Old Dec 19, 2007, 10:06 AM
RoyEOetting is offline
Find More Posts by RoyEOetting
RoyEOetting's Avatar
Fairborn, OH
Joined May 2004
Matt, can you print your color schemes directly on Depron ? I tried that a few years ago with an ink jet but the result was very faded. I'm going to try it again. Perhaps if I prime the surface it will take the ink better. I also found out since I last tried it that the printer has advanced setting which permit me to dump more ink. The advantages are worth the try. One - I won't have to contact cement templates to the foam to cut out the parts. Two- I can get a pretty intricate color scheme with detail at a low cost in weight. The disadvantage is I can't shape anything after it is done without messing up the finish. Your simpler designs seem like they were made for this procedure. The other option would be to cut sheets of blue foam and print the parts on that. The blue foam is more malleable than depron.
I did a quick test checking to see if I could create 3D poly lines and then flatten the sheet and I can. I'm not talking compound surfaces but surfaces like the one you created in front of the canopy in your example. The biggest trick will be to create the outline. I might have to do that part in Rhino.
Sorry if this sounded like I was thinking out loud but i guess that is what i was doing. Any thoughts on anything I said would be appreciated. Good luck with your F-22.
Roy
RoyEOetting is offline Find More Posts by RoyEOetting
Old Dec 19, 2007, 10:11 AM
metroidrc is offline
Find More Posts by metroidrc
Micro EDF addict
metroidrc's Avatar
Upstate NY
Joined Jun 2007
Roy, another option would be to print it on tissue paper, then attach the tissue to the depron. Tissue weighs almost nothing, especially one layer.
metroidrc is offline Find More Posts by metroidrc
Old Dec 20, 2007, 04:51 PM
Esprit440 is offline
Find More Posts by Esprit440
Supersonic hover
Esprit440's Avatar
Michigan, United States
Joined Sep 2003
Hi Roy,
Yeah it would be great to be able to print right on the foam with an inkjet. I've never tried it but I would imagine that color coverage is not so great as you mentioned. The big drawback to me is the time needed to create the graphics and get everything "just right". I was working on an F-16 that used printed paper skins a few years ago and it still needs a LOT of work.
Browse around in the Indoor forum and you will see a lot of beautiful models using the tissue method that Metroid mentioned.
-Matt
Esprit440 is offline Find More Posts by Esprit440
Old Dec 23, 2007, 12:45 PM
Supersonic hover
Esprit440's Avatar
Joined Sep 2003
I just finished the first test model and I'm fairly satisfied with it. Things I learned:
- The upper fuselage skin needs to be pre-curved so the tension doesn't deform the wing plate
- Vertical tails need to be mounted with some kind of jig to get them aligned properly
- Battery needs to sit farther back than I thought to get the CG correct
- Next model may need to be slightly larger for battery clearance (~5%)
Weight with all the gear is 4.3oz, should be slightly higher with paint and misc linkages.
Happy Holidays everybody,
-Matt
Old Dec 23, 2007, 01:42 PM
Micro EDF addict
metroidrc's Avatar
Upstate NY
Joined Jun 2007
looks very solid - nice job!
Old Dec 23, 2007, 02:44 PM
Janusz Jawien is offline
Find More Posts by Janusz Jawien
Janusz Jawien's Avatar
Los Angeles Van Nuys, California, United States
Joined Apr 2002
Beautiful job Matt!
Your last post makes me do one of those!
Happy Holidays to All!
Janusz
Janusz Jawien is offline Find More Posts by Janusz Jawien
Old Jan 13, 2008, 05:29 AM
hyper-dart is offline
Find More Posts by hyper-dart
Joined Oct 2007
is there any progress on this plane? would be cool as a 30mm version too
Jacar
hyper-dart is offline Find More Posts by hyper-dart
Old Jan 13, 2008, 09:29 AM
Supersonic hover
Esprit440's Avatar
Joined Sep 2003
Final templates are almost done, build will start this week. Not much time left!
-Matt
Old Jan 13, 2008, 04:29 PM
FresnoJay is offline
Find More Posts by FresnoJay
To drive or to fly......BOTH!!
FresnoJay's Avatar
USA, CA, Clovis
Joined Apr 2007
Matt again nice work. May have to give this one a go after the panther.
Jason
FresnoJay is offline Find More Posts by FresnoJay
Old Jan 27, 2008, 08:21 PM
Supersonic hover
Esprit440's Avatar
Joined Sep 2003
Success!
The maiden flight of the second version went very well this afternoon. I rushed to get everything done late Saturday night, and the weather cooperated today with light winds and a practically tropical 33 degrees.
It has quite a wide speed range and the thrust vectoring paddles allow it do to tight "power loops" almost indefinitely. Roll control was good but not quite equal to ailerons even with the paddles.
I set up my camera out in the field but out of a 7 minute flight video got only 10 seconds or so of the plane in frame.
I'll paint it up this week and try to sneak in another flight after work if it's light enough.
Final specs:
WS: 15"
AUW: 4.8oz
Wing area: 98 sq.in
Wing loading: 7.1 oz/sq.ft
Fan: GWS EDF-40
Motor: Feigao 25T 5800kV
ESC: Castle Creations Phoenix 10
Battery: 3S TP 730
Receiver: Berg 4L
Servos: 2x Blue Bird BMS-303
-Matt
Old Jan 27, 2008, 08:33 PM
Micro EDF addict
metroidrc's Avatar
Upstate NY
Joined Jun 2007
very nice! lots of great entries for edf40...
Old Jan 31, 2008, 11:00 PM
Supersonic hover
Esprit440's Avatar
Joined Sep 2003
Here are the final images of the model and flight video for the deadline. It feels good to finish!
Flight video 2
-Matt
Old Jan 31, 2008, 11:40 PM
Tram is offline
Find More Posts by Tram
Fly it like you stole it..
Tram's Avatar
Florence, Al
Joined Oct 2000
Are there going to be plans on this available?
Jeff
www.CommonSenseRC.com
Tram is offline Find More Posts by Tram
Latest blog entry: Wow.. 3 years..
Old Jan 31, 2008, 11:49 PM
Supersonic hover
Esprit440's Avatar
Joined Sep 2003
Hi Jeff, yes I am going to put together plans and a build guide soon.
-Matt
Old Jan 31, 2008, 11:50 PM
Tram is offline
Tram's Avatar
Florence, Al
Joined Oct 2000
Nice..
Discussion Grumman F-9F Panther for EDF-40 Esprit440 Micro EDF Jets and Power Systems 292 May 31, 2012 08:32 PM
Video Twin EDF-40 F-22 Raptor 3D Devil Electric Plane Talk 0 Feb 27, 2006 07:22 AM
Spotted a new F-22 Raptor EDF kit in UK-- anyone know about this? EpowerFan Electric Ducted Fan Jet Talk 7 Nov 16, 2005 01:41 AM
Rave F-22 Help For EDF choise!!! Julius42024 Electric Ducted Fan Jet Talk 3 Aug 09, 2005 02:12 AM
Simple F-22 Raptor EDF mmormota Electric Ducted Fan Jet Talk 36 Mar 20, 2005 11:25 PM
