Old Dec 05, 2007, 10:02 PM
Maybz is offline
Find More Posts by Maybz
medium-sized Lewbowski
USA, CO, Denver
Joined Jan 2005
Build Log
YF-23 experimental VTEDF
This is a design I'm in the middle of developing.. it started out as an attempt to make Depron YF-23 that was simple to build (no shaping), had good aerobatic ability and still looked scale. I also didn't want to just make another profile design. So, I built a quick prototype to see how the airframe behaves and to dial in the CG. After a few minor tweaks I'm quite pleased with the performance. Video shows some high alpha tests trying to reduce wing wag. Gonna try a modified aileron design tomorrow which will hopefully help.
VT-EDF version build will start as soon as the aileron design is finalized. Power will be 2 Alfa fans with AC25/25 motors to keep things lite. Controls are coupled ailerons/elevons with vectored thrust. T to W won't be near as good as the proped version but will hopefully still have some punch.
But who knows....
Maybz is offline Find More Posts by Maybz
Old Dec 05, 2007, 10:50 PM
Maybz is offline
USA, CO, Denver
Joined Jan 2005
YF-23 experimental parkjet (2 min 11 sec)
Old Dec 05, 2007, 11:04 PM
LOGICAL_PSYCHO is offline
Find More Posts by LOGICAL_PSYCHO
LOGICAL_PSYCHO's Avatar
Columbus,Ohio
Joined Jan 2006
Cool! I have been wondering what you would do to top your last one.
Will we get plans for the prop version?
Can't wait.
LOGICAL_PSYCHO is offline Find More Posts by LOGICAL_PSYCHO
Old Dec 05, 2007, 11:07 PM
thewz is offline
Find More Posts by thewz
"It's a Quad" :O
thewz's Avatar
Temecula
Joined Jul 2004
Man that looks really good. Very floaty....just had to push the envelope and break it.....
I'd love to build this with the prop as is. Do you have any plans?
thewz is offline Find More Posts by thewz
Old Dec 05, 2007, 11:26 PM
Maybz is offline
USA, CO, Denver
Joined Jan 2005
Yeah, I can post plans for you guys... but let me finish tweaking it first.
Here is the near-final design for the EDF. Note the new ailerons with tip balancers which will hopefully reduce tip stalls and wagging.
Old Dec 05, 2007, 11:49 PM
thewz is offline
"It's a Quad" :O
thewz's Avatar
Temecula
Joined Jul 2004
You wouldn't happen to be an AE would you?
Old Dec 05, 2007, 11:57 PM
Maybz is offline
USA, CO, Denver
Joined Jan 2005
Nope. I'm just a guy with a computer
Old Dec 06, 2007, 12:00 AM
birdofplay is offline
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
The JSF has a Verticle Take Off version also ! for the Marines
Now THAT would be something NEW to Model !!! :-)
birdofplay is offline Find More Posts by birdofplay
Old Dec 06, 2007, 12:02 AM
thewz is offline
"It's a Quad" :O
thewz's Avatar
Temecula
Joined Jul 2004
Did you use some form of AD modeling to determine where to place the dog tooth and the size?
Great job with SW as well! I've got engineers on the 787 that know SW but mainly use CATIA.
Old Dec 06, 2007, 12:19 AM
Maybz is offline
USA, CO, Denver
Joined Jan 2005
Thanks, what do you mean by dog tooth?
I've seen a model of the entire AH-64 in CATIA - now THAT'S some serious modeling.
Old Dec 06, 2007, 01:48 AM
RCSuperPowers is offline
Find More Posts by RCSuperPowers
Just one more flight...
RCSuperPowers's Avatar
United States, OR, Portland
Joined Sep 2005
Wow man, you seriously have some of the best work. That thing flys so comfortable at all speeds and scenarios.
RCSuperPowers is offline Find More Posts by RCSuperPowers
Old Dec 06, 2007, 07:42 AM
leadfeather is online now
Find More Posts by leadfeather
Winging it >
leadfeather's Avatar
Joined May 2006
Kudos Mz, excellent work again!
leadfeather is online now Find More Posts by leadfeather
Old Dec 06, 2007, 07:48 AM
thewz is offline
"It's a Quad" :O
thewz's Avatar
Temecula
Joined Jul 2004
The triangular peices on the LE's
Old Dec 06, 2007, 08:48 AM
smkn951 is offline
Find More Posts by smkn951
smkn951's Avatar
United States, HI, Kapolei
Joined Jan 2007
by any chance the edf that would be used is an edf55? i just totaled my gws a-10.
btw, i really like the f-14, so much i don't want to crash it......so it sits it's mty second one.
can't wait to build this one.
thanks
smkn951 is offline Find More Posts by smkn951
Old Dec 06, 2007, 09:06 AM
Maybz is offline
USA, CO, Denver
Joined Jan 2005
Smkn951 - I'm using Alfa fans which have a 2.4" (61mm) shroud OD (outer diameter of the fan housing). If the EDF55 has an OD that is 61mm or smaller then it would probably fit - you might have to wrap a 1mm Depron shim around it. I have chosen to run two fans instead of one because I am trying to maximize the fan area for thrust and better throttle response at low speed/ high alpha - I am less concerned with top speed. I'll know a lot more about what does or doesn't work in a few days....
Now go fly your 14! I've crashed mine quite a few times - it will take a good beating and recover nicely. Just keep a bottle of foam safe CA and kicker near by.
Thewz, the two teeth on the LE are balancing tabs for CG.
Cheers
The Start of my YF-23 Black Widow II Project RCWorks Foamies (Kits) 39 Jul 14, 2009 07:24 PM
Build Log New Project - YF-23 GlasairAllen Electric Ducted Fan Jet Talk 525 Dec 13, 2008 10:59 AM
Yf-23 Black Widow Twin Midi Plane Crazy Electric Ducted Fan Jet Talk 23 Feb 08, 2005 03:25 PM
WIP :free YF-23 Speed 400 Pusher Plans ssyed Electric Ducted Fan Jet Talk 7 Jun 07, 2004 05:57 PM
YF-23 ATF Not Dead GlasairAllen Electric Ducted Fan Jet Talk 6 Jan 31, 2004 03:33 PM
