Old Mar 27, 2009, 12:35 PM
KAMAX-T's Avatar
Powell TN
Originally Posted by maxvtol
Thanks UTG.
xzavin, if I did give a prediction on when the fiberglass model would fly, I wouldn't believe it. I will just say many months at this point.
I do have the 3rd design of tilt servo brackets done, but still not sure I'm going to use them. Might make a 4th just to see if it's any stiffer. I'll definitely post some pics when I'm happy with them.
Can't wait Max ......chop , chop .....
KAMAX-T is offline Find More Posts by KAMAX-T
Old Mar 31, 2009, 12:10 PM
Philscbx's Avatar
Mpls Mn
Joined Mar 2007
I'm about 90% certain I'm gonna go ahead and step up to my next version which would use one motor, shafts and variable pitch props. That has been my long term intent anyway.
That was one of my plans as well with one motor, but twin props out on ends of boom with micro belts.
My main reason here was to show you the tools used for Rivnuts.
There are many different styles, and you developed one of the ways,
but I used these tools quite a bit restoring WWII aircraft over the years.
http://www.hansonrivet.com/w69.htm
This is one common sample.
The threaded Rivnut itself has now been updated.
From round grip zone to square. Very Smart.
I wish we had these styles back in the eighties.
A common problem is the nut and screw become somewhat seized, and then the Rivnut decides to spin in it's crimp zone, and then therapy is next stage.
http://www.hansonrivet.com/w66b.htm
The other issue is the space created between the sheets.
Sometimes this is not wanted.
This is where the sub sheet gets dimpled, which then keeps combined sheets tight together.
There might be counter sink style nuts, where you use a 60 degree drill style counter sink for the nut to sit flush.
Hope I catch this ship flying soon.
Cheers
One Note added/
Check underside of rivnut head to see if it has a non turn keyed index molded in, This is where you make a matching dimple in sheet to lock
rivet from spinning.
Philscbx is offline Find More Posts by Philscbx
Old Apr 23, 2009, 09:44 AM
Joined Nov 2003
all i can say i WOW ...looking forward to seeing the thing fly.
mattijs321 is offline Find More Posts by mattijs321
Old Dec 11, 2009, 11:49 AM
Joined Nov 2007
Well what is the latest? Did you put together the 4th rev of brakets.
MJER is offline Find More Posts by MJER
Old Dec 11, 2009, 11:08 PM
just Some Useless Geek
A Useless Geek's Avatar
Chicagoland
Joined Oct 2008
The quad threads on this board seem to have fallen suspiciously silent...could it be that all the quad projects are failing miserably? I sure hope not, because paying Microdrones fifteen grand for a camera platform seems like a sucky way to blow a fortune on R/C.
A Useless Geek is offline Find More Posts by A Useless Geek
Old Dec 13, 2009, 10:16 AM
maxvtol's Avatar
Valdosta, GA
Joined May 2007
Nothing done since last post. I will eventually get back to it, just working on unrelated non-RC project.
Originally Posted by A Useless Geek View Post
... because paying Microdrones fifteen grand for a camera platform seems like a sucky way to blow a fortune on R/C.
Pay me half that and I'll get back to work on it real quick!!!
maxvtol is offline Find More Posts by maxvtol
Old Dec 13, 2009, 10:31 AM
KAMAX-T's Avatar
Powell TN
Hello Max , glad to here from ya .... Lookin' forward to more progress on the QTR ...
Terry
Old Dec 14, 2009, 08:37 PM
RCvertt's Avatar
Joined Aug 2007
Nothing done since last post. I will eventually get back to it, just working on unrelated non-RC project...
What is your AUW?
RCvertt is offline Find More Posts by RCvertt
Old Dec 14, 2009, 09:31 PM
maxvtol's Avatar
Valdosta, GA
Joined May 2007
Should be around 10lbs. Motors pull around 170 watts each using 16x10 electric props.
Old Dec 14, 2009, 09:33 PM
RCvertt's Avatar
Joined Aug 2007
WoW.
This amazing project is bigger than I though it was. Hope you get time to start it up again soon.
Old Apr 24, 2012, 06:31 PM
Joined Mar 2012
Interesting, I designed a simpler tilt motor quad with a fixed wing in the middle, but then realized it was simpler and lighter to simply add an additional horizontal flight motor and skip the complexity and weight of the tilt mechanism entirely.
This thing makes no pretense of being scalable to full sized flight, but hopefully will make a good camera / video platform.
Using the Ardupilot APM2 controller which is easy to set up for custom profiles.
grmccray is offline Find More Posts by grmccray
Old Feb 12, 2013, 08:25 AM
MULTI ENGINE FANACTIC
CESARNOGUEIRA's Avatar
SAO PAULO,S.P.,BRAZIL
Joined Dec 2000
MAGNIFICENT !!!!!!!!!!!!!
CESARNOGUEIRA is offline Find More Posts by CESARNOGUEIRA
Discussion BA609 Tilt Rotor Build shanghai_fool VTOLs 85 Feb 09, 2008 05:37 PM
GWS B-2 DF Comments and suggestions welcome. Reaper9294 Parkflyers 19 Feb 16, 2004 09:40 PM
