Old Feb 26, 2008, 07:28 PM
Esprit440 is offline
Find More Posts by Esprit440
Supersonic hover
Esprit440's Avatar
Michigan, United States
Joined Sep 2003
Thanks Birdlives!
Joe I'm interested to see that gray depron - should look great.
-Matt
Esprit440 is offline Find More Posts by Esprit440
Old Feb 26, 2008, 09:05 PM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
Nice work Matt, another great little design. Should scale up well for a larger fan also.
Cheers,
Eric B.
AirX is offline Find More Posts by AirX
Old Feb 26, 2008, 09:33 PM
Supersonic hover
Esprit440's Avatar
Joined Sep 2003
Hi Eric, yeah I am thinking about a 200% pusher version for the Park Jet motor I picked up on sale at Hobby Lobby a while ago. Come to think of it I also have a couple of XF fan/motor combos lying around. Those will probably find their way into something sooner or later.
-Matt
Old Feb 26, 2008, 09:37 PM
Turn n Burn is offline
Find More Posts by Turn n Burn
Turn n Burn's Avatar
Joined Aug 2007
Thats really cool, I want one. Esprit man its too cold for me to fly right now but I'm glad you did. Excellent plane. I second Eric's vote to go 56mm yep.
Turn n Burn is offline Find More Posts by Turn n Burn
Old Feb 27, 2008, 01:16 AM
albireo is online now
Find More Posts by albireo
From Earth to the Moon!
albireo's Avatar
United States, CA, Sacramento
Joined Jul 2003
Matt,
I've cut out the parts but am confused on step 2 (pretty early to get stumped, eh?)
You say that I sand a half circular channel in each piece of foam... I see the wings (pgs 6,7,8) as one piece of flat 3mm foam. I don't get the "two pieces of wing should come back together..." unless the wing consists of 3 parts - the one I mentioned that's connected to the fuse, and two other ones that are sandwiched on top... (which I don't see in the plans...)
Sorry to be a dolt! Don't see it...
Thanks again!
Joe
albireo is online now Find More Posts by albireo
Old Feb 27, 2008, 11:48 AM
RCParkflyer is offline
Find More Posts by RCParkflyer
RCParkflyer's Avatar
Racine, WI AMA# 809291
Joined Nov 2003
Very Nice flying Jet :congrats
RCParkflyer is offline Find More Posts by RCParkflyer
Old Feb 27, 2008, 04:46 PM
Supersonic hover
Esprit440's Avatar
Joined Sep 2003
Hey Joe,
Yup the wing panel is one piece, what you need to do is cut it from wingtip to wingtip (I think this is mentioned in there somewhere) and sand a groove in each of the cut edges so the carbon rod fits inside when you glue them back together. The trim line is marked on the plans with a dashed line.
This method is a little bit more work than gluing the spar to the surface of the foam, which works great but doesn't look as clean.
-Matt
Old Feb 27, 2008, 05:56 PM
albireo's Avatar
Joined Jul 2003
Oh..... so I cut right through the wing all the way across (cut it in half)!
Old Feb 27, 2008, 06:58 PM
albireo's Avatar
Joined Jul 2003
Oh, BTW - do you think I can get by with 9g servos?
Old Feb 27, 2008, 10:25 PM
Supersonic hover
Esprit440's Avatar
Joined Sep 2003
Depends on the size of the 9g servos. I know the Hitec HS-55s I use sometimes would be pretty bulky for this jet, and they're around 8g.
I think it could be done since there is plenty of room in the fuselage for larger servos if you mount them further forward. The extra weight is an issue but it should definitely fly.
-Matt
Old Mar 02, 2008, 09:21 AM
chuck George is offline
Find More Posts by chuck George
USA, NH
Joined Sep 2004
F-22 thrust vectoring COOL
Matt,
found the build very impressive F-22 with the thrust vectoring and the manual is also done very well
Great job on both the kit and the manual also to share what you have done with everyone...
What you came up with is a great design that flies wonderful.
You should be very PROUD and also to share this with us...that's what it's all about this RC hobbie that we can't get it out of our system...
It's a sickness....good thing they don't have a pill for it.
www.chuckshobbies.com
sales@chuckshobbies.com
Chuck George
Chuck's Hobbies
The Home of Radio Control Airplane Electric RC Jet Flight.
Manufacture & Supplier of the Highest Quality Laser Cut & Molded Foam Kits.
chuck George is offline Find More Posts by chuck George
Old Mar 02, 2008, 08:14 PM
Supersonic hover
Esprit440's Avatar
Joined Sep 2003
Thanks Chuck - I've learned pretty much everything I know about RC from this site so it's nice to give something back.
-Matt
Old Mar 02, 2008, 09:17 PM
USA, NH
Joined Sep 2004
Matt,
You are very welcome, but we all are thank full to you for the fine work you have done..
My hat is off to you...
Keep the good work up great design.
Chuck's
Old Mar 06, 2008, 09:51 AM
Janusz Jawien is offline
Find More Posts by Janusz Jawien
Janusz Jawien's Avatar
Los Angeles Van Nuys, California, United States
Joined Apr 2002
Hi Matt,
I was so impressed by simplicity and elegance of your design that I started to make one for myself. I build the body just to discover that the DF I have is GWS50 and my Feigao is 1208436... much lower kV that it should be used. Besides I have Losi 8750 and bateries 2cell 730 and 3 cell 520. I was thinking of creating a workable propulsion system from those components... any advice? I do not need jet performance, just a nice stable flight. My thoughts are that I build light enough the Losi motor combined with DF50 on 2 or 3 cells should do the trick.....
Best regards,
Janusz
Janusz Jawien is offline Find More Posts by Janusz Jawien
Old Mar 06, 2008, 09:17 PM
Supersonic hover
Esprit440's Avatar
Joined Sep 2003
Hi Janusz, thanks for the kind words.
The EDF-50 should fit although you will need to enlarge the existing fan cutouts and move the servos forward to clear the larger opening.
I haven't tried the 4100kV Feigao in any EDF setups but I understand it isn't so great. For a pusher setup with a 3x3 DD prop on 3S it is quite impressive though.
Don't know much about the Losi motor, it may be too hot for an EDF-50 even on 2S. I would try some bench testing to see what works.
Good luck!
-Matt
Discussion Grumman F-9F Panther for EDF-40 Esprit440 Micro EDF Jets and Power Systems 292 May 31, 2012 08:32 PM
Video Twin EDF-40 F-22 Raptor 3D Devil Electric Plane Talk 0 Feb 27, 2006 07:22 AM
Spotted a new F-22 Raptor EDF kit in UK-- anyone know about this? EpowerFan Electric Ducted Fan Jet Talk 7 Nov 16, 2005 01:41 AM
Rave F-22 Help For EDF choise!!! Julius42024 Electric Ducted Fan Jet Talk 3 Aug 09, 2005 02:12 AM
Simple F-22 Raptor EDF mmormota Electric Ducted Fan Jet Talk 36 Mar 20, 2005 11:25 PM
