Well, the carbon rods have held up well. It did take out the dihedral though. I think that the next one will get the SpiderWire treatment along with packing tape too. You read correctly....I'll be building another soon enough. Despite my issues with this plane, it is a great looking and well-mannered slow flyer for lazy days in calm air or indoors.
I'm presently building another one with over powered Blue Wonder motor and just Rudder/Elevator and have placed carbon reinforcing under the bottom wing at the 1/3 point and at LE of top wing. I found if I inserted a one piece carbon rod inside a aluminum tube that extended about 1" past the center supports tip to tip I could then bend the aluminum in the correct shape of the top wing dihedral and the aluminum was stiff enough to hold the carbon rod at the correct angle. I then thick CAed it in place and wrapped with tape. I will add the 30# test braided Spider Wire but seems the wing is structurally sound without it!
boomer |
http://polygonpete.blogspot.com/
This site has some Peanut Scale airplanes to model after. Just scroll down the page a little..double click to enlarge. enjoy jim |
Agreed, my sig jenny has a bamboo leading edge spar, and packing tape on both top and bottom of both wings, and it is still flying fine at 13 oz with floats attached. I reinforced the bottom of my SE5 with a carbon rod and packing tape and it flies fine without the strings needed.
Frank Quote:
Latest blog entry: Spaceship One
My review of the S.E.5a is up here on RCGroups
http://www.rcgroups.com/forums/showthread.php?t=788621 Enjoy |
I apologise if all of this has been covered elsewhere. I'm considering getting an E-Flite SE5A and I'd like to hear comments regarding the likelyhood of being able to squeeze in my favourite components.
Receiver - Hitec HFS-04M4G 37.5 x 25 x 26mm (1.47 x 0.98 x 0.62") Battery - Thunder Power 2 cell 2100mah 102 x 32 x 13mm (4 x 1.25 x 0.5") Servos - Hitec HS55 Sorry no dims but we all know what these look like. Speed Control - Most probably a Castle Creations Thunderbird ( I have not looked into what current rating I'll need). Your comments would be much appreciated Rob |
boomer |
Joined Sep 2006
Hey guys, I recently bought the SE5a, and I have a few questions.
E-flite recommends their S60 servo, which is 6g. I don't have those lying around, but I do have a few spare HS-55 servos, which are a little wider and taller. The difference in weight is nominal (2g), but the extra 1.8mm (x2) width seems to be an issue when trying the squeeze the 2 servos into the tiny servo slot. I can fit one in there, but the wire prevents me from squeezing the second one in. Would you recommend I pony up the $30 to get the S60s, or just cut a tiny slot for the HS-55 wires to fit through? I know at least one poster put ailerons on his SE5a... is this a good idea? The manual recommeds a 6x4 GWS prop to go with their 250 sized motor (which is what I'll get)... what can I try with a 7" diameter? Or should I stick with the 6" one? One more question: what's a good 1/10-1/12 scale British pilot to use? |
Here is my set-up with good results on 25-30 flights:
E-flite park 250 E-Flite 10amp pro ESC GWS 8x6 slow flyer prop Self built 740 2-cell lipo unknown C rating S-60 servos I don't think the HS-55's would be a big deal. If you look up the park 250 specs at E-Flite you'll see the park 250 can handle an 8x4 slow flyer. I know that the SE5a is a draggy airframe and my prop is probably too much, but it seems to work well. Others recommend the GWS 7x4 and I think that would be about right and look more scale than the 6 inch. |
Regarding ailerons, it depends whether or not you intend to fly outdoors or not. For indoor flying the 3-channel setup works fine. For outdoors I think ailerons would be fun, but only if you had enough power to pull the plane through the maneuvers that ailerons would make possible. A couple of us upgraded the motors to the Park 300 (mainly because we already had them laying around), and it's a good powerplant for this plane because it gives you the option of using a 3-cell LiPoly for outdoor flying. (The Park 250 is strictly 2-cell.) The extra power comes in handy on windy days, and would be needed if you added ailerons, IMHO. We're running APC 8x3.8 Slowflyer props, because it gives enough thrust for indoor flying on a 2-cell, yet won't overload the Park 300 on 3 cells. Hope this helps. Dean in Omaha |
| Thread Tools | |
| Just tested E-flite 8.4 300mah Ni-MH in my Tiger Moth | LESLIEx317537 | Parkflyers | 15 | Feb 01, 2003 09:45 AM |
| e-flite Electrajet Deluxe version | btompkins | Aircraft - Electric - Airplanes (FS/W) | 2 | Aug 23, 2002 06:44 PM |
| E-Flite Odyssey EP | tomr | Electric Plane Talk | 0 | Dec 17, 2001 03:54 PM |
| Odyssey EP by E-flite | Steven9026 | Electric Sailplanes | 4 | Nov 14, 2001 10:38 PM |
| Odyssey EP by E-Flite for a beginner flyer? | Bellavance | Beginner Training Area (Aircraft-Electric) | 0 | Oct 09, 2001 07:23 PM |
