Old Apr 03, 2008, 12:41 AM
1toslope is offline
Find More Posts by 1toslope
1toslope's Avatar
California
Joined Dec 2005
Just came acrost this thread. What a great airplane.
It's on my list now.
1toslope is offline Find More Posts by 1toslope
Old Apr 09, 2008, 02:39 AM
deadduck is online now
Find More Posts by deadduck
Manila Ninoy Intl, Philippines
Joined Nov 2001
Atomic delivers
A thin long box arrived containing my SE5 parts from Atomic.
Some damage to two of the fuselages (tails) and one of the tail plane sets, but easily repaired. I will be leaving them positive feedback since they did deliver on my bid.
It turns out the landing gear set includes the wheels, so I need to make some struts and a lewis machine gun and I have an SE5 complete (well 3 of them, ).
deadduck is online now Find More Posts by deadduck
Old Apr 09, 2008, 02:42 AM
Joined Nov 2001
Help, strut patterns needed
Anybody with an unbuilt kit and a scanner?
Please scan the outer and cabane struts for the SE5A.
Please post as a jpeg or pm me.
Thanks in advance.
Old Apr 09, 2008, 08:36 AM
skunkworks2006 is offline
Find More Posts by skunkworks2006
skunkworks2006's Avatar
Michigan
Joined Nov 2006
I have an unbuilt kit, but won't be able to scan them for a couple of days. You can always order some from E-Flite.
skunkworks2006 is offline Find More Posts by skunkworks2006
Old Apr 09, 2008, 06:05 PM
Joined Nov 2001
I looked in the Eflite site and the struts aren't listed as a spare part.
Old Apr 09, 2008, 06:43 PM
finchkid24 is offline
Find More Posts by finchkid24
100% addicted to RC :)
finchkid24's Avatar
USA, CA, La Verne
Joined Feb 2008
I am really looking into getting this plane...one question though. What motors are you guys using besides the E Flite stuff? To me its seems like $45 is too much for such a small motor. How does something like this look? http://www.nitroplanes.com/al2502brmo.html
Should I just look for a similar sized motor hitting 2200kv mark? I don't really understand how the watts and KV stuff works yet.
finchkid24 is offline Find More Posts by finchkid24
Old Apr 09, 2008, 08:25 PM
Joined Nov 2001
As long as you can reverse the shaft, that motor looks like a good substitute.
But it doesn't seem to come with a motor mount, so it might not be possible to reverse the shaft.
Old Apr 09, 2008, 10:07 PM
finchkid24's Avatar
USA, CA, La Verne
Joined Feb 2008
what do you mean by reversing the shaft?
Old Apr 10, 2008, 06:41 PM
Luis_Claudio is offline
Find More Posts by Luis_Claudio
Luis Claudio - Rio - Brazil
Luis_Claudio's Avatar
Brasil, RJ, Rio de Janeiro
Joined Apr 2005
All,
Can I order spare parts from E-flite? Like order the under carriage?
Tks,
Luis
Luis_Claudio is offline Find More Posts by Luis_Claudio
Old Apr 10, 2008, 10:49 PM
Sammy70 is offline
Find More Posts by Sammy70
PSALM 14:1
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Originally Posted by boomerace
Get some small aluminum tubing at the LHS that just fits over the LG wire and tie the wheels and hubs together into one unit with the tubing. gives a wide stance solid wheel that will just fit on the stock LG assembly.
Bullet proof on those bad landings!
boomer
Could you post of pic of this setup sometime....?
Sam
Sammy70 is offline Find More Posts by Sammy70
Old Apr 10, 2008, 10:58 PM
boomerace is offline
Find More Posts by boomerace
Been There! Done That!
boomerace's Avatar
Eugene, Oregon, United States
Joined Sep 2001
Sam
Pics. I cut off the wheel portion and place the remaining wheel halves each side on a 2-1/2" Mpi wheel. Tube through the 2 wheel halves and the Mpi Wheel tie the whole theng together.
boomer
boomerace is offline Find More Posts by boomerace
Old Apr 11, 2008, 01:29 AM
DaveInLA is offline
Find More Posts by DaveInLA
Joined Sep 2006
Hey guys, do you think this Great Planes/Electrifly 2s lipo will fit in the SE5a?
http://www3.towerhobbies.com/cgi-bin...?&I=LXMDM4&P=7
Its dimensions are 2.8" x 1.4" x 0.4". My main concern is the length; the recommended E-flite 430 battery is 2.15" long, and the Thunder Power 730 is only 2" long. This Electrifly is 0.65" longer than the E-flite, and that's a lot. However, I can get a good deal on it, which is why I'm asking. Thanks
DaveInLA is offline Find More Posts by DaveInLA
Old Apr 11, 2008, 08:06 AM
Joined Apr 2005
Hi friend!
Did you make thie under carriage or it came in the E-flite kit? tks!
boomer
Old Apr 11, 2008, 12:25 PM
boomerace's Avatar
Joined Sep 2001
It will work fine. You may have to extend the battery shelf with a piece of 1/16" balsa and some velcro but should work fine. I did this all all 3 planes.
boomer
Old Apr 11, 2008, 12:29 PM
boomerace's Avatar
Joined Sep 2001
Originally Posted by Luis_Claudio
Hi friend!
I used the original gear on all 3. Cut the axle tubes to the maximum length and still get a wheel retainer on the axle. Then when you assemble the parts make them fit the tube as you have considerable flexibility in the plastic wheel parts for compression to the width needed.
boomer
Just tested E-flite 8.4 300mah Ni-MH in my Tiger Moth LESLIEx317537 Parkflyers 15 Feb 01, 2003 09:45 AM
e-flite Electrajet Deluxe version btompkins Aircraft - Electric - Airplanes (FS/W) 2 Aug 23, 2002 06:44 PM
E-Flite Odyssey EP tomr Electric Plane Talk 0 Dec 17, 2001 03:54 PM
Odyssey EP by E-flite Steven9026 Electric Sailplanes 4 Nov 14, 2001 10:38 PM
Odyssey EP by E-Flite for a beginner flyer? Bellavance Beginner Training Area (Aircraft-Electric) 0 Oct 09, 2001 07:23 PM
