Quad Tilt Rotor - Build Log (Comments & Suggestions Welcome)
I guess it's time to start my log. I don't think building a plane from the outside in is such a good idea on your first plane (if I had to do it over again, I think I would go balsa). I think I'm far enough along where the time between posts shouldn't be too long, and progress reports can come more quickly.
The main reason I'm going fiberglass is that, as far as I know, transitioning with a custom mixer has never been done before, and if my bird decides it wants to become a terrestrial submarine, hopefully I can get flying again faster by pulling a new part from a mold. We'll see. I could probably spend another several days detailing the drawings in Solidworks, but I think it's at a point where building will be as quick as drawing. From here I'll probably start on the fuselage and make some drawings and a jig of sorts to locate the parts. From the test part and samples I believe the model will come in at 10lbs + or - .5 lbs, hopefully I can keep it on the lighter end.
Thanks V, I don't know that I have mastered the composites, still a lot of trial and error, but hopefully once I get it figured out, replacement parts or new parts will come more quickly.
Eddie the motors are direct outrunners, same as I used on my test rig. They're Electrifly Rimfire 35-48-850 and have no trouble turning the 16x10 thin electric blades with 11.1v lipos. They're rated at 666 watts constant output, not bad for a 6 oz motor. |
Thanks Ken and V, I think I understand now.
Have some video of a 40th scale fuselage plug for a test I did. I didn't video the 10th scale plug, I think it took about 6+ hours or so for both halves. CNC video of 40th scale fuselage plug And V, wow how big is that V-22 going to be? Your flap is about the width of my front wing. |
RC, they tilt in for a little more stability. I'm using gyroscopic forces and torque to help with the pitch and roll control in hover. They tilt in at 12 degrees so in theory they should loose less than 3%, though I haven't tested that. In cruise they're straight, so there isn't any loss of thrust there.
I didn't read Eddie's post clearly, sorry, the tilt servos are direct and are Hitec robot servos . If you've seen my BEC failure post, you'll need to use batteries on these servos, BEC's can't handle them. Larry, very cool, can't wait to see more of your build. I'm Joe, but I kinda like being called Max (my middle name). Call me whatever you want, I'll answer. Yes, I can try to do something for anybody. I think by the time you figure foam and machine time I was a little over $500. The foam does need to be finished with epoxy or something to give it a smooth surface, it can be quite time consuming to get it smooth, but you'll have an accurate shape. |
| Thread Tools | |
| Discussion BA609 Tilt Rotor Build | shanghai_fool | VTOLs | 85 | Feb 09, 2008 05:37 PM |
| GWS B-2 DF Comments and suggestions welcome. | Reaper9294 | Parkflyers | 19 | Feb 16, 2004 09:40 PM |
