Old Dec 05, 2007, 08:44 PM
demisemiquaver is offline
Find More Posts by demisemiquaver
Just Say No To GMO
demisemiquaver's Avatar
Earth, System of Sol, Milky Way Galaxy
Joined Sep 2007
Question
Storm Launcher (big one) - How does it charge?
Question:
Does the "Big" Storm Launcher (not the mini) charge from the transmitter or an AC Adapter?
I'm wanting to try one but also wondering how strong the wheels are cuz I want to drive it around a lot too.
Thanks in Advance.
demisemiquaver is offline Find More Posts by demisemiquaver
Old Dec 05, 2007, 08:54 PM
aerosoardude is offline
Find More Posts by aerosoardude
Its not that windy...
United States, CA, PORTER RANCH
Joined May 2007
It has no wheels first off, as it uses plastic skids, hence the water ability. Also the battery is like regular hobby grade stuff and charges outside of the vehicle. Like lipo chargers.
aerosoardude is offline Find More Posts by aerosoardude
Old Dec 05, 2007, 10:19 PM
sonicjet is offline
Find More Posts by sonicjet
RC pilot,AMA Member.
sonicjet's Avatar
Northeast PA
Joined Sep 2007
A 2s lipo charger with an ac adapter(yes it actually has a cell balancer ) ,no wheels just a plastic skid,more reliable. much more thrust than you can imagine...3d on a full charge of a broken in lipo.
Don't forget to brake it in by letting it sit at 1/4 throttle for the first few charges,if you don't bad things will happen.
Remove the prop guards you will make more thrust,if it is used on water I would cut them off if I were you so the inner part of the guard will protect the motors,plus its easier.
Don't forget to buy the lipo, it doesn't come with it.
Btw its big , epp ,and fast so watch out!
Here it has great range much more than a aa and I've taken aa's out of visual range. I'd say about 500ft.
SL thread:59 pages o' fun
sonicjet is offline Find More Posts by sonicjet
Old Dec 06, 2007, 04:22 AM
msnyder is offline
Find More Posts by msnyder
msnyder's Avatar
Palo Alto, CA, USA
Joined Dec 2006
Yeah, you buy the SL batteries separately. Each battery comes
with an AC charger, so if you buy several batteries, you end up
with a surplus of chargers. But you can have several batteries
lined up ready to go, with one plane.
The battery and charger goes for $30 everywhere I've seen it
(except ebay of course...)
msnyder is offline Find More Posts by msnyder
Old Dec 06, 2007, 05:22 AM
sonicjet is offline
sonicjet's Avatar
Northeast PA
Joined Sep 2007
At wallys world its 17$
Old Dec 06, 2007, 08:12 PM
Bugman Jeff is offline
Find More Posts by Bugman Jeff
I'm a Registered User
Evansville, WI
Joined Dec 2006
Most wal-marts that still have batterys in stock have them on clearance, ranging from $17 to $5.
Bugman Jeff is offline Find More Posts by Bugman Jeff
Old Dec 06, 2007, 08:55 PM
sonicjet is offline
sonicjet's Avatar
Northeast PA
Joined Sep 2007
Look at beginning and 1:10+
Air Hogs Storm Launcher CRASH plane/boat (1 min 33 sec)
Don't worry its fine,it had the guards on.
Discussion How can I use one controller to control the other storm launcher steeles Electric Motor Design and Construction 3 Jun 12, 2007 08:04 AM
How does one wire a twin RiBell Parkflyers 26 Apr 25, 2003 09:19 PM
HOW does one get 1000 watts out of a f10 powered smart hotliner using a 15x15 prop ? earnest High Performance 11 Mar 15, 2003 10:22 AM
How does one learn all the standard Modelling Techniques? DocMac Power Systems 9 Jul 10, 2001 08:57 AM
