in. diameter with the same pitch will put you in the ball park.
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
Old Dec 11, 2007, 08:55 AM
KenSt is offline
Find More Posts by KenSt
Scratch builder
USA, PA, Telford
Joined Apr 2004
I've always used this formula: 2/x to the .25 power. 2 = number of blades of two bladed prop. This is a constant. X = number of blades you want (usually 3 or 4) The answer you get is a decimal. Multiply it by the diameter of the two bladed prop and your answer is the new prop. Use the same pitch.
To simplify; for a three blade, 2/3 raised to the .25 power = .903602 This is the two to three blade factor.
To go from a two to four blade, 2/4 raised to the .25 power = .8408964 This is the four blade factor.
2/5 to the .25 power = .7952707 5 blade
2/6 to the .25 power = .7598357 6 blade
So, if you have a 10-7 two blade and want a three blade: 10 x .903602 = 9.036 diameter. Round it off to 9, use same pitch, 9-7 three blade.
If you start with three blades and want to go to two, divide the three blade diameter by the same .903 factor to get the two blade diameter.
These factors are virtually identical to what Slipstick said.
KenSt is offline Find More Posts by KenSt
Old Mar 31, 2008, 03:57 AM
wolw is offline
Find More Posts by wolw
<- Balsa flies better ->
wolw's Avatar
Gustafs, Sweden
Joined Feb 2006
CTRL C
Thanks Lucien
Peter
wolw is offline Find More Posts by wolw
Old Mar 31, 2008, 10:14 AM
c/f is offline
c/f
Find More Posts by c/f
c/f
Joined Jan 2004
There cheap enough at www.gwsprops.com to try them out in all the sizes.
The Direct drive GWS shaped 3 blades are quite a bit differant in comparison amp draws than the SLO fly series 3 blades. Something you must consider.
I generally just drop down by 1" in the dia of the 2 blade as a starting point. I am running more 3 blades than 2 now days as the torq effects for same thrust ratings are reduced. I preffer only the Direct drive profile however.
c/f is offline Find More Posts by c/f
Latest blog entry: Time Capsule Heli
Old May 22, 2016, 02:57 PM
tengarang is online now
Find More Posts by tengarang
Fly Straight Fly High
tengarang's Avatar
United States, CA, San Jose
Joined Aug 2010
Really appreciate the posts here guys learned alot!
tengarang is online now Find More Posts by tengarang
Old May 31, 2016, 07:09 PM
Fly_electric2 is offline
Find More Posts by Fly_electric2
Joined May 2012
Interesting equation in it being simple, but something is not quite correct, as it implies a single blade has zero load factor..?
Fly_electric2 is offline Find More Posts by Fly_electric2
Help! Prop conversion 2 to 3 blade?? JRAllen Electric Plane Talk 4 Oct 22, 2006 08:32 AM
Conversion from 2-blade to 3-blade prop tumbleweed Power Systems 4 Apr 10, 2003 08:55 AM
Beaver on 8 720 Nimh & 3 blade prop GoodTill Parkflyers 0 Jul 06, 2002 11:29 AM
gws 3 BLADE Prop now available at..... Bleriot Parkflyers 5 Feb 16, 2002 03:10 PM
2 blade v. 3 blade prop planeluv Scale Kit/Scratch Built 1 Dec 12, 2001 10:15 AM
